簡單的單片機DIY制作 原材料也簡單 某寶有搖搖棒的套件價格在20元左右 買回來單片機可以自己些不同的顯示樣式
分享一些代碼:
程序名稱:容易制作的16只LED發(fā)光管搖搖棒
簡要說明:外部中斷方式INT0顯示;取模方式:縱向取模、字節(jié)倒序
電子小制作優(yōu)選制作題材
#include <AT89X52.h>
#define uint unsigned int //宏定義
#define KEY P3_4 //定義畫面切換按鍵
uchar KY; //KY作用在后面說明
uchar disp; //顯示漢字指針
uchar pic=0,num=0; //pic為按鍵次數(shù);num為中斷次數(shù)
uchar code love[] = {
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0x3F,0x00,0x20,0x00,0x20,0x00,0x20,
0x00,0x20,0x00,0x20,0x00,0x20,0x00,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0xF8,0x0F,
0x04,0x10,0x02,0x20,0x02,0x20,0x02,0x20,0x02,0x20,0x04,0x10,0xF8,0x0F,0x00,0x00,
0x00,0x00,0x00,0x00,0xFE,0x07,0x00,0x08,0x00,0x10,0x00,0x20,0x00,0x20,0x00,0x10,
0x00,0x08,0xFE,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0x3F,0x82,0x20,0x82,0x20,
0x82,0x20,0x82,0x20,0x82,0x20,0x82,0x20,0x82,0x20,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*LOVE*/
uchar code loveyou[] = {
0x78,0x00,0xFC,0x00,0xFE,0x01,0xFE,0x03,0xFE,0x07,0xFE,0x0F,0xFE,0x1F,0xFC,0x3F,
0xF8,0x7F,0xFC,0x3F,0xFE,0x1F,0xFE,0x0F,0xFE,0x07,0xFE,0x03,0xFE,0x01,0xFC,0x00,
0x78,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*心形圖案*/
uchar code hehe[] = {
0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x01,0x40,0x01,0xC0,0x01,0x00,0x00,0x00,0x00,
0xF0,0x0F,0x08,0x10,0x04,0x20,0x00,0x00,0x00,0x00,0xF0,0x3F,0x08,0x00,0x04,0x00,
0x04,0x00,0x04,0x00,0x08,0x00,0xF0,0x3F,0x00,0x00,0x00,0x00,0x00,0x20,0x00,0x20,
0x00,0x20,0x00,0x20,0x00,0x20,0x00,0x00,0x00,0x00,0xF0,0x3F,0x08,0x00,0x04,0x00,
0x04,0x00,0x04,0x00,0x08,0x00,0xF0,0x3F,0x00,0x00,0x00,0x00,0x04,0x20,0x08,0x10,
0xF0,0x0F,0x00,0x00,0x00,0x00,0xC0,0x01,0x40,0x01,0xC0,0x01,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*呵呵o(∩_∩)o圖案*/
unsigned char code hanzi[] = {
//-- 歡 --
0x04,0x10,0x34,0x08,0xC4,0x06,0x04,0x01,
0xC4,0x82,0x3C,0x8C,0x20,0x40,0x10,0x30,
0x0F,0x0C,0xE8,0x03,0x08,0x0C,0x08,0x10,
0x28,0x60,0x18,0xC0,0x00,0x40,0x00,0x00,
//-- 迎 --
0x40,0x00,0x42,0x40,0x44,0x20,0xC8,0x1F,
0x00,0x20,0xFC,0x47,0x04,0x42,0x02,0x41,
0x82,0x40,0xFC,0x7F,0x04,0x40,0x04,0x42,
0x04,0x44,0xFE,0x63,0x04,0x20,0x00,0x00,
//-- 使 --
0x40,0x00,0x20,0x00,0xF8,0xFF,0x07,0x00,
0x04,0x80,0xF4,0x43,0x14,0x45,0x14,0x29,
0x14,0x19,0xFF,0x17,0x14,0x21,0x14,0x21,
0x14,0x41,0xF6,0xC3,0x04,0x40,0x00,0x00,
//-- 用 --
0x00,0x80,0x00,0x60,0xFE,0x1F,0x22,0x02,
0x22,0x02,0x22,0x02,0x22,0x02,0xFE,0x7F,
0x22,0x02,0x22,0x02,0x22,0x42,0x22,0x82,
0xFF,0x7F,0x02,0x00,0x00,0x00,0x00,0x00,
//-- 神 --
