- 聲明:本程序僅供大家參考學(xué)習(xí),未經(jīng)本人同意禁止用于商業(yè)用途。
- 工程名稱(chēng):ADXL345傾角測(cè)量?jī)x
- 功能: 以LCD1602顯示的傾角度
- QQ:162050981
- #include <STC12C5A.H>
- #include <math.h> //Keil library
- #include <stdio.h> //Keil library
- #include <INTRINS.H>
- #define uchar unsigned char
- #define uint unsigned int
- #include "eeprom52.h"
- #define DataPort P0 //LCD1602數(shù)據(jù)端口
- sbit SCL=P1^3; //IIC時(shí)鐘引腳定義
- sbit SDA=P1^4; //IIC數(shù)據(jù)引腳定義
- sbit LCM_RS=P2^5; //LCD1602命令端口
- sbit LCM_RW=P2^6; //LCD1602命令端口
- sbit LCM_EN=P2^7; //LCD1602命令端口
- sbit MOTOR_Z = P1^1;
- sbit MOTOR_F = P1^2;
- uint xiaozheng=0 ,bianliang=0 ,fazhi=1;
- uchar kaiji=1;
- sbit K1 = P3^3; //加
- sbit K2 = P3^4; //減
- sbit K3 = P3^2; //校準(zhǔn)
- sbit K4 = P3^1; //手動(dòng)自動(dòng)切換
- bit flat=1;
- bit REfsh=1;
- bit REfsh2=1;
- bit genxin=1;
- bit flag_300ms ;
- uchar aa=0;
- #define SlaveAddress 0xA6 //定義器件在IIC總線中的從地址,根據(jù)ALT ADDRESS地址引腳不同修改
- //ALT ADDRESS引腳接地時(shí)地址為0xA6,接電源時(shí)地址為0x3A
- typedef unsigned char BYTE;
- typedef unsigned short WORD;
- BYTE BUF[8]; //接收數(shù)據(jù)緩存區(qū)
- uchar ge,shi,bai,qian,wan; //顯示變量
- uchar san,er,yi; //顯示變量
- int dis_data; //變量
- int fuzhi;
- void delay(unsigned int k);
- void InitLcd(); //初始化lcd1602
- void Init_ADXL345(void); //初始化ADXL345
- void WriteDataLCM(uchar dataW);
- void WriteCommandLCM(uchar CMD,uchar Attribc);
- void DisplayOneChar(uchar X,uchar Y,uchar DData);
- void conversion(uint temp_data);
- void Single_Write_ADXL345(uchar REG_Address,uchar REG_data); //單個(gè)寫(xiě)入數(shù)據(jù)
- uchar Single_Read_ADXL345(uchar REG_Address); //單個(gè)讀取內(nèi)部寄存器數(shù)據(jù)
- void Multiple_Read_ADXL345(); //連續(xù)的讀取內(nèi)部寄存器數(shù)據(jù)
- void Delay5us();
- void Delay5ms();
- void ADXL345_Start();
- void ADXL345_Stop();
- void ADXL345_SendACK(bit ack);
- bit ADXL345_RecvACK();
- void ADXL345_SendByte(BYTE dat);
- BYTE ADXL345_RecvByte();
- void ADXL345_ReadPage();
- void ADXL345_WritePage();
- /******************把數(shù)據(jù)保存到單片機(jī)內(nèi)部eeprom中******************/
- void write_eeprom()
- SectorErase(0x2000);
- byte_write(0x2001, xiaozheng);
- byte_write(0x2002, bianliang);
- byte_write(0x2003, fazhi);
- byte_write(0x2004, kaiji);
- byte_write(0x2060, a_a);
- /******************把數(shù)據(jù)從單片機(jī)內(nèi)部eeprom中讀出來(lái)*****************/
- void read_eeprom()
- xiaozheng = byte_read(0x2001);
- bianliang = byte_read(0x2002);
- fazhi = byte_read(0x2003);
- kaiji = byte_read(0x2004);
- a_a = byte_read(0x2060);
- /**************開(kāi)機(jī)自檢eeprom初始化*****************/
- void init_eeprom()
- read_eeprom(); //先讀
- if(a_a != 2) //新的單片機(jī)初始單片機(jī)內(nèi)問(wèn)eeprom
- bianliang = 0;
- fazhi=1;
- a_a = 2;
- write_eeprom();
- wan=temp_data/10000+0x30 ;
- temp_data=temp_data%10000; //取余運(yùn)算
- qian=temp_data/1000+0x30 ;
- san=temp_data/1000;
