1. 加法:四位整數加法計算結果若超過八位則顯示計算錯誤
2. 減法:四位整數減法計算結果若超過八位則顯示計算錯誤
3. 乘法:多位整數乘法計算結果若超過四位則顯示計算錯誤
4. 除法:整數除法 5. 有清除功能
[code]#include<reg52.h>
uchar code num[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x00,0x40};//共陰極
// 0 1 2 3 4 5 6 7 8 9 熄滅 -
uchar code loc[]={0xff,0xfe,0xfd,0xfb,0xf7};
uchar code ero[]={0x79,0x50,0x5c};
uchar code www[]={0x71};
uint n=0,n1=0,n2=0; //賦初值
uchar flag=0; //計算類型選擇關鍵字
void delay(int t);
void display(int n);
void error();
main()
uchar temp;
//第一行檢測
P3=0xfe;
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
delay(10);
temp=P3;
temp=temp&0xfe;
if(temp!=0xfe)
temp=P3;
switch(temp)
case 0xee:n1=0;n2=0;n=0;flag=0;break; //清零
case 0xde:n1=10*n1+0;n=n1;break; //0
case 0xbe: if(flag==1)n=n2+n1; //=
if(flag==2)n=n2-n1;
if(flag==3)n=n2*n1;
if(flag==4)n=n2/n1;
n1=0;
break;
case 0x7e: // +
n2=n1;n1=0;
flag=1;break;
while(temp!=0xf0)
temp=P3;
temp=temp&0xf0;
//掃描第二行
P3=0xfd;
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
delay(10);
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
temp=P3;
switch(temp)
case 0xed:n1=10*n1+1;n=n1;break; //4
case 0xdd:n1=10*n1+2;n=n1;break; //5
case 0xbd:n1=10*n1+3;n=n1;break; //6
case 0x7d:// -
n2=n1;n1=0;
flag=2;break;
while(temp!=0xf0)
temp=P3;
temp=temp&0xf0;
//掃描第三行
P3=0xfb;
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
delay(10);
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
temp=P3;
switch(temp)
case 0xeb:n1=10*n1+4;n=n1;break;
case 0xdb:n1=10*n1+5;n=n1;break;
case 0xbb:n1=10*n1+6;n=n1;break;
case 0x7b: // * n2=n1;n1=0;
flag=3;break;
while(temp!=0xf0)
temp=P3;
temp=temp&0xf0;
//掃描第四行
P3=0xf7;
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
delay(10);
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
temp=P3;
switch(temp)
case 0xe7:n1=10*n1+7;n=n1;break; //7
case 0xd7:n1=10*n1+8;n=n1;break; //8
case 0xb7:n1=10*n1+9;n=n1;break; //9
case 0x77: // /
n2=n1;n1=0;
flag=4;break;
while(temp!=0xf0)
temp=P3;
temp=temp&0xf0;
display(n);
//延時函數
void delay(int t)
int x,y;
for(x=0;x<t;x++)
for(y=0;y<t;y++);
//數碼管顯示
void display(int n)
//溢出處理
uchar g,s,b,q;
int abs;
if((n>9999)||(n<-999))
error();
//正數
if((n>=0)&&(n<=9999))
g=n%10;
s=n/10%10;
b=n/100%10;
q=n/1000%10;
P0=num[g];
delay(5);
P2=loc[4];
delay(2);
P2=loc[0];
delay(3);
if(n>=10)
P0=num[s];
P2=loc[3];
delay(2);
P2=loc[0];
delay(3);
if(n>=100)
P0=num[b];
P2=loc[2];
delay(2);
P2=loc[0];
delay(3);
if(n>=1000)
P0=num[q];
P2=loc[1];
delay(2);
P2=loc[0];
delay(3);
//負數
if((n<0)&&(n>=-999))
abs=-n;
g=abs%10;
s=abs/10%10;
b=abs/100%10;
q=abs/1000%10;
P0=num[g];
P2=loc[4];
delay(2);
P2=loc[0];
delay(2);
if((abs/10%10>0)||(abs/100%10>0))
P0=num[s];
P2=loc[3];;
delay(2);
P2=loc[0];
delay(2);
if((abs/100%10>0))
P0=num[b];
P2=loc[2];
delay(2);
P2=loc[0];
delay(2);
if((abs/1000%10>0))
P0=num[q];
P2=loc[1];
delay(2);
P2=loc[0];
delay(2);
P0=num[11];
P2=loc[1];
delay(2);
P2=loc[0];
delay(2);
P0=num[11];
P2=loc[2];
delay(2);
P2=loc[0];
delay(2);
P0=num[11];
P2=loc[3];
delay(2);
P2=loc[0];
delay(2);
//溢出顯示
void error()
P2=loc[4];
P0=www[0];
delay(2);
P2=loc[0];
delay(3);
[/code]
