1、STM32的DAC轉(zhuǎn)換是什么開始的呢?
問:STM32的DAC轉(zhuǎn)換是什么開始的呢?如何利用DAC輸出一個脈寬的控的單脈沖呢?
答:DAC是通過寫入DAC輸出寄存器開始的。另外,如果想要脈沖,使用TIM功能。
2、STM32的DAC輸出電壓
問:DAC的輸出電壓是如何調(diào)節(jié)的呢,輸入的數(shù)字量和輸出的電壓怎么不成比例呢,輸出電壓不符合數(shù)據(jù)手冊上提供的公式(DAC輸出=VREFXDOR/4095),求高人指點,程序如下:
- #include"stm32f10x_lib.h"
- #defineDAC_DHR8R1_Address0x40007410
- DAC_InitTypeDefDAC_InitStructure;
- DMA_InitTypeDefDMA_InitStructure;
- ErrorStatusHSEStartUpStatus;
- uc8Escalator8bit[50]={0x0,0x33,0x66,0x99,0xcc,0xff};
- voidRCC_Configuration(void);
- voidGPIO_Configuration(void);
- voidNVIC_Configuration(void);
- voidDelay(vu32nCount);
- intmain(void)
- #ifdefDEBUG
- debug();
- #endif
- RCC_Configuration();
- GPIO_Configuration();
- NVIC_Configuration();
- TIM_PrescalerConfig(TIM6,0xF,TIM_PSCReloadMode_Update);
- TIM_SetAutoreload(TIM6,0xFF);
- TIM_SelectOutputTrigger(TIM6,TIM_TRGOSource_Update);
- DAC_InitStructure.DAC_Trigger=DAC_Trigger_T6_TRGO;
- DAC_InitStructure.DAC_WaveGeneration=DAC_WaveGeneration_None;
- DAC_InitStructure.DAC_OutputBuffer=DAC_OutputBuffer_Disable;
- DAC_Init(DAC_Channel_1,&DAC_InitStructure);
- DMA_DeInit(DMA2_Channel3);
- DMA_InitStructure.DMA_PeripheralBaseAddr=DAC_DHR8R1_Address;
- DMA_InitStructure.DMA_MemoryBaseAddr=(u32)&Escalator8bit;
- DMA_InitStructure.DMA_DIR=DMA_DIR_PeripheralDST;
- DMA_InitStructure.DMA_BufferSize=6;
- DMA_InitStructure.DMA_PeripheralInc=DMA_PeripheralInc_Disable;
- DMA_InitStructure.DMA_MemoryInc=DMA_MemoryInc_Enable;
- DMA_InitStructure.DMA_PeripheralDataSize=DMA_PeripheralDataSize_Byte;
- DMA_InitStructure.DMA_MemoryDataSize=DMA_MemoryDataSize_Byte;
- DMA_InitStructure.DMA_Mode=DMA_Mode_Circular;
- DMA_InitStructure.DMA_Priority=DMA_Priority_High;
- DMA_InitStructure.DMA_M2M=DMA_M2M_Disable;
- DMA_Init(DMA2_Channel3,&DMA_InitStructure);
- DMA_Cmd(DMA2_Channel3,ENABLE);
- DAC_Cmd(DAC_Channel_1,ENABLE);
- DAC_DMACmd(DAC_Channel_1,ENABLE);
- TIM_Cmd(TIM6,ENABLE);
- while(1)
- RCC_DeInit();
- RCC_HSEConfig(RCC_HSE_ON);
- HSEStartUpStatus=RCC_WaitForHSEStartUp();
- if(HSEStartUpStatus==SUCCESS)
- FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
- FLASH_SetLatency(FLASH_Latency_2);
- RCC_HCLKConfig(RCC_SYSCLK_Div1);
- RCC_PCLK2Config(RCC_HCLK_Div1);
- RCC_PCLK1Config(RCC_HCLK_Div2);
- RCC_PLLConfig(RCC_PLLSource_HSE_Div1,RCC_PLLMul_9);
- RCC_PLLCmd(ENABLE);
- while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY)==RESET)
- RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
- while(RCC_GetSYSCLKSource()!=0x08)
- RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA2,ENABLE);
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO|RCC_APB2Periph_GPIOA,ENABLE);
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_DAC,ENABLE);
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM6,ENABLE);
- GPIO_InitTypeDefGPIO_InitStructure;
- GPIO_InitStructure.GPIO_Pin=GPIO_Pin_4;
- GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
- GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP;
- GPIO_Init(GPIOA,&GPIO_InitStructure);
- #ifdefVECT_TAB_RAM
- NVIC_SetVectorTable(NVIC_VectTab_RAM,0x0);
- #else/*VECT_TAB_FLASH*/
- NVIC_SetVectorTable(NVIC_VectTab_FLASH,0x0);
- #endif
- for(;nCount!=0;nCount--);
輸出電壓為什么不是0~3.3V呢?
