//LCD12864字庫系列(控制器ST7920A),單片機(jī):89S52,晶振:12M,
//并行連接方式,P2.0-RS,P2.1-RW,P2.2-E
//設(shè)計:TIMEN HUANG
#include<reg52.h>
#include <intrins.h>
sbit RS=P3^2;//串口時為CS
sbit RW=P3^1; //串口為SID
sbit E=P3^0; //串口為時鐘SCLK
sbit stop=P2^2;
sbit PSB=P3^4;
sbit REST=P3^3;
//以下是用<at89x51.h>頭文件的定義
#define RS P2_0
#define RW P2_1 //定義引腳
#define E P2_2
#define PSB P2_3
#define REST P2_4
#define Data P1
#include<at89x51.h>
#define BF 0x80 //用于檢測LCM狀態(tài)字中的Busy標(biāo)識
typedef unsigned int Uint;
typedef unsigned char Uchar;
//字符串例子
//"F1--English",也可以往里面寫入漢字碼,一個漢字由兩個碼組成
const Uchar F1English[]={0x46,0x31,0x2d,0x2d,0x45,0x6e,0x67,0x6c,0x69,0x73,0x68,0x00};
const Uchar lengthF1=6; //字符串長度
//漢字,直接可以寫入字形
unsigned char code uctech[] = {"有限公司"};
const Uchar lengthCF3=8;
Uchar code TAB1[]={
/*-- 調(diào)入了一幅圖像:D:\公司的文件\程序圖片\未命名11.bmp --*/
/*-- 寬度x高度=128x64 --*/
0x40,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x05,0xAE,0x90,0x00,0x00,0x00,0x00,0x00,
0x95,0x55,0x48,0x80,0x00,0x00,0x00,0x00,
0x2B,0x55,0x00,0x00,0x00,0x00,0x00,0x00,
0xA8,0x00,0x22,0x15,0x20,0x00,0x00,0x00,
0x97,0xFB,0x00,0x00,0x00,0x00,0x00,0x00,
0x45,0x55,0x08,0xA0,0x00,0x00,0x00,0x0A,
0x6F,0xF4,0x00,0x00,0x00,0x00,0x00,0x00,
0xB2,0x80,0x40,0x00,0x04,0x40,0x00,0x00,
0xBA,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,
0x4D,0x55,0x15,0x15,0x20,0x00,0x00,0x95,
0xD5,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0xFF,0xE8,0x40,0x40,0x00,0x00,0x00,0x4A,
0xAA,0x80,0x00,0x00,0x00,0x00,0x00,0x00,
0xFF,0xFF,0x2A,0x00,0x40,0x00,0x00,0x15,
0x54,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0xFF,0xFD,0xD0,0xAA,0x01,0x00,0x00,0x25,
0x20,0x10,0x00,0x00,0x00,0x00,0x00,0x00,
0xFF,0xFF,0xB6,0x00,0x10,0x00,0x01,0x4A,
0x49,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0xFF,0xFF,0xFD,0xE8,0x40,0x00,0x00,0x11,
0x00,0x24,0x84,0x00,0x00,0x00,0x00,0x00,
0xAB,0xFF,0xFF,0x55,0x00,0x00,0x00,0x24,
0x02,0x49,0x5E,0xA0,0x00,0x00,0x00,0x00,
0x84,0xBF,0xFF,0xF4,0x88,0x00,0x00,0x00,
0x10,0x05,0xFF,0xF4,0x00,0x00,0x00,0x00,
0x29,0x0B,0xFF,0xFA,0x20,0x00,0x00,0x00,
0x02,0xBF,0xFF,0xFC,0x00,0x00,0x00,0x00,
0x44,0xA0,0x57,0xFD,0x80,0x00,0x00,0x00,
0x08,0x5F,0xFF,0xFF,0x80,0x00,0x00,0x00,
0x91,0x0A,0xAA,0xF6,0x50,0x00,0x00,0x00,
0x41,0xFF,0xFF,0xFF,0xC0,0x00,0x00,0x00,
0x44,0xA0,0x01,0x1B,0x84,0x00,0x00,0x00,
0x26,0xFF,0xFF,0xFF,0x90,0x00,0x00,0x00,
0x11,0x0A,0xAA,0x6D,0x68,0x00,0x00,0x00,
0x0B,0xFB,0xFF,0xEF,0xE0,0x00,0x00,0x00,
0xC4,0xA0,0x01,0x02,0x80,0x00,0x00,0x00,
0x43,0xF1,0xFE,0x63,0xF0,0x00,0x00,0x00,
0x15,0x55,0x54,0x55,0x6A,0x00,0x00,0x00,
0x9F,0xE3,0xFC,0x87,0x38,0x00,0x00,0x00,
0xCA,0xAB,0x91,0x00,0x90,0x00,0x00,0x00,
0x07,0xC1,0xFA,0x2A,0x80,0x00,0x00,0x00,
