藍牙控制小車單片機代碼,帶尋跡 避障等功能的整合版,51hei提供下載.
2017-4-12 17:22 上傳
2017-4-12 17:22 上傳
單片機源代碼:
- 藍牙控制程序:
- P1_0 接前進
- P1_1 接后退
- P1_2 接左轉
- P1_3 接右轉
- 插入藍牙模塊:
- 晶振:11.0592M晶振
- #include<AT89x52.H>
- #include <intrins.h>
- //#define Left_moto_go {P1_0=1,P1_1=0,P1_2=1,P1_3=0;} //左邊兩個電機向前走
- //#define Left_moto_back {P1_0=0,P1_1=1,P1_2=0,P1_3=1;} //左邊兩個電機向后轉
- //#define Left_moto_Stop {P1_0=0,P1_1=0,P1_2=0,P1_3=0;} //左邊兩個電機停轉
- //#define Right_moto_go {P1_4=1,P1_5=0,P1_6=1,P1_7=0;} //右邊兩個電機向前走
- //#define Right_moto_back {P1_4=0,P1_5=1,P1_6=0,P1_7=1;} //右邊兩個電機向前走
- //#define Right_moto_Stop {P1_4=0,P1_5=0,P1_6=0,P1_7=0;} //右邊兩個電機停轉
- #define TRIG0 P3_4 //右超聲波接口定義
- #define ECHO0 P3_5 //右超聲波接口定義
- #define TRIG1 P2_4 //中超聲波接口定義
- #define ECHO1 P2_5 //中超聲波接口定義
- #define TRIG2 P2_6 //左超聲波接口定義
- #define ECHO2 P2_7 //左超聲波接口定義
- #define TRIG3 P3_6 //后超聲波接口定義
- #define ECHO3 P3_7 //后超聲波接口定義
- #define Infrared_4 P1_7 //紅外輸出信號接口定義
- #define Infrared_6 P1_6 //紅外輸出信號接口定義
- //#define Sevro_moto_pwm P2_7 //接舵機信號端輸入PWM信號調節速度
- //#define Left_1_led P3_4 //P3_2接四路尋跡模塊接口第一路輸出信號即中控板上面標記為OUT1
- //#define Left_2_led P3_5 //P3_3接四路尋跡模塊接口第二路輸出信號即中控板上面標記為OUT2
- //#define Right_1_led P3_6 //P3_4接四路尋跡模塊接口第三路輸出信號即中控板上面標記為OUT3
- //#define Right_2_led P3_7 //P3_5接四路尋跡模塊接口第四路輸出信號即中控板上面標記為OUT4
- #define up 'A' //前進
- #define down 'B' //后退
- #define left 'C' //左轉
- #define right 'D' //右轉
- #define stop 'F' //停止
- #define gear 'G' //擋位
- #define BrakeH 'H' //開制動
- #define BrakeI 'I' //關制動
- #define swrst 'S' //軟件復位
- //char code str[] = "收到指令,向前!\n";
- //char code str1[] = "收到指令,向后!\n";
- //char code str2[] = "收到指令,向左!\n";
- //char code str3[] = "收到指令,向右!\n";
- //char code str4[] = "收到指令,停止!\n";
- unsigned char const discode[] = { 0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0xBF,0xff/*-*/};
- //unsigned char const positon[3]= { 0xfe,0xfd,0xfb};
- unsigned char disbuff[3] = { 0,0,5};
- unsigned char swbuffer[5][4] = {{0,0,0,0},{1,4,5,0},{2,0,0,0},{3,0,0,0},{4,0,0,5}};//超聲波0、1、2、3,是否開自動停止4-1,(默認0關)角度:4-2/3
- //unsigned char tswbuffer[5][4] = {{'1','1','1','1'},{'2','2','2','2'},{'3','3','3','3'},{'4','4','4','4'},{'5','5','5','5'}};
- //unsigned char code str[] = "www.mucstudio.com.cn\r\n";
- char angle = 5; //角度初始化
- unsigned int dynamic_distance = 1; //初始化前動態距離
- unsigned int dynamic_distance_down = 1;//初始化后動態距離
- //unsigned char pwm_val_left = 0;//變量定義
- //unsigned char push_val_left =13;//舵機歸中,產生約,1.5MS 信號
- unsigned int time=0; //時間變量