- temp_data=temp_data%1000; //取余運(yùn)算
- bai=temp_data/100+0x30 ;
- er=temp_data/100;
- temp_data=temp_data%100; //取余運(yùn)算
- shi=temp_data/10+0x30 ;
- yi=temp_data/10;
- temp_data=temp_data%10; //取余運(yùn)算
- ge=temp_data+0x30;
- unsigned int i,j;
- for(i=0;i<k;i++)
- for(j=0;j<121;j++)
- void WaitForEnable(void)
- DataPort=0xff;
- LCM_RS=0;LCM_RW=1;_nop_();
- LCM_EN=1;_nop_();_nop_();
- while(DataPort&0x80);
- LCM_EN=0;
- if(Attribc)WaitForEnable();
- LCM_RS=0;LCM_RW=0;_nop_();
- DataPort=CMD;_nop_();
- LCM_EN=1;_nop_();_nop_();LCM_EN=0;
- WaitForEnable();
- LCM_RS=1;LCM_RW=0;_nop_();
- DataPort=dataW;_nop_();
- void InitLcd()
- WriteCommandLCM(0x38,1);
- WriteCommandLCM(0x08,1);
- WriteCommandLCM(0x01,1);
- WriteCommandLCM(0x06,1);
- WriteCommandLCM(0x0c,1);
- Y&=1;
- X&=15;
- if(Y)X|=0x40;
- X|=0x80;
- WriteCommandLCM(X,0);
- WriteDataLCM(DData);
- 延時(shí)5微秒(STC90C52RC---12MHz---12T)
- 不同的工作環(huán)境,需要調(diào)整此函數(shù),注意時(shí)鐘過(guò)快時(shí)需要修改
- 當(dāng)改用1T的MCU時(shí),請(qǐng)調(diào)整此延時(shí)函數(shù)
- void Delay5us()
- _nop_();_nop_();_nop_();_nop_();
- 延時(shí)5毫秒(STC90C52RC@12M)
- void Delay5ms()
- WORD n = 560;
- while (n--);
- 起始信號(hào)
- SDA = 1; //拉高數(shù)據(jù)線
- SCL = 1; //拉高時(shí)鐘線
- Delay5us(); //延時(shí)
- SDA = 0; //產(chǎn)生下降沿
- SCL = 0; //拉低時(shí)鐘線
- 停止信號(hào)
- SDA = 0; //拉低數(shù)據(jù)線
- SDA = 1; //產(chǎn)生上升沿
- 發(fā)送應(yīng)答信號(hào)
- 入口參數(shù):ack (0:ACK 1:NAK)
- SDA = ack; //寫(xiě)應(yīng)答信號(hào)
- 接收應(yīng)答信號(hào)
- CY = SDA; //讀應(yīng)答信號(hào)
- return CY;
- 向IIC總線發(fā)送一個(gè)字節(jié)數(shù)據(jù)
- BYTE i;
- for (i=0; i<8; i++) //8位計(jì)數(shù)器
- dat <<= 1; //移出數(shù)據(jù)的最高位
- SDA = CY; //送數(shù)據(jù)口
- ADXL345_RecvACK();
- 從IIC總線接收一個(gè)字節(jié)數(shù)據(jù)
- BYTE i;
- BYTE dat = 0;
- SDA = 1; //使能內(nèi)部上拉,準(zhǔn)備讀取數(shù)據(jù),
- dat <<= 1;
- dat |= SDA; //讀數(shù)據(jù)
- return dat;
- //******單字節(jié)寫(xiě)入*******************************************
- ADXL345_Start(); //起始信號(hào)
- ADXL345_SendByte(SlaveAddress); //發(fā)送設(shè)備地址+寫(xiě)信號(hào)
- ADXL345_SendByte(REG_Address); //內(nèi)部寄存器地址,請(qǐng)參考中文pdf22頁(yè)
- ADXL345_SendByte(REG_data); //內(nèi)部寄存器數(shù)據(jù),請(qǐng)參考中文pdf22頁(yè)
- ADXL345_Stop(); //發(fā)送停止信號(hào)
- //********單字節(jié)讀取*****************************************
- { uchar REG_data;
- ADXL345_SendByte(REG_Address); //發(fā)送存儲(chǔ)單元地址,從0開(kāi)始
- ADXL345_SendByte(SlaveAddress+1); //發(fā)送設(shè)備地址+讀信號(hào)
- REG_data=ADXL345_RecvByte(); //讀出寄存器數(shù)據(jù)
- ADXL345_SendACK(1);
- ADXL345_Stop(); //停止信號(hào)
- return REG_data;
- //連續(xù)讀出ADXL345內(nèi)部加速度數(shù)據(jù),地址范圍0x32~0x37
- void Multiple_read_ADXL345(void)
- { uchar i;
- ADXL345_SendByte(0x32); //發(fā)送存儲(chǔ)單元地址,從0x32開(kāi)始
- for (i=0; i<6; i++) //連續(xù)讀取6個(gè)地址數(shù)據(jù),存儲(chǔ)中BUF
- BUF[i] = ADXL345_RecvByte(); //BUF[0]存儲(chǔ)0x32地址中的數(shù)據(jù)
