查看: 130963|回復(fù): 339
別人的altium designer常用元件庫和封裝庫下載-非常全面初學(xué)者有福了
ID:168433 發(fā)表于 2017-3-6 00:06 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
本帖最后由 三分鐘熱度ooo 于 2017-3-6 00:13 編輯
http://m.raoushi.com/bbs/dpj-31103-1.html     原網(wǎng)址
1.
  我的元件庫\74LS595.LibPkg
  ..........\78穩(wěn)壓塊.SCHLIB
  ..........\8-8點陣.LibPkg
  ..........\8-8點陣.PcbLib
  ..........\8-8點陣.SchLib
  ..........\altium\PCB_lib\IC.PCBLIB
  ..........\......\.......\IC.PCBLIB.htm
  ..........\......\.......\jointbar.PCBLIB
  ..........\......\.......\jointbar.PCBLIB.htm
  ..........\......\.......\Miscellaneous Connectors.PcbLib
  ..........\......\.......\Miscellaneous Connectors.PcbLib.htm
  ..........\......\.......\photounit.PCBLIB
  ..........\......\.......\photounit.PCBLIB.htm
  ..........\......\.......\RCDQLY.PCBLIB
  ..........\......\.......\RCDQLY.PCBLIB.htm
  ..........\......\.......\rest.PCBLIB
  ..........\......\.......\rest.PCBLIB.htm
  ..........\......\.......\常用元件封裝.PCBLIB
  ..........\......\.......\常用元件封裝.PCBLIB.htm
  ..........\......\.......\常用元件封裝庫(pcb).PCBLIB
  ..........\......\.......\常用元件封裝庫(pcb).PCBLIB.htm
  ..........\......\SCH_lib\CD4000系列IC.SCHLIB
  ..........\......\.......\CMOS&TTL74.SCHLIB
  ..........\......\.......\IC.SCHLIB
  ..........\......\.......\Miscellaneous Devices.SCHLIB
  ..........\......\.......\MyInt_Lib.LIBPKG
  ..........\......\.......\photounit.SCHLIB
  ..........\......\.......\RCDQLY.SCHLIB
  ..........\......\.......\rest.SCHLIB
  ..........\......\.......\TTL74系列IC.SCHLIB
  ..........\......\.......\二極管.SCHLIB
  ..........\......\.......\單片機及相關(guān).SCHLIB
  ..........\......\.......\場效應(yīng)管及可控硅.SCHLIB
  ..........\......\.......\聲亮元件.SCHLIB
  ..........\......\.......\常用元件庫.SCHLIB
  ..........\......\.......\開關(guān).SCHLIB
  ..........\......\.......\感應(yīng)元件.SCHLIB
  ..........\......\.......\接口與插座.SCHLIB
  ..........\......\.......\插件.SCHLIB
  ..........\......\.......\數(shù)字符號.SCHLIB
  ..........\......\.......\雜元件庫.SCHLIB
  ..........\......\.......\模擬符號.SCHLIB
  ..........\......\.......\模擬集成電路.SCHLIB
  ..........\......\.......\電容.SCHLIB
  ..........\......\.......\電源.SCHLIB
  ..........\......\.......\電阻.SCHLIB
  ..........\......\.......\繼電器類元件.SCHLIB
  ..........\CD4000系列IC.SCHLIB
  ..........\Composite Drawing.pdf
  ..........\DIP-16.LibPkg
  ..........\DIP-16.PcbLib
  ..........\DIP-16.SchLib
  ..........\Final Artwork Prints.pdf
  ..........\GT_PCB\專用A.PcbLib
  ..........\......\專用B.PcbLib