答1:(u32)&Escalator8bit;你把這個里面的數(shù)據(jù)強制轉(zhuǎn)換為32位,也就是0x0,0x33,0x66,0x99轉(zhuǎn)換為一個32位的數(shù)據(jù),你這樣做是不對的。你應(yīng)該定義一個16位的數(shù)組,然后VREFXDOR/4095算出DOR的值,DOR的值不能超過4095.
答2:DAC_OutputBuffer-輸出緩存使能再試試
1、關(guān)于STM32F103RE的DAC
問:關(guān)于STM32F103RE中有幾個DAC呢?是只有一個DAC(包括兩個通道)還是有兩個呢?
答:有2個,這個你可以到引腳圖上面看到。
2、STM32F107的DAC例程都用TIMx更新啟動DMA2
問:STM32F107的DAC例程都用TIMx更新啟動DMA2,沒有不用TIMx啟動DMA2自動把數(shù)據(jù)傳送DAC的DHRxx寄存器里面?該如何設(shè)置呢?
答:不用TIM只能自己寫時間判斷了.可以在while()里面寫一個計數(shù)器的處理或者延時的處理.
3、STM32F107可以帶多個外置式ADC嗎?如果可以最多可以帶多少個?
問:STM32F107可以帶多個外置式ADC嗎?如果可以最多可以帶多少個?
答:一共有16個痛多的ADC,外置式是什么類型連接的?
答:外置式ADC型號是AD7490的16通道,SPI接口。因為總共有38路模擬量的,我想用三個外置ADC。另外我想問一下是不是可以只用一個SPI接口就可以連接三個外置ADC呢?如果可以怎么做片選呢?萬分感謝!
答:用其他3個IO做片選就可以
6、STM32F2ADC
問:STM32F系列單片機中ADC的每個通道的采用周期都是可配置的,我想問一下采樣周期配置的越大轉(zhuǎn)換出來的值越精確嗎?比如STM32F2處理器的ADC采用周期可以是3、15、28、56、84、112、144、480.還有就是ADC中分為規(guī)則組和注入組,這兩種模式在使用上有什么本質(zhì)的不同嗎?