- unsigned int timer1=0; //時間變量
- unsigned int timer=0; //延時基準變量
- unsigned int anglecenter = 0; //方向校正計數歸0
- unsigned int sw[4] = {450,450,450,450}; //超聲波距離值
- //unsigned long S=0; //計算出超聲波距離值
- //unsigned long S1=0;
- //unsigned long S2=0;
- //unsigned long S3=0;
- //unsigned long S4=0;
- bit flag_REC=0; //串口接收完成標志位
- bit flag =0; //持續接收標志位
- //bit flag_xj =0;
- //bit flag_bj =0;
- unsigned char t=0;
- unsigned char dat=0;
- unsigned char buff[5]=0; //接收緩沖字節;
- unsigned char posit = 0;
- //函數聲明
- void delay(unsigned int); //延時函數
- //void brakeup(void); //前進緊急制動
- //void brakedown(void); //后退緊急制動
- void run(void); //前進
- void backrun(void); //后退
- void leftrun(void); //左轉
- void rightrun(void); //右轉
- void stoprun(void); //前后停止
- void gearrun(void); //擋位:1、2、3(循環)
- void swrstrun(void); //軟件復位
- void stoplr(void); //停止左右轉動
- void brakeh(void); //開自動制動
- void brakei(void); //關自動制動
- void startModule(int); //啟動超聲波測距信號
- int conut(int); //計算距離
- void send_str(void); //數據發送
- void Display(void); //數碼管顯示
- void Loaddata(void); //啟動超聲波測距,計算距離,載入buffer
- void control(void); //解析控制指令并執行
- void time1(void); //TIMER1中斷服務子函數interrupt 3
- void receive(void); //中斷接收3個字節,串行口中斷 interrupt
- void Init(void); //初始化
- void main(void); /*--主函數--*/
- /*--主函數--*/
- void main(void)
- // _nop_();
- // delay(500);
- // _nop_();
- Init(); //初始化
- // P1_0 = 0;
- // P1_1 = 0;
- // P1_2 = 0;
- // P1_3 = 0;
- // delay(200);
- // P1_0 = 1;
- // P1_1 = 1;
- // P1_2 = 1;
- // P1_3 = 1;
- // delay(100);
- // push_val_left=13; //舵機歸中
- //ISP_CONTR=00100000B,SWBS=0(選擇AP區),SWRST=1(軟件復位)
- while(1) /*無限循環*/
- // Loaddata(); //數據采集
- // send_str(); //數據發送
- Display(); //顯示1號距離
- // while(flag_xj) //循線標志位
- // if(flag_REC==1)
- // stoprun();
- // break;
- // //有信號為0 沒有信號為1
- // if(Left_2_led==0&&Right_1_led==0)
- // run();
- // else
- // if(Right_1_led==1&&Left_2_led==0) //右邊檢測到黑線
- // Left_moto_go; //左邊兩個電機正轉
- // Right_moto_back; //右邊兩個電機反轉
- // if(Left_2_led==1&&Right_1_led==0) //左邊檢測到黑線
- // Right_moto_go; //右邊兩個電機正轉
- // Left_moto_back; //左邊兩個電機反式開始轉
- // while(flag_bj) /*無限循環*/
- // if(timer>=1000) //100MS檢測啟動檢測一次
- // timer=0;
- // StartModule(); //啟動檢測
- // Conut(); //計算距離
- // if(S<20) //距離小于20CM
- // stoprun(); //小車停止
- // COMM(); //方向函數
- // else if(S>30) //距離大于,30CM往前走
- // run();
- // stoprun();
- // break;
- //延時函數
- void delay(unsigned int k) //延時1.00043ms
- unsigned int x,y;
- for(x=0; x<k; x++)
- for(y=0; y<111; y++);
- _nop_();