  ..........\......\專用C.PcbLib
  ..........\......\劉強PCB.PcbLib
  ..........\...SCH\ARM.SchLib
  ..........\......\劉強SCH.SchLib
  ..........\......\常用1.SchLib
  ..........\......\常用2.SchLib
  ..........\......\模塊\51單片機.SchLib
  ..........\......\....\555.SchLib
  ..........\......\....\74HC164.SchLib
  ..........\......\....\74HC595.SchLib
  ..........\......\....\AD7416.SchLib
  ..........\......\....\AD轉(zhuǎn)換器件.SchLib
  ..........\......\....\AVR單片機.SchLib
  ..........\......\....\BIS0001.SchLib
  ..........\......\....\C8051Fx.SchLib
  ..........\......\....\CH375.SchLib
  ..........\......\....\CHXXXSCH.SchLib
  ..........\......\....\CMOS系列.SchLib
  ..........\......\....\HT單片機.SchLib
  ..........\......\....\ICD2.SchLib
  ..........\......\....\MSP430.SchLib
  ..........\......\....\PIC單片機.SchLib
  ..........\......\....\SLE4442.SchLib
  ..........\......\....\TMS320f2812.SchLib
  ..........\......\....\TTL74系列.SchLib
  ..........\......\....\中央處理器.SchLib
  ..........\......\....\傳感器.SchLib
  ..........\......\....\光電器件.SchLib
  ..........\......\....\變壓器.SchLib
  ..........\......\....\可控硅.SchLib
  ..........\......\....\場效應(yīng)管.SchLib
  ..........\......\....\存儲器.SchLib
  ..........\......\....\接口器件.SchLib
  ..........\......\....\數(shù)碼管.SchLib
  ..........\......\....\時鐘芯片.SchLib
  ..........\......\....\模擬器件.SchLib
  ..........\......\....\液晶.SchLib
  ..........\......\....\電子管.SchLib
  ..........\......\....\電控開關(guān).SchLib
  ..........\......\....\穩(wěn)壓器件.SchLib
  ..........\......\....\語音芯片.SchLib
  ..........\History\8-8點陣.~(1).LibPkg.Zip
  ..........\.......\8-8點陣.~(1).PcbLib.Zip
  ..........\.......\8-8點陣.~(1).SchLib.Zip
  ..........\.......\8-8點陣.~(2).LibPkg.Zip
庫文件1下載: Altium-Designer-PCB.rar (2.63 MB, 下載次數(shù): 10359)
----------------------------------我是分隔線-------------------------------------------------------
下面是另一個我收藏的更全面的庫
AD元件庫
.....\AD庫
.....\....\單片機8051.IntLib
.....\....\我的 封裝
.....\....\....\AD轉(zhuǎn)換.lib
.....\....\....\CMOS系列.Lib
.....\....\....\IC.SCHLIB
.....\....\....\TTL74系列IC.SCHLIB
.....\....\....\中央處理器.lib
.....\....\....\元件
.....\....\....\...\4000 CMOS.SchLib
.....\....\....\...\4位共陽極數(shù)碼管.SchLib
.....\....\....\...\74xxTTL.SchLib
.....\....\....\...\CPU.SchLib
.....\....\....\...\CRY晶振.SchLib
.....\....\....\...\C電容.SchLib
.....\....\....\...\DIODE.SchLib
.....\....\....\...\D硅堆.SchLib
.....\....\....\...\J繼電器.SchLib
.....\....\....\...\LCD顯示.SchLib
.....\....\....\...\LED數(shù)碼管.SchLib
.....\....\....\...\Linear.SchLib
