查看: 4479|回復(fù): 4
求助利用STC12C5A60S2內(nèi)部PWM控制頻率和占空比! 并且頻率可調(diào)!
ID:51533 發(fā)表于 2017-1-13 13:45 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
ID:160895 發(fā)表于 2017-1-13 15:48 | 只看該作者
這是官方提供的程序
你可以看看
就是設(shè)置寄存器的參數(shù)
/* --- STC MCU Limited ---------------------------------------------*/
/* --- STC12C5Axx Series MCU PCA module output PWM wave Demo -------*/
/* --- Mobile: (86)13922805190 -------------------------------------*/
/* --- Fax: 86-0513-55012956,55012947,55012969 ---------------------*/
/* --- Tel: 86-0513-55012928,55012929,55012966----------------------*/
/* If you want to use the program or the program referenced in the  */
/* article, please specify in which data and procedures from STC    */
#include "reg51.h"
#include "intrins.h"
#define FOSC    11059200L
typedef unsigned char BYTE;
typedef unsigned int WORD;
/*Declare SFR associated with the PCA */
sfr CCON        =   0xD8;           //PCA control register
sbit CCF0       =   CCON^0;         //PCA module-0 interrupt flag
sbit CCF1       =   CCON^1;         //PCA module-1 interrupt flag
sbit CR         =   CCON^6;         //PCA timer run control bit
sbit CF         =   CCON^7;         //PCA timer overflow flag
sfr CMOD        =   0xD9;           //PCA mode register
sfr CL          =   0xE9;           //PCA base timer LOW
sfr CH          =   0xF9;           //PCA base timer HIGH
sfr CCAPM0      =   0xDA;           //PCA module-0 mode register
sfr CCAP0L      =   0xEA;           //PCA module-0 capture register LOW
sfr CCAP0H      =   0xFA;           //PCA module-0 capture register HIGH
sfr CCAPM1      =   0xDB;           //PCA module-1 mode register
sfr CCAP1L      =   0xEB;           //PCA module-1 capture register LOW
sfr CCAP1H      =   0xFB;           //PCA module-1 capture register HIGH
sfr PCAPWM0     =   0xf2;
sfr PCAPWM1     =   0xf3;
    CCON = 0;                       //Initial PCA control register
                                    //PCA timer stop running
                                    //Clear CF flag
                                    //Clear all module interrupt flag
    CL = 0;                         //Reset PCA base timer
    CH = 0;
    CMOD = 0x02;                    //Set PCA timer clock source as Fosc/2
                                    //Disable PCA timer overflow interrupt
    CCAP0H = CCAP0L = 0x80;         //PWM0 port output 50% duty cycle square wave
    CCAPM0 = 0x42;                  //PCA module-0 work in 8-bit PWM mode and no PCA interrupt
    CCAP1H = CCAP1L = 0xff;         //PWM1 port output 0% duty cycle square wave
    PCAPWM1 = 0x03;
    CCAPM1 = 0x42;                  //PCA module-1 work in 8-bit PWM mode and no PCA interrupt
    CR = 1;                         //PCA timer start run
    while (1);
ID:51533 發(fā)表于 2017-1-13 16:04 | 只看該作者
怎么沒人回復(fù)
ID:74784 發(fā)表于 2017-1-13 20:07 | 只看該作者
我這有一個是用AT89XX單片機(jī)的匯編代碼~~~~~~~~~~
ID:399179 發(fā)表于 2019-7-7 20:52 來自觸屏版 | 只看該作者
這個程序能用嗎
