查看: 2398|回復: 0
51單片機可調(diào)鬧鐘代碼
ID:194291 發(fā)表于 2017-4-27 18:06 | 顯示全部樓層 |閱讀模式
自己寫的,可以調(diào)試。
下載:
駱放—可調(diào)鬧鐘程序.rar (60.08 KB, 下載次數(shù): 11)
  1. #include "main.h"
  2. unsigned char keyscan()
  3. {
  4.     unsigned char keyvalue;
  5.                 KEYPORT=0xf0;
  6.
  7.                 if(0xf0!=KEYPORT)
  8.                 {
  9.                     KEYPORT=0xfe;
  10.                                 if(KEYPORT!=0xfe)
  11.                                 {
  12.                                     if(0xf0!=KEYPORT)
  13.                         delay_ms(10);
  14.                                     keyvalue=KEYPORT;
  15.                                                 keyvalue&=0xf0;
  16.                                                 keyvalue+=0x0e;
  17.                                                 while(KEYPORT!=0xfe);
  18.                                                 delay_ms(10);
  19.                                                 while(KEYPORT!=0xfe);
  20.                                                 return keyvalue;
  21.                                 }
  22.
  23.                 }
  24.
  25.                 if(0xf0!=KEYPORT)
  26.                 {
  27.
  28.                     KEYPORT=0xfd;
  29.                                 if(KEYPORT!=0xfd)
  30.                                 {
  31.                                                 if(0xf0!=KEYPORT)
  32.                                                 delay_ms(10);
  33.                                     keyvalue=KEYPORT;
  34.                                                 keyvalue&=0xf0;
  35.                                                 keyvalue+=0x0d;
  36.                                                 while(KEYPORT!=0xfd);
  37.                                                 delay_ms(10);
  38.                                                 while(KEYPORT!=0xfd);
  39.                                                 return keyvalue;
  40.                                 }
  41.
  42.                 }
  43.
  44.                 if(0xf0!=KEYPORT)
  45.                 {
  46.
  47.                     KEYPORT=0xfb;
  48.                                 if(KEYPORT!=0xfb)
  49.                                 {
  50.                                     if(0xf0!=KEYPORT)
  51.                         delay_ms(10);
  52.                                     keyvalue=KEYPORT;
  53.                                                 keyvalue&=0xf0;
  54.                                                 keyvalue+=0x0b;
  55.                                                 while(KEYPORT!=0xfb);
  56.                                                 delay_ms(10);
  57.                                                 while(KEYPORT!=0xfb);
  58.                                                 return keyvalue;
  59.                                 }
  60.
  61.                 }
  62.
  63.                 if(0xf0!=KEYPORT)
  64.                 {
  65.
  66.                     KEYPORT=0xf7;
  67.                                 if(KEYPORT!=0xf7)
  68.                                 {
  69.                                                 if(0xf0!=KEYPORT)
  70.                                                 delay_ms(10);
  71.                                     keyvalue=KEYPORT;
  72.                                                 keyvalue&=0xf0;
  73.                                                 keyvalue+=0x07;
  74.                                                 while(KEYPORT!=0xf7);
  75.                                                 delay_ms(10);
  76.                                                 while(KEYPORT!=0xf7);
  77.                                                 return keyvalue;
  78.                                 }
  79.
  80.                 }
  81.                 return 0xff;
  82. }
  83. unsigned char keypro()
  84. {
  85.     unsigned char num;
  86.                 num=keyscan();
  87.                 switch(num)
  88.                 {
  89.                     case 0x7e:return 0;break;
  90.                                 case 0xbe:return 1;break;
  91.                                 case 0xde:return 2;break;
  92.                                 case 0xee:return 3;break;
  93.                                 case 0x7d:return 4;break;
  94.                                 case 0xbd:return 5;break;
  95.                                 case 0xdd:return 6;break;
  96.                                 case 0xed:return 7;break;
  97.                                 case 0x7b:return 8;break;
  98.                                 case 0xbb:return 9;break;
  99.                                 case 0xdb:return 10;break;
  100.                                 case 0xeb:return 11;break;
  101.                                 case 0x77:return 12;break;
  102.                                 case 0xb7:return 13;break;
  103.                                 case 0xd7:return 14;break;
  104.                                 case 0xe7:return 15;break;
  105.                                 default:return 0xff;break;
  106.                 }
  107. }
