#include<reg51.h>
#include"intrins.h" // _nop_();
sbit scl=P2^1;
sbit sda=P2^0;
bit write=0;
uint num,num1;
uchar ge,shi;
uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,
0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
void delay_ms(uint Z)
uint x,y;
for(x=Z;x>0;x--)
for(y=110;y>0;y--);
/*****ÅäÖÃIICD¾Æ¬**********/
void delay()
_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();
void start()//¿aê¼
sda=1;
delay();
scl=1;
delay();
sda=0;
delay();
void stop()
sda=0;
delay();
scl=1;
delay();
sda=1;
delay();
void respons()
uchar i;
scl=1;
delay();
while((sda==1)&&(i<250))
i++;
scl=0;
delay();
void init()
sda=1;
delay();
scl=1;
delay();
void write_byte(uchar date)
uchar i,temp;
temp=date;
for(i=0;i<8;i++)
temp=temp<<1;
scl=0;
delay();
sda=CY;
delay();
scl=1;
delay();
scl=0;
delay();
sda=1;
delay();
uchar read_byte()
uchar i,k;
scl=0;
delay();
sda=1;
delay();
for(i=0;i<8;i++)
scl=1;
delay();
k=(k<<1)|sda;///////
scl=0;
delay();
return k;
void write_add(uchar address,uchar date)
start();
write_byte(0xa0);
respons();
write_byte(address);
respons();
write_byte(date);
respons();
stop();
uchar read_add(uchar address)
uchar date;
start();
write_byte(0xa0);
respons();
respons();
start();
write_byte(0xa1);
respons();
date=read_byte();
stop();
return date;
/************êyÂë1üÏÔê¾oˉêy*********************/
void display(uchar shi,uchar ge)
P1=0xdf;
P0=table[shi];
delay_ms(5);
P1=0xef;
P0=table[ge];
delay_ms(5);
/*********Ö÷oˉêy************************/
init();
num1=read_add(2);
if(num1>100)
num1=0;
TMOD=0x01;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
ET0=1;
EA=1;
TR0=1;
display(num1/10,num1%10);
if(write==1)
write=0;
write_add(2,num1);
/*******ÖD¶Ïoˉêy*****************************/
void time0() interrupt 1
num++;
if(num==20)
num=0;
num1++;
write=1;
if(num1==100)
num1=0;
I2C總線.zip
2017-4-17 21:37 上傳
下載積分: 黑幣 -5
44.41 KB, 下載次數: 11, 下載積分: 黑幣 -5
