/*MCU:STC89C52*/ /*Designed by: Y.Q.Bi*/
#include <reg52.h> #include <intrins.h> #define uchar unsigned char #define uint unsigned int
uchar code table[]={0xc0,0xf9,0xa4,0xb0, 0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xC6,0xA1,0x86,0x8E};//共陰數碼管顯示代碼
void Key_scan(void); void delay(uint d);
void main(void) //主程序 { while(1) { Key_scan(); P1=0xf7; delay(2000); } }
void Key_scan(void) //確定按鍵子程序 { uchar key,readkey,x_temp,y_temp; P2=0x0f; x_temp=P2&0x0f; //確定哪一行按鍵按下 if(x_temp==0x0f) goto keyout; P2=0xf0; y_temp=P2&0xf0; //確定哪一列按鍵按下 readkey=x_temp|y_temp; //確定具體的按鍵按下
switch(readkey) { case 0xee:key=0;P0=table[key]; break; case 0xde:key=1;P0=table[key]; break; case 0xbe:key=2;P0=table[key]; break; case 0x7e:key=3;P0=table[key]; break; case 0xed:key=4;P0=table[key]; break; case 0xdd:key=5;P0=table[key]; break; case 0xbd:key=6;P0=table[key]; break; case 0x7d:key=7;P0=table[key]; break; case 0xeb:key=8;P0=table[key]; break; case 0xdb:key=9;P0=table[key]; break; case 0xbb:key=10;P0=table[key];break; case 0x7b:key=11;P0=table[key];break; case 0xe7:key=12;P0=table[key];break; case 0xd7:key=13;P0=table[key];break; case 0xb7:key=14;P0=table[key];break; case 0x77:key=15;P0=table[key];break; default:break; }
keyout:_nop_(); }
void delay(uint d) //延時子程序 { while(--d); }
