#include <reg52.h>
unsigned char step = 0; //操作步驟
unsigned char oprt = 0; //運(yùn)算類(lèi)型
signed long num1 = 0; //操作數(shù)1
signed long num2 = 0; //操作數(shù)2
signed long result = 0; //運(yùn)算結(jié)果
unsigned char T0RH = 0; //T0重載值的高字節(jié)
unsigned char T0RL = 0; //T0重載值的低字節(jié)
void ConfigTimer0(unsigned int ms);
extern void KeyScan();
extern void KeyDriver();
extern void InitLcd1602();
extern void LcdShowStr(unsigned char x, unsigned char y, unsigned char *str);
extern void LcdAreaClear(unsigned char x, unsigned char y, unsigned char len);
extern void LcdFullClear();
EA = 1; //開(kāi)總中斷
ConfigTimer0(1); //配置T0定時(shí)1ms
InitLcd1602(); //初始化液晶
LcdShowStr(15, 1, "0"); //初始顯示一個(gè)數(shù)字0
while (1)
KeyDriver(); //調(diào)用按鍵驅(qū)動(dòng)
/* 長(zhǎng)整型數(shù)轉(zhuǎn)換為字符串,str-字符串指針,dat-待轉(zhuǎn)換數(shù),返回值-字符串長(zhǎng)度 */
unsigned char LongToString(unsigned char *str, signed long dat)
signed char i = 0;
unsigned char len = 0;
unsigned char buf[12];
if (dat < 0) //如果為負(fù)數(shù),首先取絕對(duì)值,并在指針上添加負(fù)號(hào)
dat = -dat;
*str++ = '-';
len++;
do { //先轉(zhuǎn)換為低位在前的十進(jìn)制數(shù)組
buf[i++] = dat % 10;
dat /= 10;
} while (dat > 0);
len += i; //i最后的值就是有效字符的個(gè)數(shù)
while (i-- > 0) //將數(shù)組值轉(zhuǎn)換為ASCII碼反向拷貝到接收指針上
*str++ = buf[i] + '0';
*str = '\0'; //添加字符串結(jié)束符
return len; //返回字符串長(zhǎng)度
/* 顯示運(yùn)算符,顯示位置y,運(yùn)算符類(lèi)型type */
void ShowOprt(unsigned char y, unsigned char type)
switch (type)
case 0: LcdShowStr(0, y, "+"); break; //0代表+
case 1: LcdShowStr(0, y, "-"); break; //1代表-
case 2: LcdShowStr(0, y, "*"); break; //2代表*
case 3: LcdShowStr(0, y, "/"); break; //3代表/
default: break;
/* 計(jì)算器復(fù)位,清零變量值,清除屏幕顯示 */
void Reset()
num1 = 0;
num2 = 0;
step = 0;
LcdFullClear();
/* 數(shù)字鍵動(dòng)作函數(shù),n-按鍵輸入的數(shù)值 */
void NumKeyAction(unsigned char n)
unsigned char len;
unsigned char str[12];
if (step > 1) //如計(jì)算已完成,則重新開(kāi)始新的計(jì)算
Reset();
if (step == 0) //輸入第一操作數(shù)
num1 = num1*10 + n; //輸入數(shù)值累加到原操作數(shù)上
len = LongToString(str, num1); //新數(shù)值轉(zhuǎn)換為字符串
LcdShowStr(16-len, 1, str); //顯示到液晶第二行上
else //輸入第二操作數(shù)
num2 = num2*10 + n; //輸入數(shù)值累加到原操作數(shù)上
len = LongToString(str, num2); //新數(shù)值轉(zhuǎn)換為字符串
/* 運(yùn)算符按鍵動(dòng)作函數(shù),運(yùn)算符類(lèi)型type */
void OprtKeyAction(unsigned char type)
unsigned char len;
if (step == 0) //第二操作數(shù)尚未輸入時(shí)響應(yīng),即不支持連續(xù)操作
len = LongToString(str, num1); //第一操作數(shù)轉(zhuǎn)換為字符串
LcdAreaClear(0, 0, 16-len); //清除第一行左邊的字符位
LcdShowStr(16-len, 0, str); //字符串靠右顯示在第一行
ShowOprt(1, type); //在第二行顯示操作符
LcdAreaClear(1, 1, 14); //清除第二行中間的字符位
LcdShowStr(15, 1, "0"); //在第二行最右端顯示0
oprt = type; //記錄操作類(lèi)型
step = 1;
/* 計(jì)算結(jié)果函數(shù) */
void GetResult()
unsigned char len;
if (step == 1) //第二操作數(shù)已輸入時(shí)才執(zhí)行計(jì)算
step = 2;
switch (oprt) //根據(jù)運(yùn)算符類(lèi)型計(jì)算結(jié)果,未考慮溢出問(wèn)題
case 0: result = num1 + num2; break;
case 1: result = num1 - num2; break;
case 2: result = num1 * num2; break;
case 3: result = num1 / num2; break;
default: break;
len = LongToString(str, num2); //原第二操作數(shù)和運(yùn)算符顯示到第一行
ShowOprt(0, oprt);
LcdAreaClear(1, 0, 16-1-len);
len = LongToString(str, result); //計(jì)算結(jié)果和等號(hào)顯示在第二行
LcdShowStr(0, 1, "=");
LcdAreaClear(1, 1, 16-1-len);
/* 按鍵動(dòng)作函數(shù),根據(jù)鍵碼執(zhí)行相應(yīng)的操作,keycode-按鍵鍵碼 */
void KeyAction(unsigned char keycode)
if ((keycode>='0') && (keycode<='9')) //輸入字符
NumKeyAction(keycode - '0');
else if (keycode == 0x26) //向上鍵,+
OprtKeyAction(0);
else if (keycode == 0x28) //向下鍵,-
OprtKeyAction(1);
else if (keycode == 0x25) //向左鍵,*
OprtKeyAction(2);
else if (keycode == 0x27) //向右鍵,÷
OprtKeyAction(3);
else if (keycode == 0x0D) //回車(chē)鍵,計(jì)算結(jié)果
GetResult();
else if (keycode == 0x1B) //Esc鍵,清除
Reset();
/* 配置并啟動(dòng)T0,ms-T0定時(shí)時(shí)間 */
unsigned long tmp; //臨時(shí)變量
tmp = 11059200 / 12; //定時(shí)器計(jì)數(shù)頻率
tmp = (tmp * ms) / 1000; //計(jì)算所需的計(jì)數(shù)值
tmp = 65536 - tmp; //計(jì)算定時(shí)器重載值
tmp = tmp + 28; //補(bǔ)償中斷響應(yīng)延時(shí)造成的誤差
T0RH = (unsigned char)(tmp>>8); //定時(shí)器重載值拆分為高低字節(jié)
T0RL = (unsigned char)tmp;
TMOD &= 0xF0; //清零T0的控制位
TMOD |= 0x01; //配置T0為模式1
TH0 = T0RH; //加載T0重載值
TL0 = T0RL;
ET0 = 1; //使能T0中斷
TR0 = 1; //啟動(dòng)T0
/* T0中斷服務(wù)函數(shù),執(zhí)行按鍵掃描 */
void InterruptTimer0() interrupt 1
TH0 = T0RH; //重新加載重載值
TL0 = T0RL;
KeyScan(); //按鍵掃描