答:ADC采用周期越大采集間隔越長,這個值越小采集越精確。規(guī)則組此模式通過設(shè)置ADC_CR1寄存器上的DISCEN位激活。它可以用來執(zhí)行一個短序列的n次轉(zhuǎn)換(n<=8),此轉(zhuǎn)換是ADC_SQRx寄存器所選擇的轉(zhuǎn)換序列的一部分。數(shù)值n由ADC_CR1寄存器的DISCNUM[2:0]位給出。一個外部觸發(fā)信號可以啟動ADC_SQRx寄存器中描述的下一輪n次轉(zhuǎn)換,直到此序列所有的轉(zhuǎn)換完成為止?偟男蛄虚L度由ADC_SQR1寄存器的L[3:0]定義。舉例:n=3,被轉(zhuǎn)換的通道=0、1、2、3、6、7、9、10第一次觸發(fā):轉(zhuǎn)換的序列為0、1、2第二次觸發(fā):轉(zhuǎn)換的序列為3、6、7第三次觸發(fā):轉(zhuǎn)換的序列為9、10,并產(chǎn)生EOC事件第四次觸發(fā):轉(zhuǎn)換的序列0、1、2注入組此模式通過設(shè)置ADC_CR1寄存器的JDISCEN位激活。在一個外部觸發(fā)事件后,該模式按通道順序逐個轉(zhuǎn)換ADC_JSQR寄存器中選擇的序列。一個外部觸發(fā)信號可以啟動ADC_JSQR寄存器選擇的下一個通道序列的轉(zhuǎn)換,直到序列中所有的轉(zhuǎn)換完成為止?偟男蛄虚L度由ADC_JSQR寄存器的JL[1:0]位定義。例子:n=1,被轉(zhuǎn)換的通道=1、2、3第一次觸發(fā):通道1被轉(zhuǎn)換第二次觸發(fā):通道2被轉(zhuǎn)換第三次觸發(fā):通道3被轉(zhuǎn)換,并且產(chǎn)生EOC和JEOC事件第四次觸發(fā):通道1被轉(zhuǎn)換
答:非常感謝您的回答。其實我想問的是采樣時間越大采樣值就越精確嗎?ADC采樣周期可以是3、15、28、56、84、112、144、480.最小的采樣時間是3個ADCCLK,最大的是480個ADCCLK,這個值是越大越好嗎?
7、STM32ADC操作模式有哪些?
問:STM32ADC操作模式有哪些?
答:單次轉(zhuǎn)換模式:轉(zhuǎn)換一次則停止連續(xù)轉(zhuǎn)換模式:轉(zhuǎn)換完一次后即開始下一次轉(zhuǎn)換掃描模式:掃描一組模擬通道間斷模式:每觸發(fā)一次,轉(zhuǎn)換序列中n個通道多種觸發(fā)方式
8、STM32的內(nèi)部溫度傳感器通過哪個AD采集?
答:STM32集成了片上的溫度傳感器,可以用來測量芯片內(nèi)部的溫度;STM32內(nèi)部溫度傳感器與ADC的通道16相連,與ADC配合使用實現(xiàn)溫度測量;測量范圍–40~125℃,精度±1.5℃。
9、STM32CPU溫度數(shù)值如何計算?
答:ADC轉(zhuǎn)換結(jié)束以后,讀取ADC_DR寄存器中的結(jié)果,通過下面的公式計算T(℃)=V25–VSENSE/Avg_Slope+25V25:溫度傳感器在25℃時的輸出電壓,典型值1.43VVSENSE:溫度傳感器的當(dāng)前輸出電壓,與ADC_DR寄存器中的結(jié)果ADC_ConvertedValue之間的轉(zhuǎn)換關(guān)系為:VSENSE=ADC_ConvertedValue*Vdd/Vdd_convert_value(0xFFF)Avg_Slope:溫度傳感器輸出電壓和溫度的關(guān)聯(lián)參數(shù),典型值4.3mV/℃轉(zhuǎn)換程序Vtemp_sensor=ADC_ConvertedValue*Vdd/Vdd_convert_value;Current_Temp=(V25-Vtemp_sensor)/Avg_Slope+25;
10、使用ADC時的注意事項是什么?