0x25,0xFF,0xFE,0x95,0x2A,0x00,0x00,0x00,
0x2F,0x13,0xFE,0xFC,0x10,0x00,0x00,0x00,
0x95,0xFF,0xFF,0xC0,0x50,0x00,0x00,0x00,
0x0F,0x41,0xFF,0xF3,0x80,0x00,0x00,0x00,
0x4F,0xFF,0xFF,0xF9,0x2A,0x00,0x00,0x00,
0x9F,0x08,0xFF,0xD4,0x00,0x00,0x00,0x00,
0xB3,0xFF,0xFF,0xFE,0x54,0x80,0x00,0x00,
0x1E,0xA0,0x7F,0xA0,0x00,0x00,0x00,0x00,
0x5F,0xFE,0x7F,0xFE,0xAA,0x00,0x00,0x00,
0x5F,0x57,0xFE,0x00,0x00,0x00,0x00,0x00,
0xAF,0xFD,0x7F,0xFF,0x94,0x80,0x00,0x00,
0x1F,0xFE,0xE8,0x00,0x00,0x00,0x00,0x00,
0x7F,0xFA,0x7F,0x5F,0xCA,0x00,0x00,0x00,
0x3F,0x55,0x00,0x00,0x00,0x00,0x00,0x00,
0xAF,0xF1,0x7F,0xDE,0xF5,0x40,0x00,0x00,
0x1A,0xA0,0x80,0x00,0x00,0x00,0x00,0x00,
0xDF,0xF2,0x3F,0xFC,0xC2,0x00,0x00,0x00,
0x50,0x08,0x00,0x00,0x00,0x00,0x00,0x00,
0x2F,0xFA,0xBF,0xFF,0xF4,0xA0,0x00,0x00,
0x05,0x42,0x00,0x00,0x00,0x00,0x00,0x00,
0x97,0xFE,0x3F,0xFF,0xE3,0x00,0x00,0x00,
0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x68,0xFF,0xDF,0xD5,0x78,0x40,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x07,0x5F,0xFF,0x48,0x02,0x80,0x00,0x00,
0xD0,0xAA,0xF4,0xA0,0xAA,0x40,0x00,0x00,
0x0A,0x45,0x09,0x05,0x11,0x00,0x00,0x00,
0xA1,0x28,0xA0,0x00,0x44,0x40,0x00,0x00,
0x08,0x42,0x04,0x52,0x12,0x80,0x00,0x00,
0xA5,0x09,0x51,0x00,0x48,0x00,0x00,0x00,
0x00,0x50,0x04,0x4A,0x12,0x80,0x00,0x00,
0xAA,0x05,0x50,0x21,0x48,0x20,0x00,0x00,
0x00,0x90,0x02,0x84,0x12,0x80,0x00,0x00,
0xD4,0x05,0x48,0x10,0x48,0x00,0x00,0x00,
0x81,0x20,0x00,0x02,0x02,0x80,0x00,0x00,
0xA4,0x84,0x92,0x48,0x94,0x40,0x00,0x00,
0x48,0x10,0x00,0x00,0x21,0x00,0x00,0x00,
//這個是在串口時指令和數(shù)據(jù)之間的延時
void delay10US(Uchar x)
Uchar k;
for(k=0;k<x;k++);
const Uchar delay=250; //延時時間常數(shù)
static void Wait1ms(void)//延遲1 ms
Uchar cnt=0;
while (cnt<delay) cnt++;
//延遲n ms
void WaitNms(int n)
Uchar i;
for(i=1;i<=n;i++)
Wait1ms();
void stopint(void)//中斷程序
if(stop==0)
while(1);
//以下是并口時才開的
//讀忙標(biāo)志,
void RDBF(void)
Uchar temp;
RS=0; // RS=0
RW=1; // RW=1
P1=0xFF; //數(shù)據(jù)線為輸入
E=1;
temp=P1;
E=0; // E=0
if ((temp&0x80)==0) break;
//寫數(shù)據(jù)到指令寄存器
void WRCommand(Uchar comm)
RDBF();
RW=0;
P1=comm;
E=1;
E=0;
//寫數(shù)據(jù)到數(shù)據(jù)寄存器
void WRData(Uchar TEMP)
RDBF();
RS=1;
RW=0;
P1=TEMP;
E=1;
E=0;
stopint();
//以下是串口時開的讀寫時序
/*void SendByteLCD(Uchar WLCDData)
Uchar i;
for(i=0;i<8;i++)
if((WLCDData<<i)&0x80)RW=1;
else RW=0;
E=0;
E=1 ;
SPIWR(Uchar Wdata,Uchar WRS)
SendByteLCD(0xf8+(WRS<<1));
SendByteLCD(Wdata&0xf0);
SendByteLCD((Wdata<<4)&0xf0);
void WRCommand(Uchar CMD)
RS=0;
RS=1;
SPIWR(CMD,0);
delay10US(90);//89S52來模擬串行通信,所以,加上89S52的延時,
void WRData(Uchar Data)
RS=0;
RS=1;
SPIWR(Data,1);
//初始化LCD-8位接口
void LCDInit(void)
{ // PSB=0; //串口
PSB=1;//并口時選這個,上一行取消
REST=1;
REST=0;
REST=1;
WRCommand(0x30); //基本指令集,8位并行
