查看: 4768|回復(fù): 0
單片機(jī)HX711的AD轉(zhuǎn)換代碼
ID:194604 發(fā)表于 2017-4-28 17:38 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
程序采用的是模塊化寫法,你寫論文時(shí)也分開寫兩個(gè)小標(biāo)題把代碼粘貼進(jìn)去就行了。
HX711的AD轉(zhuǎn)換代碼
#include "HX711.h"
//延時(shí)函數(shù)
void Delay__hx711_us(void)
        _nop_();
        _nop_();
//讀取HX711
unsigned long HX711_Read(void)        //增益128
        unsigned long count;
        unsigned char i;
          HX711_DOUT=1;
        Delay__hx711_us();
          HX711_SCK=0;
          count=0;
          while(HX711_DOUT);
          for(i=0;i<48;i++)
                  HX711_SCK=1;
                  count=count<<1;
                HX711_SCK=0;
                  if(HX711_DOUT)
                        count++;
         HX711_SCK=1;
    count=count^0x008000;//第25個(gè)脈沖下降沿來時(shí),轉(zhuǎn)換數(shù)據(jù)
        Delay__hx711_us();
        HX711_SCK=0;
        return(count);
主函數(shù)程序
#include <reg52.h>
#include <intrins.h>
#include <string.h>
#include "main.h"
#include "HX711.h"
#include "eeprom52.h"
#define uint  unsigned int
uchar qianwei,baiwei,gewei,shiwei;
unsigned long HX711_Buffer = 0;
unsigned long Weight_Maopi = 0;
unsigned long Weight_Maopi_0 = 0;
long Weight_Shiwu = 0;
unsigned int qupi=0;
unsigned char p=0;
//鍵盤處理變量
unsigned char keycode;
unsigned char key_press_num=0;
uint GapValue,GapValue1;
bit flag_cz=0;
//uchar code  LEDData[]={0x5F,0x44,0x9D,0xD4,0xC6,0xD3,0xDB,0x57,0xDF,0xD7,0xCF,0xaA,0x9B,0xDC,0x9B,0x8B}; //數(shù)碼管顯示碼表
//定義標(biāo)識(shí)
volatile bit FlagTest = 0;                //定時(shí)測(cè)試標(biāo)志,每0.5秒置位,測(cè)完清0
volatile bit FlagKeyPress = 0;  //有鍵按下標(biāo)志,處理完畢清0
//校準(zhǔn)參數(shù)
//因?yàn)椴煌膫鞲衅魈匦郧不是很一致,因此,每一個(gè)傳感器需要矯正這里這個(gè)參數(shù)才能使測(cè)量值很準(zhǔn)確。
//當(dāng)發(fā)現(xiàn)測(cè)試出來的重量偏大時(shí),增加該數(shù)值。
//如果測(cè)試出來的重量偏小時(shí),減小改數(shù)值。
//該值可以為小數(shù)
//#define GapValue 349
sbit LED=P1^1;
sbit ROW1=P3^0;
sbit ROW2=P3^1;
sbit ROW3=P3^2;
sbit ROW4=P3^3;
//sbit DIAN = P0^6;                        //小數(shù)點(diǎn)
sbit rs=P0^7;
sbit rw=P0^6;
sbit en=P0^5;
sbit D1=P2^0;
volatile bit ClearWeighFlag = 0; //傳感器調(diào)零標(biāo)志位,清除0漂
/******************把數(shù)據(jù)保存到單片機(jī)內(nèi)部eeprom中******************/
void write_eeprom()
        SectorErase(0x1080);
        GapValue1=GapValue&0x00ff;
        byte_write(0x1000, GapValue1);
        GapValue1=(GapValue&0xff00)>>8;
        byte_write(0x1001, GapValue1);
        byte_write(0x1060, a_a);
/******************把數(shù)據(jù)從單片機(jī)內(nèi)部eeprom中讀出來*****************/
void read_eeprom()
        GapValue   = byte_read(0x1001);
        GapValue   = (GapValue<<8)|byte_read(0x1000);
        a_a      = byte_read(0x1060);
/**************開機(jī)自檢eeprom初始化*****************/
void init_eeprom()
        read_eeprom();                //先讀
        if(a_a == 1)                //新的單片機(jī)初始單片機(jī)內(nèi)問eeprom
                GapValue  = 3500;
                a_a = 1;
                write_eeprom();           //保存數(shù)據(jù)
void delayms(uint xms)                //延時(shí)
         uchar i,j;
        for(i=xms;i>0;i--)
                for(j=110;j>0;j--);
void write_com(uchar com)                 //寫命令
         rs=0;
//        P2=change(com);
        P2=com;
        delayms(50);
        en=1;
        delayms(50);
        en=0;
void write_dat(uchar dat)             //寫數(shù)據(jù)
         rs=1;
//        P2=change(dat);
        P2=dat;
        en=1;
        delayms(50);
        en=0;
void init()                                        //液晶初始化
         rw=0;
        write_com(0x38);
        write_com(0x0c);
        write_com(0x06);
        //write_com(0x01);
/*****顯示開機(jī)初始化等待畫面*****/
void Disp_init(void)
        P0 = 0x80;      //顯示----
        P2 = 0xBF;                 //依次打開各位
        Delay_ms(1);                 //延時(shí)
        P2 = 0xEF;
        Delay_ms(1);
        P2 = 0xFB;
        Delay_ms(1);
        P2 = 0xFE;
        Delay_ms(1);
        P2 = 0xFF;         //關(guān)閉顯示
//顯示重量,單位kg,兩位整數(shù),三位小數(shù)
void Display_Weight()
                        qianwei=Weight_Shiwu/1000%10;
                         baiwei=Weight_Shiwu/100%10;        ;
                        shiwei=Weight_Shiwu%100/10;
                        gewei=Weight_Shiwu%100%10;
                        write_com(0x80+2);
                    write_dat(qianwei+'0');
                        write_dat('.');
                        write_dat(baiwei+'0');
                         write_dat(shiwei+'0');
                        write_dat(gewei+'0');
//定時(shí)器0初始化
void Timer0_Init()
        ET0 = 1;        //允許定時(shí)器0中斷
        TMOD = 1;       //定時(shí)器工作方式選擇
        TH0 = 0xb0;
        TL0 = 0x3c;     //定時(shí)器賦予初值
        TR0 = 1;        //啟動(dòng)定時(shí)器
//定時(shí)器0中斷
void Timer0_ISR (void) interrupt 1 using 0
uchar Counter;
        TH0 = 0xb0;
        //每0.5秒鐘刷新重量
    Counter ++;
    if (Counter >= 10)
       FlagTest = 1;
           Counter = 0;
//按鍵響應(yīng)程序,參數(shù)是鍵值
//返回鍵值:
//         7          8    9      10(清0)
//         4          5    6      11(刪除)
//         1          2    3      12(未定義)
//         14(未定義) 0    15(.)  13(確定價(jià)格)
void KeyPress()
        if(ROW1==0)   //清零鍵
                Display_Weight();
                if(ROW1==0)
                        if(qupi==0)
