查看: 3330|回復: 1
51單片機小車實現尋跡源程序
ID:189728 發表于 2017-4-15 09:56 | 顯示全部樓層 |閱讀模式
51小車實現尋跡
*3ìDò1|Äü£»êμÏÖD¡3μѰ¼£
*3ìDò×÷Õß         ÕÅ»¶
*′′×÷걼䣻2016-11-10
#include <reg52.h>
#define unint unsigned int
#define unchar unsigned char
sbit IN1=P1^0;
sbit IN2=P1^2;
sbit IN3=P1^3;
sbit IN4=P1^5;
sbit ENA=P1^1;
sbit ENB=P1^4;
sbit jiance1=P2^5;
sbit jiance2=P2^6;
unchar timer1;
//   ¶¨ê±Æ÷3õê¼»ˉ
void Timer()
        TMOD= 0x10;
        TH1 = 0xFE;
        TL1 = 0x0C;
        ET1 = 1;
        EA = 1;
        TR1 = 1;
//    ÖD¶Ïoˉêy
void Time1(void) interrupt 3
        TH1 = 0xFE;
        TL1 = 0x0C;
        timer1++;
//     Õ¼¿Õ±è′|àíoˉêy
unint z;
void display(z)
                if(timer1>100)
                        timer1=0;
                if(timer1 < z)
                        ENA=1;
                        ENB=1;
                        ENA=0;
                        ENB=0;
void zhengzhuan()
        IN1 = 0;
        IN2 = 1;
        IN3 = 0;
        IN4 = 1;
        display(40);
void fanzhuan()
        IN1 = 1;
        IN2 = 0;
        IN3 = 1;
        IN4 = 0;
        display(50);
void youzhuan()
        IN1 = 0;
        IN2 = 1;
        IN3 = 0;
        IN4 = 0;
        display(40);
void zuozhuan()
{        IN1 = 0;
        IN2 = 0;
        IN3 = 0;
        IN4 = 1;
        display(40);
        Timer();
                zhengzhuan();
                if(/*jiance1==0&&*/jiance2==1)
                        zuozhuan();
                        break;
                if(jiance1==1/*&&jiance2==0*/)
                        youzhuan();
                        break;
ID:449181 發表于 2018-12-20 20:52 | 顯示全部樓層
這是4輪的還是2輪的,如何接線呢