WRCommand(0x06); //啟始點(diǎn)設(shè)定:光標(biāo)右移
WRCommand(0x01); //清除顯示DDRAM
WRCommand(0x0C); //顯示狀態(tài)開關(guān):整體顯示開,光標(biāo)顯示關(guān),光標(biāo)顯示反白關(guān)
WRCommand(0x02); //地址歸零
//顯示數(shù)組字符串(顯示半寬字型16*8點(diǎn)陣)
void ShowQQChar(Uchar addr,Uchar *english,Uchar count)
Uchar i;
WRCommand(addr); //設(shè)定DDRAM地址
for(i=0;i<count;)
WRData(english[i*2]);
WRData(english[i*2+1]);
i++;
//顯示連續(xù)字串(半寬字符)
void ShowNUMChar(Uchar addr,Uchar i,Uchar count)
Uchar j;
for(j=0;j<count;)
WRData(i+j);
j++;
WRData(i+j);
addr++;
j++;
//自定義字符寫入CGRAM
void WRCGRAM(Uchar data1,Uchar data2,Uchar addr)
Uchar i;
for(i=0;i<16;)
WRCommand(addr+i); //設(shè)定CGRAM地址
WRData(data1);
WRData(data1);
i++;
WRData(data2);
WRData(data2);
i++;
//顯示自定義的字符,并把這個字符填滿全屏16*16
void ShowCGChar(Uchar addr,Uchar i)
Uchar j;
for(j=0;j<0x20;)
WRCommand(addr+j); //設(shè)定DDRAM地址
WRData(0x00);
WRData(i);
j++;
void CLEARGDRAM(void)
Uchar j;
Uchar i;
WRCommand(0x34);
WRCommand(0x36);
for(j=0;j<32;j++)
WRCommand(0x80+j);
WRCommand(0x80);//X坐標(biāo)
for(i=0;i<32;i++)//
WRData(0x00);
//寫入GDRAM 繪圖,Y是Y繪圖坐標(biāo),2個字節(jié)一行,CLONG是圖形長度,以字節(jié)
//為單位;HIGHT是圖形高度,TAB是圖形數(shù)據(jù)表.12864M的圖形顯示是相當(dāng)于256*32點(diǎn)陣.
//由兩屏128*32上下兩屏組成,同一行的下屏的頭地址緊接上屏的未地址。
//繪圖在串口輸入時,會比在并口下的輸入要慢一些
void WRGDRAM(Uchar Y1,Uchar clong,Uchar hight,Uchar *TAB1)
Uint k;
Uchar j;
Uchar i;
WRCommand(0x34);
WRCommand(0x36);
for(j=0;j<hight;j++)//32
{ //先上半屏
WRCommand(Y1+j); //Y總坐標(biāo),即第幾行
WRCommand(0x80);//X坐標(biāo),即橫數(shù)第幾個字節(jié)開始寫起
for(i=0;i<clong;i++)//
WRData(TAB1[clong*j+i]);
//后下半屏
for(k=0;k<clong;k++)//
WRData(TAB1[clong*(j+hight)+k]);
void menu(void)
LCDInit();
ShowNUMChar(0x80,0x01,0x0f);//顯示半寬特殊符號
ShowNUMChar(0x90,0x30,0x0f);//顯示半寬0~?數(shù)字標(biāo)點(diǎn)
ShowNUMChar(0x88,0x41,0x0f);//顯示半寬A~P大寫
ShowNUMChar(0x98,0x61,0x0f);//顯示半寬a~p小寫
WaitNms(250); //等待時間
stopint();
WRCGRAM(0xff,0x00,0x40);//寫入橫
WRCGRAM(0x00,0xff,0x50);//寫入橫2
WRCGRAM(0xaa,0xaa,0x60);//寫入豎
WRCGRAM(0x55,0x55,0x70);//寫入豎2
ShowCGChar(0x80,0x00);//顯示橫并填滿
stopint();
ShowCGChar(0x80,02);//顯示橫2并填滿
stopint();
ShowCGChar(0x80,04);//顯示豎并填滿
stopint();
ShowCGChar(0x80,06);//顯示豎2并填滿
stopint();
WRCGRAM(0x00,0x00,0x40);//清CGRAM1
WRCGRAM(0x00,0x00,0x50);//清CGRAM2
WRCGRAM(0xaa,0x55,0x40);//寫入點(diǎn)
WRCGRAM(0x55,0xaa,0x50);//寫入點(diǎn)2
ShowCGChar(0x80,00);//顯示點(diǎn)并填滿
stopint();
ShowCGChar(0x80,02);//顯示點(diǎn)2并填滿
stopint();
ShowQQChar(0x80,uctech,lengthCF3);//顯示'有限公司',以下共四行
ShowQQChar(0x90,uctech,lengthCF3);
ShowQQChar(0x88,uctech,lengthCF3);
ShowQQChar(0x98,uctech,lengthCF3);
stopint();
void menu2(void)
{ CLEARGDRAM();
WRGDRAM(0x80,16,32,TAB1);
stopint();
//主函數(shù)
void main(void)
menu();//初始化及半寬字符和點(diǎn)橫豎漢字掃描
menu2();//繪圖顯示
for(;;)