.....\....\....\...\LM317-337....SchLib
.....\....\....\...\L電感.SchLib
.....\....\....\...\OpAmp比較器.SchLib
.....\....\....\...\Operational 運放.SchLib
.....\....\....\...\OP光耦.SchLib
.....\....\....\...\ORDER其它.SchLib
.....\....\....\...\R電阻.SchLib
.....\....\....\...\Schematic Linear集成芯片.SchLib
.....\....\....\...\Schlib2.SchLib
.....\....\....\...\SCR單向可控硅.SchLib
.....\....\....\...\SW開關(guān).SchLib
.....\....\....\...\TRIAC雙向可控硅.SchLib
.....\....\....\...\T變壓器.SchLib
.....\....\....\...\USB.SchLib
.....\....\....\...\V三極管.SchLib
.....\....\....\...\功放IC.SchLib
.....\....\....\...\常用IC.SchLib
.....\....\....\...\開關(guān).SchLib
.....\....\....\...\接口.SchLib
.....\....\....\...\接觸器.SchLib
.....\....\....\...\電機驅(qū)動.SchLib
.....\....\....\...\電阻.SchLib
.....\....\....\...\穩(wěn)壓管.SchLib
.....\....\....\...\集成塊.SchLib
.....\....\....\單片機及相關(guān).SCHLIB
.....\....\....\變壓器.lib
.....\....\....\可控硅.Lib
.....\....\....\場效應(yīng)管.LIB
.....\....\....\封裝
.....\....\...\LM317-337封裝.PcbLib
.....\....\...\PCB Footprints.PcbLib
.....\....\...\PCBLIB2.PcbLib
.....\....\...\三極管.PcbLib
.....\....\...\二極管.PcbLib
.....\....\...\共陽極LED.PcbLib
.....\....\...\變壓器.PcbLib
.....\....\...\可調(diào)電阻.PcbLib
.....\....\...\常用...封裝庫(pcb).PCBLIB
.....\....\...\開關(guān).PcbLib
.....\....\...\接頭-功率型插座.PcbLib
.....\....\...\插座.PcbLib
.....\....\...\數(shù)碼管.PcbLib
.....\....\...\晶振.PcbLib
.....\....\...\液晶顯示器.PcbLib
.....\....\...\電子管.PcbLib
.....\....\...\電感.PcbLib
.....\....\...\硅堆.PcbLib
.....\....\...\繼電器.PcbLib
.....\....\...\蜂鳴器.PcbLib
.....\....\...\貼片-DIP轉(zhuǎn)換.PcbLib
.....\....\...\貼片.PcbLib
.....\....\...\阻容.PcbLib
.....\....\...\集成塊.PcbLib
.....\....\....\常用器件.SCHLIB
.....\....\....\數(shù)碼管光耦.SCHLIB
.....\....\....\雜元件庫.lib
.....\....\....\模擬器件.lib
.....\....\....\電子管.LIB
.....\....\....\電控開關(guān).Lib
庫文件2下載: AD常用元件封裝庫.zip (7.05 MB, 下載次數(shù): 3369)
參與人數(shù) 23黑幣 +90 收起 理由
dnsam + 5 很給力!
ckwx123456 + 3 很給力!
stu + 5 共享資料的黑幣獎勵!
hhhlllbbb + 5 很給力!
466167790 + 5 很給力!
hnhkccdyx + 1 贊一個!
zrz111 + 4 很給力!
一世琉璃白 + 5 很給力!
takeafail + 5 很給力!
a1048495714 + 5 共享資料的黑幣獎勵!
76412464 + 1 很給力!
qq383570990 + 4 很給力!
swdsmy + 4 很給力!
zk333 + 3 絕世好帖!
feng005 + 5 共享資料的黑幣獎勵!
drymango + 1 絕世好帖!
劉玉清上 + 5 回帖助人的獎勵!
zlnseu + 5 很給力!
angelboygo3 + 5 贊一個!
X927048000 + 5 回帖助人的獎勵!
guanggong + 5 回帖助人的獎勵!
Hope時代 + 1 很給力!
娛樂天空 + 3 很給力!
收藏收藏29 分享淘帖 頂23 踩
ID:170143 發(fā)表于 2017-3-12 19:35 | 只看該作者
很好,好東西,很全面
ID:124911 發(fā)表于 2017-3-21 21:29 | 只看該作者
這個真的不錯很有用
ID:188301 發(fā)表于 2017-4-13 21:49 | 只看該作者
樓主可以做個朋友嗎?
