查看: 2143|回復: 0
基于51壁障遙控尋跡小車源代碼
ID:151076 發表于 2016-11-29 19:39 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
#define uint unsigned int;
sbit Trig=P3^1;
sbit Echo=P3^2;
sbit zuo1=P2^2;
sbit you1=P2^1;
sbit zuo2=P2^3;
sbit you2=P2^0;
sbit A=P1^0;
sbit E=P1^1;
sbit C=P1^2;
sbit D=P1^3;
sbit ENA=P1^4;
sbit ENB=P1^5;
sbit a=P2^4;
sbit b=P2^5;
sbit c=P2^6;
sbit d=P2^7;
uchar PWML,PWMR,t;
uint x,y;
uint timeH,distance,timeL,time;
void delay1(int e)
        int i,j;
        for(i=e;i>0;i--)
        for(j=5;j>0;j--);
void delayms(int f)
        int i,j;
        for(i=f;i>0;i--)
        for(j=110;j>0;j--);
void delay(int g)
        int i,j;
        for(i=2;i>0;i--)
        for(j=g;j>0;j--);
void delay_20us()
        uchar s;
        for(s=0;s<100;s++);
void yaokong()
        if(a==1)
        x=1;
        if(b==1)
        x=2;
        if(c==1)
        x=3;
        if(d==1)
        x=4;
void qianjin1()
        while(x!=4)
                 A=0;E=1;
                 C=0;D=1;
         PWML=30;
                 PWMR=30;
                 delayms(1000);
                 PWML=100;
                 PWMR=100;
                 delayms(1000);
                 PWML=0;
                 PWMR=0;
                 delayms(1000);
                 A=1;E=0;
                 C=1;D=0;
                 PWML=100;
                 PWMR=100;
                 delayms(1000);
                 PWML=30;
                 PWMR=30;
                 delayms(1000);
                 x=4;
void qianjin()
{        P1=0xfa;  //前進//
        delay(15-8);
        P1=0xff;
        delay(8);
void qianjin2()
{        P1=0xfa;  //前進
    delay1(50);
        P1=0xf0;
        delay1(50);
void zuozhuan()
{        P1=0xf2;  //左轉動
        delay(15-9);
        P1=0xff;
        delay(9);
void zuozhuan1()
   P1=0xf2;
   delay1(10);
   P1=0xf0;
   delay1(1);//左轉動//
void youzhuan()
{        P1=0xf8;  //右轉動//
        delay(15-9);
        P1=0xff;
        delay(9);
void xunji()
        if((zuo1==1)&&(zuo2==1)&&(you2==1)&&(you1==0))
                y=1;//youzhuan();
        if((zuo1==1)&&(zuo2==1)&&(you2==1)&&(you1==1))
                y=0;//qianjin();
        if((zuo1==0)&&(zuo2==1)&&(you2==1)&&(you1==1))
                y=2;//zuozhuan();
        if((zuo1==1)&&(zuo2==1)&&(you2==0)&&(you1==0))
                y=1;//youzhuan();
        if((zuo1==0)&&(zuo2==0)&&(you2==1)&&(you1==1))
                        y=2;//        zuozhuan();
        if((zuo1==1)&&(zuo2==0)&&(you2==0)&&(you1==0))
                y=1;//youzhuan();
        if((zuo1==0)&&(zuo2==0)&&(you2==0)&&(you1==1))
                        y=2;//        zuozhuan();
        switch(y)
                case 0:qianjin();break;
                case 1:youzhuan();break;
                case 2:zuozhuan();break;
void chaoshengbo()
        Trig=0;//拉低脈沖輸入引腳
        TH1=0;//定時器高位清零
    TL1=0;//定時器低位清零
        Trig=1;//超聲波輸入端
        delay_20us();//延時20us
        Trig=0;//產生一個20us的脈沖
        while(Echo==0);//等待Echo回波引腳變低電平
        EX0=1;//打開外部中斷0
        TR1=1;//啟動定時器1
        while(Echo==1);//等待測量結果
        TR1=0;//關閉定時器1
        EX0=0;//關閉外部中斷
    time=timeH*256+timeL;
        distance=time*0.172;//毫米
        if(distance>300)
                        qianjin2();
                  zuozhuan1();
void panduan()
          if(x==1)
         TR0=0;
         TR1=0;
         xunji();
        if(x==2)
         TR1=0;
         TR0=1;
         qianjin1();
        if(x==3)
         TR0=0;
         chaoshengbo();
        if(x==4)
         P1=0xf0;
void init()
TMOD=0x11;
TH0=(65536-50)/256;
TL0=(65536-50)%256;
EA=1;
ET0=1;
ET1=1;
P1=0xf0;
P2=0x0f;
  init();
        yaokong();
        panduan();
void T0_time() interrupt 1
        TH0=(65536-50)/256;
        TL0=(65536-50)%256;
        if(t<PWML)
                  ENA=1;
          ENA=0;
          if(t<PWMR)
          ENB=1;
          ENB=0;
          t++;
          if(t>=100)
          t=0;
void exter() interrupt 0//外部中斷,判斷回波電平
        timeH=TH1;//取出定時器的值
        timeL=TL1;//取出定時器的值
void timer1() interrupt 3// 定時器1中斷,超聲波測距計時
        TH1=0;
        TL1=0;
