LCD12864無(wú)字庫(kù)液晶屏幕的proteus仿真原理圖:
單片機(jī)源程序預(yù)覽:
- 內(nèi)容:無(wú)字庫(kù)12864測(cè)試程序(縱向取模。字節(jié)倒序)
- 作者:QQ:1181826414
- 交流:http://m.raoushi.com/bbs/mcu-h24-1.html
- #include <reg52.h>
- #define uint unsigned int
- #define uchar unsigned char
- #define Disp_On 0x3f //顯示命令
- #define Disp_Off 0x3e //關(guān)閉命令
- #define Col_Add 0x40 //起始列地址
- #define Page_Add 0xb8 //起始頁(yè)地址
- #define Start_Line 0xc0 //起始行地址
- #define Lcd_Bus P0 //MCU P0<---> LCM
- sbit RS = P2^0; //RS=1時(shí)為數(shù)據(jù)操作,RS=0時(shí)為命令操作
- sbit RW = P2^1; //RW=1時(shí)為讀選通,RW=0時(shí)為寫選通
- sbit E = P2^2; //E下降沿時(shí),數(shù)據(jù)寫入驅(qū)動(dòng)器,E為高電平時(shí),數(shù)據(jù)被讀出
- sbit Mcs = P2^3; //Master chip E,右半屏-CS2
- sbit Scs = P2^4; //Slave chip E,左半屏-CS1
- sbit RST = P2^5; //液晶模塊復(fù)位控制管腳
- char code ce[] = {
- /*-- 文字: 測(cè) --*/
- /*-- 宋體12; 此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x高=16x16 --*/
- 0x08, 0x31, 0x86, 0x60, 0x00, 0xFE, 0x02, 0xF2, 0x02, 0xFE, 0x00, 0xF8, 0x00, 0x00, 0xFF, 0x00,
- 0x04, 0xFC, 0x03, 0x00, 0x80, 0x47, 0x30, 0x0F, 0x10, 0x67, 0x00, 0x07, 0x40, 0x80, 0x7F, 0x00
- char code shi[] = {
- /*-- 文字: 試 --*/
- 0x40, 0x42, 0xDC, 0x08, 0x00, 0x90, 0x90, 0x90, 0x90, 0x90, 0xFF, 0x10, 0x12, 0x1C, 0x10, 0x00,
- 0x00, 0x00, 0x7F, 0x20, 0x10, 0x20, 0x20, 0x1F, 0x10, 0x10, 0x01, 0x06, 0x18, 0x20, 0x78, 0x00
- char code kai[] = {
- /*-- 文字: 開(kāi) --*/
- 0x40, 0x42, 0x42, 0x42, 0x42, 0xFE, 0x42, 0x42, 0x42, 0x42, 0xFE, 0x42, 0x42, 0x42, 0x42, 0x00,
- 0x00, 0x40, 0x20, 0x10, 0x0C, 0x03, 0x00, 0x00, 0x00, 0x00, 0x7F, 0x00, 0x00, 0x00, 0x00, 0x00
- char code shi3[]= {
- /*-- 文字: 始 --*/
- 0x10, 0x90, 0x70, 0x1F, 0x12, 0xF0, 0x00, 0x20, 0x70, 0x28, 0x27, 0x22, 0x28, 0x70, 0x20, 0x00,
- 0x40, 0x21, 0x12, 0x0C, 0x06, 0x09, 0x30, 0x00, 0x7F, 0x21, 0x21, 0x21, 0x21, 0x7F, 0x00, 0x00
- char code wan[] = {
- /*-- 文字: 完 --*/
- 0x00, 0x90, 0x8C, 0xA4, 0xA4, 0xA4, 0xA5, 0xA6, 0xA4, 0xA4, 0xA4, 0xA4, 0x94, 0x8C, 0x04, 0x00,
- 0x00, 0x80, 0x40, 0x20, 0x18, 0x07, 0x00, 0x00, 0x00, 0x3F, 0x40, 0x40, 0x40, 0x70, 0x00, 0x00
- char code bi[] = {
- /*-- 文字: 畢 --*/
- 0x00, 0x00, 0xFF, 0x88, 0x48, 0x28, 0x08, 0x80, 0x7F, 0x88, 0x88, 0x88, 0x84, 0x84, 0xE0, 0x00,
- 0x04, 0x04, 0x04, 0x04, 0x04, 0x04, 0x04, 0xFF, 0x04, 0x04, 0x04, 0x04, 0x04, 0x04, 0x04, 0x00
- uchar code FirstPage[] =
- /*-- 調(diào)入了一幅圖像:C:\Users\Administrator\Desktop\無(wú)標(biāo)題.bmp --*/
- /*-- 寬度x高度=128x64 --*/
- 0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x80,0x80,0x80,0xC0,0xC0,0xC0,0xC0,0x80,0x80,0x80,0xC0,0xC0,0xC0,0xC0,
- 0x00,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0x80,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,
- 0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF0,0xF8,0xFC,
- 0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,
- 0x3F,0x7F,0x7F,0x7F,0xFF,0xFF,0xFE,0xFC,0xF8,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFB,0xF9,0xE0,0xFE,0xFC,0xFC,0xFC,0xE0,0xFC,
- 0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF9,
- 0xC6,0x1F,0x1F,0x7D,0x7F,0x00,0x0F,0x0E,0x02,0xFD,0xBF,0xFF,0xFF,0xFF,0xFF,0xFF,
- 0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,
- 0xFF,0xFD,0xE8,0xE0,0xE0,0xC0,0xC0,0x00,0x00,0x00,0x00,0x80,0xC0,0xC0,0xC0,0xC0,