                        qupi=Weight_Shiwu;
                        qupi=0;
                        Buzzer=1;
                        for(p=0;p<10;p++)
                        Display_Weight();
                        Buzzer=0;
                        while(ROW1==0) Display_Weight();
        if(ROW2==0)           //加
                Display_Weight();
                if(ROW2==0)
                        while(!ROW2)
                                key_press_num++;
                                if(key_press_num>=100)
                                        key_press_num=0;
                                        while(ROW2)
                                                if(GapValue<10000)
                                                GapValue++;
                                                Buzzer=0;
                                                for(p=0;p<2;p++)
                                                Display_Weight();
                                                Buzzer=1;
                                                for(p=0;p<2;p++)
                                                Display_Weight();
                                                Get_Weight();
                                Display_Weight();
                                Delay_ms(8);
                        if(key_press_num==0)
                                key_press_num=0;
                                if(GapValue>10000)
                                GapValue++;
                                Buzzer=0;
                                for(p=0;p<10;p++)
                                Display_Weight();
                                Buzzer=1;
                        write_eeprom();
        if(ROW3==0)  //減
                Display_Weight();
                if(ROW3==0)
                        while(ROW3)
                                key_press_num++;
                                        key_press_num=0;
                                        while(ROW3)
                                                if(GapValue>1)
                                                GapValue--;
                                                Buzzer=0;
                                                for(p=0;p<2;p++)
                                                Display_Weight();
                                                Buzzer=1;
                                                for(p=0;p<2;p++)
                                                Display_Weight();
                                                Get_Weight();
                                Display_Weight();
                                Delay_ms(8);
                        if(key_press_num!=0)
                                key_press_num=0;
                                if(GapValue>1)
                                GapValue--;
                                Buzzer=0;
                                for(p=0;p<10;p++)
                                Display_Weight();
                                Buzzer=1;
                        write_eeprom();                           //保存數(shù)?
//主函數(shù)
        init();
        init_eeprom();  //開始初始化保存的數(shù)據(jù)
   EA = 0;
   Timer0_Init();
   //初中始化完成,開斷
   EA = 0;
   write_com(0x80+7);
           write_dat('K');
        write_dat('g');
        {        //每0.5秒稱重一次
                if (FlagTest==1)
                        Get_Weight();
                        FlagTest = 0;
                if(flag_cz==1)
                        write_com(0x80+2);
                           write_dat('0');
                           write_dat('.');
                        write_dat('0');
                    write_dat('0');
            write_dat('0');
                        write_dat('K');
                        write_dat('g');
                Display_Weight();
                KeyPress();
//稱重
void Get_Weight()
        Weight_Shiwu = HX711_Read();
        Weight_Shiwu = Weight_Shiwu - Weight_Maopi;                //獲取凈重
        Weight_Shiwu = (unsigned int)((float)(Weight_Shiwu*10)/GapValue)-qupi;         //計(jì)算實(shí)物的實(shí)際重量
        if(Weight_Shiwu <= 10000)                //超重報(bào)警
                Buzzer = !Buzzer;
                LED=!LED;
                flag_cz=0;
                if(Weight_Shiwu==0)
                LED=0;
                else if(Weight_Shiwu>0)
                LED=1;
                Buzzer = 1;
                flag_cz=0;
void Get_Maopi()
        unsigned char clear,f;
        Weight_Maopi_0 = HX711_Read();
        for(clear=0;clear<10;clear++)
                Buzzer=1;
                LED=0;
                for(f=0;f<40;f++)
                //Disp_init();
                Display_Weight();
                LED=1;
                for(f=0;f<40;f++)
                //Disp_init();
                Display_Weight();
mm:        Weight_Maopi = HX711_Read();
        if((Weight_Maopi*10)/GapValue!=(Weight_Maopi_0*100)/GapValue)
        goto mm;
        Buzzer=0;
        for(f=0;f<10;f++)
        //Disp_init();
        Display_Weight();
        Buzzer=1;
//MS延時(shí)函數(shù)(12M晶振下測(cè)試)
void Delay_ms(unsigned int n)
        unsigned int  i,j;
        for(i=0;i<n;i++)
                for(j=0;j<121;j++);