- if (i == 5)
- ADXL345_SendACK(1); //最后一個(gè)數(shù)據(jù)需要回NOACK
- else
- ADXL345_SendACK(0); //回應(yīng)ACK
- Delay5ms();
- //初始化ADXL345,根據(jù)需要請(qǐng)參考pdf進(jìn)行修改************************
- void Init_ADXL345()
- Single_Write_ADXL345(0x31,0x0B); //測(cè)量范圍,正負(fù)16g,13位模式
- Single_Write_ADXL345(0x2C,0x08); //速率設(shè)定為12.5 參考pdf13頁(yè)
- Single_Write_ADXL345(0x2D,0x08); //選擇電源模式 參考pdf24頁(yè)
- Single_Write_ADXL345(0x2E,0x80); //使能 DATA_READY 中斷
- // Single_Write_ADXL345(0x1E,0x00); //X 偏移量 根據(jù)測(cè)試傳感器的狀態(tài)寫(xiě)入pdf29頁(yè)
- // Single_Write_ADXL345(0x1F,0x00); //Y 偏移量 根據(jù)測(cè)試傳感器的狀態(tài)寫(xiě)入pdf29頁(yè)
- Single_Write_ADXL345(0x20,0x05); //Z 偏移量 根據(jù)測(cè)試傳感器的狀態(tài)寫(xiě)入pdf29頁(yè)
- //顯示x軸
- void display_x()
- { float temp;
- dis_data=(BUF[1]<<8)+BUF[0]; //合成數(shù)據(jù)
- if(dis_data<0){
- dis_data=-dis_data;
- DisplayOneChar(10,0,'-'); //顯示正負(fù)符號(hào)位
- else DisplayOneChar(10,0,' '); //顯示空格
- temp=(float)dis_data*3.9; //計(jì)算數(shù)據(jù)和顯示,查考ADXL345快速入門(mén)第4頁(yè)
- conversion(temp); //轉(zhuǎn)換出顯示需要的數(shù)據(jù)
- DisplayOneChar(8,0,'X');
- DisplayOneChar(9,0,':');
- DisplayOneChar(11,0,qian);
- DisplayOneChar(12,0,'.');
- DisplayOneChar(13,0,bai);
- DisplayOneChar(14,0,shi);
- DisplayOneChar(15,0,' ');
- //顯示y軸
- void display_y()
- { float temp;
- dis_data=(BUF[3]<<8)+BUF[2]; //合成數(shù)據(jù)
- if(dis_data<0)
- DisplayOneChar(2,1,'-'); //顯示正負(fù)符號(hào)位
- MOTOR_Z = 0;
- MOTOR_F = 0; //為負(fù)值,電機(jī)反轉(zhuǎn)
- else if(dis_data>0)
- DisplayOneChar(2,1,' '); //顯示空格
- DisplayOneChar(0,1,'Y'); //第1行,第0列 顯示y
- DisplayOneChar(1,1,':');
- DisplayOneChar(3,1,qian);
- DisplayOneChar(4,1,'.');
- DisplayOneChar(5,1,bai);
- DisplayOneChar(6,1,shi);
- DisplayOneChar(7,1,' ');
- //顯示z軸
- void display_z()
- float temp;
- dis_data=(BUF[5]<<8)+BUF[4]; //合成數(shù)據(jù)
- if(genxin==0)
- genxin=1;
- if(dis_data<0) //當(dāng)為負(fù)數(shù)的時(shí)候進(jìn)行校準(zhǔn)
- bianliang=~dis_data;
- xiaozheng=0;
- if(dis_data>0) //當(dāng)為正數(shù)的時(shí)候進(jìn)行校準(zhǔn)
- bianliang=dis_data;
- xiaozheng=1;
- write_eeprom(); //保存數(shù)據(jù)
- if(genxin==1)
- if(xiaozheng==0) //負(fù)數(shù)校準(zhǔn)后函數(shù)
- dis_data=dis_data+bianliang;
- if(dis_data<0)
- flat=0;
- DisplayOneChar(3,1,'-'); //顯示負(fù)符號(hào)位
- else DisplayOneChar(3,1,' '); //顯示空格
- jiance();
- DisplayOneChar(1,1,'Z'); //第0行,第10列 顯示Z
- DisplayOneChar(2,1,':');
- DisplayOneChar(4,1,qian);
- DisplayOneChar(5,1,'.');
- DisplayOneChar(6,1,bai);
- DisplayOneChar(7,1,shi);
- DisplayOneChar(8,1,' ');
- DisplayOneChar(11,1,'0');
- DisplayOneChar(12,1,'.');
- DisplayOneChar(13,1,'0');
- DisplayOneChar(14,1,fazhi+'0');
- flat=1;
- if(xiaozheng==1) //正數(shù)校準(zhǔn)后函數(shù)
- dis_data=dis_data-bianliang;
- if(dis_data<0)
- flat=0;
- jiance();
- flat=1;
- jiance()
- if(flat==1)
- if(san==0 && er==0 && yi>=0 && yi<=fazhi )