- 0xE0,0xC0,0xC0,0xE0,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,
- 0xF9,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xEF,0xFF,0xFB,0xFE,0xFF,0xFF,
- 0xFF,0xFF,0xFF,0xFF,0xBF,0x3F,0xFF,0xFD,0xFD,0x8F,0x9D,0x3F,0x17,0xFF,0xFF,0xFF,
- 0xFD,0xF8,0xF0,0xC0,0x80,0x03,0x07,0x80,0xFA,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
- 0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC7,0xFF,0xFF,0x0F,
- 0x1F,0x3F,0x3F,0x6F,0x3F,0x8D,0xFF,0xFF,0x2E,0x00,0x00,0x1F,0x3F,0x6F,0x6F,0x2F,
- 0x3D,0x1D,0x0B,0x08,0x01,0x0F,0xFF,0xFF,0xEF,0xFF,0xFC,0x18,0x00,0x00,0x00,0x00,
- 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
- 0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0xFF,0xFF,0xDF,0xDF,0xC7,0xE0,0xFA,0xFF,0xFF,0xFF,
- 0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFC,0xFC,0xF7,0x0F,0xE7,0xFF,0xFF,0xFF,0xFF,0xFF,
- 0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xFF,0xFF,
- 0xFC,0xB0,0xC0,0xC0,0xE6,0xFF,0xFF,0xFF,0xFC,0xFC,0xFC,0xDC,0xC0,0xC0,0x80,0x80,
- 0x00,0x00,0x00,0x00,0x00,0xE2,0xFF,0x3F,0x3F,0x1F,0x03,0x00,0x00,0x00,0x00,0x00,
- 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0x7F,0xFF,0xFF,0x7F,0xFF,0xDF,0x9F,
- 0x3E,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xDF,0xFF,0xF9,0xFC,0xFF,0xFF,0xFF,0xFE,0xF9,
- 0xFB,0x77,0xFF,0xFF,0xEF,0xEF,0xFF,0xDF,0x80,0xE0,0xF3,0xFF,0xFF,0xFF,0xFF,0xFF,
- 0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,
- 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xEF,0xEF,0xEF,0xCF,0xCF,0x83,0x83,0xC3,0xC7,0xE7,
- 0x60,0x60,0x30,0xD8,0x7E,0xE3,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x03,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x04,0x07,0x02,0x02,0x01,
- 0x03,0x06,0x00,0x01,0x03,0x03,0x03,0x03,0x07,0x07,0x01,0x01,0x03,0x07,0x05,0x01,
- 0x06,0x06,0x01,0x07,0x07,0x07,0x03,0x06,0x07,0x05,0x07,0x07,0x07,0x07,0x07,0x07,
- 0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1C,0x3F,
- 0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0xFF,0xFF,0xFB,0xFF,0xFF,0xF6,
- 0x7E,0x32,0x1B,0x1F,0x87,0xFF,0x3C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x01,0x03,0x07,0x0F,0x0F,0x0F,0x1B,0x1F,0x1F,0x1F,0x1F,0x3F,0x3F,0x1B,
- 0x0C,0x0C,0x06,0x07,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- /*---------------------延時(shí)子程序----------------------------*/
- void delay(unsigned int t)
- unsigned int i, j;
- for (i = 0;i < t;i++)
- for (j = 0;j < 10;j++)
- /*--------------------讀忙碌子程序---------------------------*/
- void Read_busy()
- P0 = 0x00;
- RS = 0;
- RW = 1;
- E = 1;
- while(P0&0x80);
- E = 0;
- /*--------------------寫命令到LCD----------------------------*/
- void write_com(unsigned char cmdcode)
- Read_busy(); //每次讀寫都要判斷是否忙碌
- RS = 0;
- RW = 0;
- Lcd_Bus = cmdcode;
- delay(0);
- E = 1;
- delay(0);
- E = 0;
- /*-------------------寫數(shù)據(jù)到LCD----------------------------*/
- void write_data(unsigned char Dispdata)
- RS = 1;
- RW = 0;
- Lcd_Bus = Dispdata;
- delay(0);
- E = 1;
- delay(0);
- E = 0;
- /*------------------顯示邊框-------------------------------*/
- void frame()
- unsigned char i;
- Mcs = 0; //兩個(gè)屏幕
- Scs = 0;
- write_com(Page_Add + 0); //上面橫線
- write_com(Col_Add + 0);
