查看: 3480|回復(fù): 0
數(shù)碼管0~9,A~F顯示
ID:149673 發(fā)表于 2016-11-23 11:12 | 只看該作者 回帖獎勵 |倒序?yàn)g覽 |閱讀模式
#include<reg52.h>
uchar a[]={0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x08,0x0B,0X46,0xA1,0x06,0x0E};
uchar b[]={0xef,0xdf,0xbf,0x7f,0xef,0xdf,0xbf,0x7f,0xef,0xdf,0xbf,0x7f,0xef,0xdf,0xbf,0x7f};
void delay(uint x);
void LED();
     LED();
void delay(uint  x)
     uint i,j;
         for(i=0;i<x;i++)
         for(j=0;j<250;j++);
void  LED()
{          uint i;
         for(i=0;i<14;i++)
             P0=a[i];
                 P2=b[i];
                 delay(500);