答:1、外部電路的等效輸入阻抗要匹配,采樣速度越快,輸入阻抗越小。STM32數(shù)據(jù)手冊上有對照表;2、只有在100腳和144腳的產(chǎn)品上才有VREF+和VREF-引出管腳。在其它產(chǎn)品封裝中,VREF+在芯片內(nèi)部與VDDA相連,VREF-在芯片內(nèi)部與VSSA相連;3、電路設(shè)計時,在VREF+和VDDA上一定要有良好的濾波,使用高質(zhì)量的濾波電容且一定要盡量靠近芯片的管腳。
11、關(guān)于STM32 雙ADC 同步注入模式
問:我想用TIM控制雙ADC同步采樣6路信號,因為聽說DMA方式會有錯位的BUG,所以想用雙ADC同步注入方式采樣。但是看了手冊后有以下幾個疑惑
1. ADC_InitStructure.ADC_Mode = ADC_Mode_InjecSimult;
如果我設(shè)置了同步注入模式,可是觸發(fā)方式選擇什么呢。能否簡單的說明下同步注入
模式的初始化配置流程。
2. 在數(shù)據(jù)手冊上只有ADC1有注入數(shù)據(jù)寄存器,而ADC2是沒有的。但是在庫函數(shù)中發(fā)現(xiàn)有
ADC_GetInjectedConversionValue這樣一個函數(shù),用這個是否能讀出ADC2注入
組的數(shù)據(jù)呢?
答1:選擇自動注入就可以,注意不可能同時使用自動注入和間斷模式。 2、此模式轉(zhuǎn)換一個注入通道組。外部觸發(fā)來自ADC1的注入組多路開關(guān)(由ADC1_CR2寄存器的JEXTSEL[2:0]選擇),它同時給ADC2提供同步觸發(fā)。
12、ADC 定時器觸發(fā)
問:按(下面)
/* ADC 初始化 */ void ADC_Configuration(void)
{ ADC_InitTypeDef ADC_InitStructure; DMA_InitTypeDef DMA_InitStructure;
GPIO_InitTypeDef GPIO_InitStructure; TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; TIM_OCInitTypeDef TIM_OCInitStructure; /* Enable peripheral clocks ------------------------------------------------*/ /* Enable DMA1 clock */
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE); /* Enable GPIOA clock */ RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE); /* TIM3 Periph clock enable */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE); /* Enable ADC1 clocks */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1 , ENABLE); /* Configure PA.00, PA.01, PA.02, PA.03 (ADC Channel0, Channel1, Channel2, Channel3) as analog inputs */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3; GPIO_InitStr
程序初始化后,只能觸發(fā)一次,轉(zhuǎn)換完數(shù)據(jù)都自動復(fù)制到ADC_CvtValue中了。不能連續(xù)轉(zhuǎn)換。不知啥原因?
答1:ADC_DMARequestModeConfig(ADC1,ADC_DMAMode_Circular); 就好了。如果還有問題的話你看看 ChannelNumbers; 值是多少? ADC_CvtValue; 是數(shù)組?還有你開了中斷!要清除標(biāo)志位!
13、STM32 DAC 庫函數(shù)問題
問:在函數(shù)DAC_SetChannel1Data(u32 DAC_Align, u16 Data)中,第二個參數(shù)u16 Data是什么意思,怎么使用?
答:DATA就是你要發(fā)送的數(shù)據(jù),也就是DAC輸出的電壓值
14、一個關(guān)于STM32F103VCT6 ADC的線性度的測試
問:本人同事最近做的項目,發(fā)現(xiàn) STM32F103VCT6 ADC 測試出現(xiàn)了一個現(xiàn)象,線性度不好, 使用外部2.5V基準(zhǔn),調(diào)整10K電位器, ADC轉(zhuǎn)換在 3072 3584 3840 三個點線性度很不好, 電壓變化20mv,這三個點才會發(fā)生跳變,跳變不是ADC碼+-1,而是加減了幾十個ADCbit,我認為不是STM32內(nèi)部的硬件問題,而是應(yīng)用問題,不知道有人遇到過這種情況沒有? 從二進制碼來看,這三個數(shù)的第八位都是0
貼一張STM32 ADC性能參數(shù)圖,按理說STM32的ADC不至于我測試的這么差呀,是我們使用有問題嗎?