- for (i = 0;i < 64;i++) write_data(0x01);
- write_com(Page_Add + 7); //下面橫線
- for (i = 0;i < 64;i++) write_data(0x80);
- for (i = 0;i < 8;i++)
- Mcs = 0; //右半屏
- Scs = 1;
- write_com(Page_Add + i); //共8頁(yè)
- write_com(Col_Add + 63); //最后一列
- write_data(0xff); //ff表示每頁(yè)的8行全亮
- Mcs = 1; //左半屏與右半屏類似
- Scs = 0;
- write_data(0xff);
- /*---------------------------清除內(nèi)存--------------------------------*/
- void Clr_Scr()
- unsigned char j, k;
- for (k=0;k<8;k++)
- Mcs = 1;Scs = 0;delay(10); //左半屏清屏
- write_com(Page_Add + k);
- for (j = 0;j < 64;j++) write_data(0x00);
- Mcs = 0;Scs = 1; delay(10); //右半屏清屏
- for (j = 64;j < 128;j++) write_data(0x00);
- /*------------------顯示12864圖片---------------------------*/
- void Disp_Img(unsigned char code *img)
- for (k = 0;k < 8;k++) //共8頁(yè)
- Mcs = 1;Scs = 0;delay(10); //左半屏數(shù)據(jù)
- for (j = 0;j < 64;j++) write_data(img[k*128 + j]); //每半塊屏共64列
- Mcs = 0;Scs = 1; delay(10); //右半屏數(shù)據(jù)
- for (j = 64;j < 128;j++) write_data(img[k*128 + j]);
- /*-------------------------顯示橫---------------------------*/
- void Disp_H_Line()
- unsigned char i, j;
- Mcs = 0;
- Scs = 0;
- write_com(Disp_On); //顯示開(kāi)
- write_com(Page_Add); //頁(yè)地址
- write_com(Start_Line); //開(kāi)始行
- write_com(Col_Add); //列地址
- for (j = 0;j < 8;j++) //共8頁(yè),所以循環(huán)8次
- write_com(Page_Add + j);
- write_com(Col_Add + 0); //第一列開(kāi)始
- write_com(Start_Line+0); //第一行開(kāi)始
- for (i = 0;i < 64;i++)write_data(0x55); //每半屏幕共64列
- /*------------------------顯示列-----------------------------*/
- void Disp_V_Line()
- write_com(Start_Line); //列地址
- write_com(Start_Line + 0);
- for (i = 0;i < 32;i++) //64列,寫兩次,一列空白,一列實(shí)線,所以循環(huán)32次
- write_data(0x00); //一列空
- write_data(0xff); //一列實(shí)
- /*---------------------指定位置顯示漢字16*16-----------------------*/
- void hz_disp16(unsigned char pag, unsigned char col, unsigned char code *hzk)
- unsigned char j = 0, i = 0;
- for (j = 0;j < 2;j++) //一個(gè)漢字需要占用2頁(yè),1頁(yè)8行,共16行
- write_com(Page_Add + pag + j);
- write_com(Col_Add + col);
- for (i = 0;i < 16;i++) //16列,所以會(huì)循環(huán)16次
- write_data(hzk[16*j + i]);
- /*--------------------------初始化LCD屏-----------------------------*/
- void init_lcd()
- RST = 0;
- delay(100);
- RST = 1;
- delay(100);
- Mcs = 0;
- Scs = 0;
- delay(100);
- write_com(Disp_Off); //關(guān)顯示
- write_com(Disp_On); //開(kāi)顯示
- /*------------------------------信息顯示----------------------------*/
- void Msg(int flg)
- Clr_Scr(); //清屏
- frame(); //顯示邊框
- if (flg == 0)
- { //顯示“測(cè)試開(kāi)始”
- Mcs = 1;Scs = 0;
- hz_disp16(3, 32, ce);
- delay(2000);
- hz_disp16(3, 48, shi);
- delay(2000);
- Mcs = 0;Scs = 1;
- hz_disp16(3, 0, kai);
- delay(2000);
- hz_disp16(3, 16, shi3);
- delay(2000);
- else if (flg == 1)
- { //顯示“測(cè)試完畢”
- Mcs = 1;Scs = 0;
- Mcs = 0;Scs = 1;
- hz_disp16(3, 0, wan);
- hz_disp16(3, 16, bi);
- /*-----------------------------主程序---------------------------------*/
- main()
- while (1)
- init_lcd();
- Disp_Img(FirstPage);
- delay(25000);
- Msg(0);
- delay(10000);
- Disp_H_Line();
- delay(10000);
- Disp_V_Line();
- delay(10000);
- Msg(1);
- delay(10000);
LCD12864仿真工程文件等資料下載:
LCD12864測(cè)試程序.zip
(419.72 KB, 下載次數(shù): 120)
2016-12-6 19:49 上傳
點(diǎn)擊文件名下載附件