- _nop_();
- _nop_();
- //機動單元
- //void brakeup(void) //緊急制動
- // if((sw[1] <= 40)||(sw[0] <= 30)||(sw[2] <=30))
- // P1_0 = 1; //靜止前進
- // P1_1 = 0;
- // if(sw[3] <= 50) //檢測前制動
- // P1_1 = 1; //靜止后退
- // P1_0 = 0;
- void run(void) //前進
- if(swbuffer[4][1] == 0) //是否開動態制動,0為關
- P1_0 = 0;
- timer = 0;
- else
- if((sw[1] <= dynamic_distance*30)||(sw[0] <= (dynamic_distance*20))||(sw[2] <= (dynamic_distance*20))) //檢測距離||(sw[0] <= (dynamic_distance*25))||(sw[2] <= (dynamic_distance*25))
- P1_0 = 1; //靜止前進
- delay(150);
- if(--dynamic_distance <= 1) //重置動態距離
- dynamic_distance = 1;
- else
- P1_0 = 0;
- timer = 0; //中斷停止計數值歸0
- dynamic_distance = dynamic_distance + 1;
- if(dynamic_distance >= 4)
- dynamic_distance = 4;
- // brakeup();
- void backrun(void) //后退
- P1_1 = 0;
- timer = 0;
- else
- if(sw[3] <= dynamic_distance_down*30) //檢測后超聲波數據
- P1_1 = 1; //靜止后退
- delay(150);
- if(--dynamic_distance_down <= 1) //重置動態距離
- dynamic_distance_down = 1;
- else
- P1_1 = 0;
- if(++dynamic_distance_down >= 4)
- dynamic_distance_down = 4;
- // brakedown();
- void leftrun(void) //左轉
- P1_2 = 0;
- // P1_3 = 1;
- // if(Infrared == 0)
- // angle = 5;
- if(--angle == -1) //角度左校正
- angle = 0;
- // angle = (--angle == -1) ? 0 : angle;
- anglecenter = 0; //中校正歸0
- void rightrun(void) //右轉
- P1_3 = 0;
- // P1_2 = 1;
- // angle = 5;
- // else
- if(++angle == 11) //角度右校正
- angle = 10;
- // angle = (++angle == 11) ? 10 : angle;
- void stoprun(void) //前后停止
- P1_0 = 1;
- P1_1 = 1;
- dynamic_distance = 1; //重置動態距離
- void gearrun(void) //擋位:1、2、3(循環)
- P1_5 = 0;
- _nop_();
- P1_5 = 1;
- void swrstrun(void) //軟件復位
- ISP_CONTR=0x20;
- // ISP_CONTR=0x60;
- void stoplr(void) //停止左右轉動
- P1_2 = 1;
- P1_3 = 1;
- void brakeh(void)
- swbuffer[4][1] = 1; //1為開動態制動
- void brakei(void)
- swbuffer[4][1] = 0; //0為關動態制動
- void startModule(int i) //啟動測距信號
- if(i == 0)
- TRIG0 = 1;
- else if(i == 1)
- TRIG1 = 1;
- else if(i == 2)
- TRIG2 = 1;
- else if(i == 3)
- TRIG3 = 1;
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- if(i == 0)
- TRIG0 = 0;
- else if(i == 1)
- TRIG1 = 0;
- else if(i == 2)
- TRIG2 = 0;
- else if(i == 3)
- TRIG3 = 0;
- //計算距離
- int conut(int i)
- int S0 = 0;
- unsigned int chaoshi = 0;
- if(i == 0)
- while(!ECHO0) //當RX為零時等待
- // chaoshi=TH1*256+TL1;
- // if(chaoshi >26571) //超時彈出
- // break;
- else if(i == 1)
- while(!ECHO1)
- // break;
- else if(i == 2)
- while(!ECHO2)
- // break;
- else if(i == 3)
- while(!ECHO3)
- // break;