ID:189667 發(fā)表于 2017-4-14 21:21 | 只看該作者
多謝樓主分享
ID:189940 發(fā)表于 2017-4-15 20:06 | 只看該作者
好東西,頂一個
ID:191665 發(fā)表于 2017-4-20 16:12 | 只看該作者
為啥下載不了,直接說出錯了啊~
ID:193475 發(fā)表于 2017-4-25 17:13 | 只看該作者
很好,東西很全
ID:193262 發(fā)表于 2017-4-25 21:56 | 只看該作者
我又來了 東西很好
ID:193630 發(fā)表于 2017-4-25 22:00 | 只看該作者
好東西大家分享
ID:195306 發(fā)表于 2017-5-1 17:25 | 只看該作者
謝謝謝謝
ID:194759 發(fā)表于 2017-5-2 19:08 | 只看該作者
好東西大家分享
ID:194700 發(fā)表于 2017-5-5 20:21 | 只看該作者
多謝樓主分享
ID:197334 發(fā)表于 2017-5-6 15:10 | 只看該作者
感謝樓主分享
ID:197334 發(fā)表于 2017-5-6 15:11 | 只看該作者
多謝分享!!
ID:168697 發(fā)表于 2017-5-7 17:03 來自觸屏版 | 只看該作者
贊一個
ID:137511 發(fā)表于 2017-5-24 20:25 | 只看該作者
謝謝 樓主分享~好多元件  都要自己一個一個創(chuàng)建 好麻煩啊~
ID:137511 發(fā)表于 2017-5-24 20:26 | 只看該作者
謝謝樓主分享啊  元件庫很的元件有沒有啊 ~~
ID:204574 發(fā)表于 2017-5-25 03:31 | 只看該作者
謝謝分享
ID:205567 發(fā)表于 2017-5-28 10:21 | 只看該作者
太感謝樓主了,在做彩燈的實驗,正愁找不到器件,謝謝!!!
ID:199744 發(fā)表于 2017-5-30 08:44 | 只看該作者
謝謝樓主大哥分享!!
ID:208555 發(fā)表于 2017-6-6 20:34 | 只看該作者
好給力啊
ID:212567 發(fā)表于 2017-6-19 14:02 | 只看該作者
好東西~~感謝樓主分享
ID:205199 發(fā)表于 2017-6-30 08:48 | 只看該作者
有沒STM的
ID:190995 發(fā)表于 2017-7-19 23:33 | 只看該作者
謝謝!受用了
ID:230546 發(fā)表于 2017-9-2 12:58 | 只看該作者
十分感謝!!!
ID:237262 發(fā)表于 2017-10-4 18:47 | 只看該作者
謝謝樓主分享
ID:237262 發(fā)表于 2017-10-4 18:48 | 只看該作者
Thanks
ID:239368 發(fā)表于 2017-10-14 13:23 | 只看該作者
我好像下載不了
ID:240085 發(fā)表于 2017-10-16 22:13 | 只看該作者
謝謝樓主分享
ID:77669 發(fā)表于 2017-10-18 10:02 | 只看該作者
好東西,謝謝分享
ID:164340 發(fā)表于 2017-10-20 20:11 | 只看該作者
太給力了,太棒了,非常感謝樓主
ID:220046 發(fā)表于 2017-10-22 13:14 | 只看該作者
樓主超級棒!!
ID:243141 發(fā)表于 2017-10-26 15:06 | 只看該作者
非常感謝
ID:247653 發(fā)表于 2017-11-9 12:41 | 只看該作者
很強,拿走謝謝了
ID:247653 發(fā)表于 2017-11-9 12:42 | 只看該作者
這個資源很好
ID:248489 發(fā)表于 2017-11-11 22:31 | 只看該作者
樓主黑幣不夠啊
ID:248581 發(fā)表于 2017-11-12 13:04 | 只看該作者
很全面,謝謝
ID:248659 發(fā)表于 2017-11-12 17:31 | 只看該作者
看到好東西了
ID:249388 發(fā)表于 2017-11-14 16:59 | 只看該作者
謝謝樓主分享,正迫切需要。