- MOTOR_Z = 1;
- MOTOR_F = 1;
- else
- MOTOR_Z = 0;
- MOTOR_F = 1; //為正值,點(diǎn)擊正轉(zhuǎn)
- if(flat==0)
- if(san==0 && er==0 && yi>=0 && yi<=fazhi)
- MOTOR_Z = 1;
- MOTOR_F = 1;
- else
- MOTOR_Z = 1;
- MOTOR_F = 0; //為正值,點(diǎn)擊正轉(zhuǎn)
- qingping()
- DisplayOneChar(3,0,' ');
- DisplayOneChar(4,0,' ');
- DisplayOneChar(5,0,' ');
- DisplayOneChar(6,0,' ');
- DisplayOneChar(7,0,' ');
- DisplayOneChar(8,0,' ');
- DisplayOneChar(9,0,' ');
- DisplayOneChar(10,0,' ');
- DisplayOneChar(11,0,' ');
- DisplayOneChar(3,1,' ');
- DisplayOneChar(4,1,' ');
- DisplayOneChar(5,1,' ');
- DisplayOneChar(6,1,' ');
- DisplayOneChar(9,1,' ');
- DisplayOneChar(10,1,' ');
- DisplayOneChar(11,1,' ');
- zidong()
- DisplayOneChar(1,0,'B');
- DisplayOneChar(2,0,'a');
- DisplayOneChar(3,0,'l');
- DisplayOneChar(4,0,'a');
- DisplayOneChar(5,0,'n');
- DisplayOneChar(6,0,'c');
- DisplayOneChar(7,0,'e');
- DisplayOneChar(12,0,'D');
- DisplayOneChar(13,0,'u');
- //balance
- shoudong()
- DisplayOneChar(3,0,'S');
- DisplayOneChar(4,0,'h');
- DisplayOneChar(5,0,'o');
- DisplayOneChar(6,0,'u');
- DisplayOneChar(8,0,'D');
- DisplayOneChar(9,0,'o');
- DisplayOneChar(10,0,'n');
- DisplayOneChar(11,0,'g');
- void Outside_Init()
- EX0 = 1;
- IT0 = 1;
- EA = 1;
- void Outside_Int1(void) interrupt 0 using 1
- genxin=0;
- // P2=0x00;
- /*************???0?????***************/
- void time_init()
- EA = 1; //????
- TMOD = 0X01; //???0????1????1
- ET0 = 1; //????0??
- TR0 = 1; //?????0??
- //******主程序********
- void main()
- uchar devid;
- delay(500); //上電延時(shí)
- Init_ADXL345(); //初始化ADXL345
- time_init(); //??????
- init_eeprom(); //讀eeprom數(shù)據(jù)
- InitLcd(); //液晶初始化ADXL345
- while(1) //循環(huán)
- if(!K4)
- delay(20);
- if(!K4)
- while(!K4)
- kaiji++;
- if(kaiji>=2) { kaiji=0; }
- REfsh=1;
- REfsh2=1;
- //======================手動(dòng)=====================================================
- if(kaiji==0)
- if(REfsh2==1)
- InitLcd();
- shoudong();
- REfsh2=0;
- if(K1==0) { MOTOR_Z = 0; }
- if(K1==1) { MOTOR_Z = 1; }
- if(K2==0) { MOTOR_F = 0; }
- if(K2==1) { MOTOR_F = 1; }
- //===============自動(dòng)=============================================================
- if(kaiji==1)
- if(REfsh==1)
- InitLcd();
- zidong();
- REfsh=0;
- if(!K3)
- delay(20);
- if(!K3)
- while(!K3)
- genxin=0;
- if(!K1)
- delay(20);
- if(!K1)
- while(!K1)
- fazhi++;
- if(fazhi>=9) { fazhi=9; }
- if(!K2)
- delay(20);
- if(!K2)
- while(!K2)
- fazhi--;
- if(fazhi<=1) { fazhi=1; }
- if( flag_300ms == 1)
- flag_300ms=0;
- Multiple_Read_ADXL345(); //連續(xù)讀出數(shù)據(jù),存儲(chǔ)在BUF中
- display_z(); //---------顯示Z軸
- /*************???0??????***************/
- void time0_int() interrupt 1
- static uchar value;
- TH0 = 0x3c;
- TL0 = 0xb0; // 50ms
- value ++;
- if(value % 9 == 0)
- flag_300ms = 1; //450ms
- value = 0;
評(píng)分
查看全部評(píng)分