- TR0=1; //開啟計數0
- if(i == 0)
- while(ECHO0) //當RX為1計數并等待
- // if(++chaoshi >40000)
- // break;
- else if(i == 1)
- while(ECHO1)
- // if(++chaoshi >40000) //超時彈出
- // break;
- else if(i == 2)
- while(ECHO2)
- // break;
- else if(i == 3)
- while(ECHO3)
- // break;
- TR0=0; //關閉計數0
- time=TH0*256+TL0; //讀取脈寬長度單位0.1MS
- TH0=0;
- TL0=0;
- if(chaoshi >40000) //超時彈出
- S0 = sw[i]; //使用上次值
- else
- S0 = ((time*1.7)/100);
- if(i == 1)
- disbuff[0]=S0%1000/100; //更新顯示距離
- disbuff[1]=S0%1000%100/10;
- disbuff[2]=S0%1000%10 %10;
- // disbuff[0]=angle%1000/100; //更新顯示方向角
- // disbuff[1]=angle%1000%100/10;
- // disbuff[2]=angle%1000%10 %10;
- return S0; //算出來是CM
- //數據發送函數
- //void send_str()
- // // 傳送字串
- // char i = 0;
- // while(i<=9)
- // SBUF = 0x10;//0x31
- // while(!TI); // 等特數據傳送
- // TI = 0; // 清除數據傳送標志
- // SBUF = '\n';//0x31
- // TI = 0;
- // i++; // 下一個字符
- // void send(short int dat)
- //SBUF = dat>>8;
- //while(TI == 0);
- //TI = 0;
- //SBUF=dat &0XFF;
- //while(TI == 0);
- //TI = 0;
- int x = 0;
- // unsigned char k = 0;
- // SBUF = '\n'; //一幀數據開始標志
- // TI = 0;
- while(x <= 4)
- int y = 0;
- while(y <= 3)
- SBUF = swbuffer[x][y];
- // SBUF = k;
- while(!TI); // 等特數據傳送
- TI = 0; // 清除數據傳送標志
- y++;
- x++; // 下一個字符
- SBUF = '\n'; //一幀數據完成標志
- // SBUF = '\r'; //一幀數據完成標志
- // SBUF = 0x0d; //一幀數據完成標志
- //數碼管顯示
- if(posit==0)
- P0=(discode[disbuff[posit]])&0x7f; //+產生點
- P2_1=0;
- P2_2=1;
- P2_3=1;
- else if(posit==1)
- P0=discode[disbuff[posit]];
- P2_1=1;
- P2_2=0;
- P2_3=1;
- else if(posit==2)
- P2_1=1;
- P2_2=1;
- P2_3=0;
- P2_1=1;
- P2_2=1;
- P2_3=1;
- posit++;
- if(posit == 3)
- posit = 0;
- //啟動超聲波測距,計算距離,載入buffer
- unsigned int i= 0;
- while(i <= 4)
- if(i <= 3)
- startModule(i); //啟動超聲波測距
- sw[i] = conut(i); //計算距離
- swbuffer[i][1]= sw[i]%1000/100; //載入buffer
- swbuffer[i][2]= sw[i]%1000%100/10;
- swbuffer[i][3]= sw[i]%1000%10 %10;
- else if(i == 4)
- // swbuffer[i][1]= angle%1000/100; //載入buffer
- swbuffer[i][2]= angle%1000%100/10;
- swbuffer[i][3]= angle%1000%10 %10;
- i++;
- // push_val_left=5; //舵機向左轉90度
- // timer=0;
- // while(timer<=4000); //延時400MS讓舵機轉到其位置
- // StartModule(); //啟動超聲波測距
- // S2=S;
- // push_val_left=23; //舵機向右轉90度
- // timer=0;
- // S4=S;
- // timer=0;
- // S1=S;
- // if((S2<20)||(S4<20)) //只要左右各有距離小于,20CM小車后退
- // backrun(); //后退
- // timer=0;
- // if(S2>S4)
- // rightrun(); //車的左邊比車的右邊距離小 右轉
下載:
20.藍牙控制小車 尋跡 避障整合版.zip
(99.94 KB, 下載次數: 80)
2017-4-12 17:06 上傳
單片機代碼 下載積分: 黑幣 -5
