查看: 2262|回復: 1
STC12C5A60S2 串口2收不到程序 大神求指教!
ID:194894 發表于 2017-4-29 23:02 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
#define jingzhen     11059200UL
#define botelv   9600UL
#define uchar  unsigned char
#define uint   unsigned int
unsigned char buf[6]={'S','t','r','i','n','g'};
unsigned char *TextStr;
unsigned char *RecStr;
void PutString(char *TextStr)
    ES=0;
     while(*TextStr!=0)
        SBUF=*TextStr;
        while(TI==0);
        TI=0;
        TextStr++;
    ES=1;
void ReceiveString(char *RecStr)
    char num=0;
    unsigned char count=0;
    *RecStr=SBUF;
    count=0;
    RI=0;
void init(void)
                EA=0;
                TMOD&=0x0F;
                TMOD|=0x20;
                SCON=0x50;
                TH1=256-jingzhen/(botelv*12*16);
                TL1=256-jingzhen/(botelv*12*16);
                PCON=0x80;
                ES=1;
                TR1=1;
                REN=1;
                EA=1;
                init();
                PutString(&buf);
//                 ReceiveString(&buf);
void uart(void) interrupt 4
        if(RI)
                        RI=0;
                        *RecStr = SBUF;
                        SBUF = *TextStr;
                }        else
                {TI=0;}
ID:194894 發表于 2017-4-29 23:04 | 只看該作者
不好意思剛剛發錯了 那個是串口1的,串口2如下:
#include <stdio.h>
#include <string.h>
#include <reg52.h>
#define S2RI 0x01 //S2CON.1
#define S2TI 0x02 //S2CON.2
#define ES2 0x01
unsigned char buf[7]={'S','t','r','i','n','g'};
IE2=0x00;
while(*TextStr!=0)
S2BUF=*TextStr;
while(!(S2CON&S2TI));
S2CON &= ~S2TI;
TextStr++;
IE2=0x01;
char num=0;
*RecStr=S2BUF;
count=0;
S2CON &= ~S2RI;
void init(void)
//        AUXR |= 0x08;        //????????S2SMOD
//        S2CON = 0x50;        //8???,?????
//        AUXR &= 0xFB;        //???????????Fosc/12,?12T
//        BRT = 0xFA;        //?????????????
//        AUXR |= 0x10;        //??????????
AUXR &= 0xf7; //??????
BRT = 0xDC; //?????????????
AUXR |= 0x04; //???????????Fosc,?1T
IE2=0x01; //????2??ES2=1
EA=1; //????
init();
PutString(&buf);
while(1);
void UART2(void) interrupt 8
if(S2CON & S2RI)
S2CON &= ~S2RI;
*RecStr = S2BUF;
S2BUF = *TextStr;