答:ADC測試的時候盡量保證電壓的穩(wěn)定,最好用放大器來將其分壓,而電阻分壓在溫度、電流、電壓不同的情況下會有偏差。
15、STM32的DAC轉(zhuǎn)換是什么開始的呢?
16、關(guān)于STM32F103RE的DAC個數(shù)問題
17、STM32F107的DAC例程都用TIMx更新啟動DMA2
最佳答案:
18、STM32如何與多個多通道ADC AD790進行配置
問:STM32F107VCT6如何與多個多通道ADC AD790進行SPI連接配置?謝謝各位大俠們
最佳答案:
通過AD790本身的控制,可以通過硬件來設(shè)置硬件地址。你可以詳細樂隊AD790的資料。
19、STM32F107可以帶多個外置式ADC嗎?如果可以最多可以帶多少個?
問:外置式ADC型號是AD7490的 16通道,SPI接口。因為總共有38路模擬量的,我想用三個外置ADC。另外我想問一下是不是可以只用一個SPI接口就可以連接三個外置ADC呢?如果可以怎么做片選呢?萬分感謝!
答:用其他3個IO做片選就可以
20、STM32F2 ADC
問:采樣時間越大采樣值就越精確嗎?ADC采樣周期可以是3、15、28、56、84、112、144、480. 最小的采樣時間是3個ADCCLK,最大的是480個ADCCLK,這個值是越大越好嗎?
答:ADC采用周期越大采集間隔越長,這個值越小采集越精確。 規(guī)則組 此模式通過設(shè)置ADC_CR1寄存器上的DISCEN位激活。它可以用來執(zhí)行一個短序列的n次轉(zhuǎn)換(n<=8),此轉(zhuǎn)換是ADC_SQRx寄存器所選擇的轉(zhuǎn)換序列的一部分。數(shù)值n由ADC_CR1寄存器的DISCNUM[2:0]位給出。 一個外部觸發(fā)信號可以啟動ADC_SQRx寄存器中描述的下一輪n次轉(zhuǎn)換,直到此序列所有的轉(zhuǎn)換完成為止。總的序列長度由ADC_SQR1寄存器的L[3:0]定義。 舉例: n=3,被轉(zhuǎn)換的通道 = 0、1、2、3、6、7、9、10 第一次觸發(fā):轉(zhuǎn)換的序列為 0、1、2 第二次觸發(fā):轉(zhuǎn)換的序列為 3、6、7 第三次觸發(fā):轉(zhuǎn)換的序列為 9、10,并產(chǎn)生EOC事件 第四次觸發(fā):轉(zhuǎn)換的序列 0、1、2 注入組 此模式通過設(shè)置ADC_CR1寄存器的JDISCEN位激活。在一個外部觸發(fā)事件后,該模式按通道順序逐個轉(zhuǎn)換ADC_JSQR寄存器中選擇的序列。 一個外部觸發(fā)信號可以啟動ADC_JSQR寄存器選擇的下一個通道序列的轉(zhuǎn)換,直到序列中所有的轉(zhuǎn)換完成為止。總的序列長度由ADC_JSQR寄存器的JL[1:0]位定義。 例子: n=1,被轉(zhuǎn)換的通道 = 1、2、3 第一次觸發(fā):通道1被轉(zhuǎn)換 第二次觸發(fā):通道2被轉(zhuǎn)換 第三次觸發(fā):通道3被轉(zhuǎn)換,并且產(chǎn)生EOC和JEOC事件 第四次觸發(fā):通道1被轉(zhuǎn)換
21、STM32的雙ADC操作模式有哪些?
問:STM32的雙ADC操作模式有哪些?
最佳答案:
快速交替模式:在一個通道上以連續(xù)方式的快速交替模式
慢速交替模式:在一個通道上以連續(xù)方式的快速交替模式
交替觸發(fā)模式:
同步模式:
交替觸發(fā)模式:
