查看: 3047|回復(fù): 0
單片機(jī)定時(shí)器和中斷實(shí)驗(yàn)
ID:152472 發(fā)表于 2016-12-13 22:08 | 顯示全部樓層 |閱讀模式
單片機(jī)實(shí)驗(yàn)三:
單片機(jī)實(shí)驗(yàn)三.rar (21.41 KB, 下載次數(shù): 12)
源程序:
  1. #include <REG52.h>
  2. #define uint unsigned int
  4. sbit L1=P1^2;
  5. sbit L2=P1^3;
  6. sbit L3=P1^4;
  7. sbit L4=P1^5;
  8. uchar high,E,F,G;
  9. void int0() interrupt 0 using 1
  10.                 {high=high+40;
  11.      E=E+30;
  12.                         F=F+35;
  13.                         G=G+20;}
  14.
  15. void int1() interrupt 0 using 2
  16.                         {high=high-20;
  17.      E=E-15;
  18.                         F=F-20;
  19.                         G=G-20;}
  20.
  21. void timer0isr(void) interrupt 1 using 1
  22. {
  23. {TH0=0xd8;
  24.         TL0=0xf0;
  25.         high++;
  26.         if(high==40)
  27.                 L1=0;
  28.         if(high==200)
  29.         {
  30.                 L1=1;
  31.                 high=0;
  32.   }}
  33.         {TH0=0xb1;
  34.         TL0=0xe0;
  35.                 E++;
  36.         if(E==20)
  37.                 L2=0;
  38.         if(E==100)
  39.         {
  40.                 L2=1;
  41.                 E=0;
  42.   }}
  43.         {TH0=0x63;
  44.         TL0=0xc0;
  45.                 G++;
  46.         if(G==25)
  47.                 L3=0;
  48.         if(G==50)
  49.         {
  50.                 L3=1;
  51.                 G=0;
  52.   }}
  53.         {TH0=0xd8;
  54.         TL0=0xf0;
  55.                 F++;
  56.         if(F==100)
  57.                 L4=0;
  58.         if(F==200)
  59.         {
  60.                 L4=1;
  61.                 F=0;
  62.     }
  63.   }
  64. }
  65.
  66. void main(void)
  67. {
  68.         high=0;
  69.         F=0;
  70.         TMOD=0x01;
  71.         L1=1;
  72.         L4=1;
  73.         TH0=0xd8;
  74.         TL0=0xf0;
  75.
  76.         E=0;
  77.         L2=1;
  78.         TH0=0xb1;
  79.         TL0=0xe0;
  80.
  81.         G=0;
  82.         L3=1;
  83.         TH0=0x63;
  84.         TL0=0xc0;
  85.         EX0=1;
  86.         IT0=0;
  87.         EX1=1;
  88.         IT1=0;
  89.         PX1=1;
  90.         EA=1;
  91.         ET0=1;
  92.         TR0=1;
  93.         while(1);
  94. }
評(píng)分
參與人數(shù) 1黑幣 +50 收起 理由
查看全部評(píng)分
相關(guān)帖子
