查看: 2960|回復(fù): 1
51單片機(jī)輸出正弦波
ID:185230 發(fā)表于 2017-3-31 22:03 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include<reg51.h>
#include<intrins.h>
sbit wr=P3^6;
sbit cs=P3^0;
unsigned char k,t;
sbit key=P3^1;
void keyscan();
unsigned char code Table[]={
0x80,0x83,0x86,0x89,0x8d,0x90,0x93,0x96,0x99,
0x9c,0x9f,0xa2,0xa5,0xa8,0xab,0xae,0xb1,0xb4,
0xb7,0xba,0xbc,0xbf,0xc2,0xc5,0xc7,0xca,0xcc,
0xcf,0xd1,0xd4,0xd6,0xd8,0xda,0xdd,0xdf,0xe1,
0xe3,0xe5,0xe7,0xe9,0xea,0xec,0xee,0xef,0xf1,
0xf2,0xf4,0xf5,0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,
0xfc,0xfd,0xfd,0xfe,0xff,0xff,0xff,0xff,0xff,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xfd,
0xfd,0xfc,0xfb,0xfa,0xf9,0xf8,0xf7,0xf6,0xf5,
0xf4,0xf2,0xf1,0xef,0xee,0xec,0xea,0xe9,0xe7,
0xe5,0xe3,0xe1,0xde,0xdd,0xda,0xd8,0xd6,0xd4,
0xd1,0xcf,0xcc,0xca,0xc7,0xc5,0xc2,0xbf,0xbc,
0xba,0xb7,0xb4,0xb1,0xae,0xab,0xa8,0xa5,0xa2,
0x9f,0x9c,0x99,0x96,0x93,0x90,0x8d,0x89,0x86,
0x83,0x80,0x80,0x7c,0x79,0x76,0x72,0x6f,0x6c,
0x69,0x66,0x63,0x60,0x5d,0x5a,0x57,0x55,0x51,
0x4e,0x4c,0x48,0x45,0x43,0x40,0x3d,0x3a,0x38,
0x35,0x33,0x30,0x2e,0x2b,0x29,0x27,0x25,0x22,
0x20,0x1e,0x1c,0x1a,0x18,0x16,0x15,0x13,0x11,
0x10,0x0e,0x0d,0x0b,0x0a,0x09,0x08,0x07,0x06,
0x05,0x04,0x03,0x02,0x02,0x01,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x01,0x02,0x02,0x03,0x04,0x05,0x06,0x07,0x08,
0x09,0x0a,0x0b,0x0d,0x0e,0x10,0x11,0x13,0x15,
0x16,0x18,0x1a,0x1c,0x1e,0x20,0x22,0x25,0x27,
0x29,0x2b,0x2e,0x30,0x33,0x35,0x38,0x3a,0x3d,
0x40,0x43,0x45,0x48,0x4c,0x4e,0x51,0x55,0x57,
0x5a,0x5d,0x60,0x63,0x66,0x69,0x6c,0x6f,0x72,
0x76,0x79,0x7c,0x80};
void Delay(int Time_ms);
k=4;
cs=0;
    wr=1;
   P0=Table[t];
   wr=0;
   keyscan();
  Delay(k);
t++;
   if(t==256) t=0;
void Delay(int Time_u)
int i;
for(i=0;i<Time_u;i++)
  _nop_();
void keyscan()
if(key==0)   k=k+10;   if(k==54)          k=4;
相關(guān)帖子
ID:333877 發(fā)表于 2018-7-2 20:09 來自觸屏版 | 只看該作者
求大神解釋一下