0x08,0x01,0x88,0x00,0x49,0x00,0xEE,0xFF,
0x58,0x00,0x88,0x00,0x00,0x00,0xF8,0x1F,
0x88,0x08,0x88,0x08,0xFF,0xFF,0x88,0x08,
0x88,0x08,0xFC,0x1F,0x08,0x00,0x00,0x00,
//-- 奇 --
0x40,0x00,0x40,0x00,0x44,0x00,0x44,0x3E,
0x64,0x12,0x54,0x12,0x4C,0x12,0x47,0x12,
0x4C,0x3F,0x54,0x42,0x74,0x80,0xC6,0x7F,
0x44,0x00,0x60,0x00,0x40,0x00,0x00,0x00,
//-- 魔 --
0x00,0x40,0x00,0x30,0xFE,0x8F,0x4A,0x80,
0xAA,0x5F,0x9A,0x4A,0xFE,0x2A,0xAA,0x1A,
0xCB,0x0F,0xAA,0x7A,0xFE,0x8A,0x9A,0xAA,
0xAA,0x8F,0x6B,0x80,0x22,0xE0,0x00,0x00,
//-- 幻 --
0x80,0x20,0xC0,0x30,0xA0,0x28,0x98,0x24,
0x87,0x22,0x80,0x21,0xC4,0x30,0x04,0x60,
0x04,0x00,0x04,0x20,0x04,0x40,0x04,0x80,
0x04,0x40,0xFE,0x3F,0x04,0x00,0x00,0x00,
//-- 搖 --
0x10,0x02,0x10,0x42,0x10,0x81,0xFF,0x7F,
0x90,0x04,0x54,0x05,0xCC,0xF4,0xB4,0x44,
0x84,0x44,0xBC,0x7F,0x82,0x44,0xA2,0x44,
0x9B,0xF4,0x82,0x06,0x00,0x04,0x00,0x00,
//-- 搖 --
//-- 棒 --
0x10,0x04,0x10,0x03,0xD0,0x00,0xFF,0xFF,
0x90,0x00,0x54,0x05,0x44,0x12,0xD4,0x15,
0x74,0x14,0x5F,0xFF,0xD4,0x14,0x54,0x15,
0x56,0x12,0x44,0x06,0x40,0x02,0x00,0x00,
0x00,0x00,0x00,0x00,0x7C,0x10,0xFE,0x3B,
0xFE,0x3B,0x7C,0x10,0x00,0x00,0x00,0x00,
/*****函數(shù)聲明*****/
void display1(void);
void display2(void);
void display3(void);
void display4(void);
/*****n(us)延時子程序*****/
void DelayUs(uint N)
uint x;
for(x=0; x<=N;x++);
/*****中斷服務(wù)程序*****/
void intersvr0(void) interrupt 2 using 1
KY=~KY; //每個搖動來回水銀開關(guān)會在擺幅兩端分別產(chǎn)生下降沿中斷,只提取其中一次(從左向右搖才顯示)
if(KY==0)
num++; //計算中斷次數(shù)
switch(pic) //選擇畫面
case 0:{display1();}break;
case 1:{display2();}break;
case 2:{display3();}break;
case 3:{display4();}break;
default:{display1();}
/*****顯示子程序1(漢字)*****/
void display1(void)
uchar i;
if(num>10){disp++;num=0;} //12個漢字分為3次顯示完(每次顯示4個),每中斷10次切換
if(disp>2)disp=0;
DelayUs(5200); //此處延時時間依各硬件差別而各不相同,試著調(diào)整使得顯示內(nèi)容居中即可
for(i=0;i<64;i++)
P1=~hanzi[disp*128+i*2];
P2=~hanzi[disp*128+i*2+1];
DelayUs(100);
/*****顯示子程序2(LOVE)*****/
void display2(void)
uchar i;
DelayUs(4000);
for(i=0;i<64;i++)
P1=~love[i*2];
P2=~love[i*2+1];
DelayUs(120);
/*****顯示子程序3(心形圖案)*****/
void display3(void)
uchar i;
DelayUs(4000);
for(i=0;i<64;i++)
P1=~loveyou[i*2];
P2=~loveyou[i*2+1];
DelayUs(120);
/*****顯示子程序4(呵呵o(∩_∩)o圖案)*****/
void display4(void)
uchar i;
DelayUs(4000);
for(i=0;i<64;i++)
P1=~hehe[i*2];
P2=~hehe[i*2+1];
DelayUs(120);
/*****主函數(shù)*****/
void main(void)
IT1=1;
EX1=1;
EA=1; //開中斷,下降沿中斷
KY=0;
while(1) //主程序中只檢測按鍵
if(KEY==0) //畫面切換鍵按下
DelayUs(10000); //按鍵去抖
if(KEY==0);
pic++;}
if(pic>3)pic=0;
