用定時(shí)器做時(shí)鐘的仿真,可調(diào)節(jié)時(shí)間,兩個(gè)“-”1秒閃爍一次
2016-11-9 10:54 上傳
下面是源代碼
#include<reg51.h>
#include<absacc.h>
/*七段共陰管顯示定義*/
uchar code dispcode[ ]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x40,0x00,
0xBF,0x86,0xCB,0xCF,0xEF,0xED,0xFD,0x87,0xFF,0xDF};
/*定義并初始化變量*/
uchar seconde=0;
uchar minite=0;
uchar hour=12;
uchar mstcnt=0;
uchar mstcnt1=0;
uchar miao_ss=0;
char k1num=0,snum,fnum;
sbit k1=P1^0; // 設(shè)置
sbit k2=P1^1; //加
sbit k3=P1^2; //減
sbit LED=P1^7;
/*函數(shù)聲明*/
void delay(uchar k ); //延時(shí)子程序
void time_pro( ); //時(shí)間處理子程序
void display( ); //顯示子程序
void keyscan( ); //鍵盤掃描子程序
/*延時(shí)子程序*/
void delay (uchar k)
uchar j;
while((k--)!=0)
for(j=0;j<125;j++)
/*時(shí)間處理子程序*/
void time_pro( void)
if(seconde==60) //秒鐘設(shè)為60進(jìn)制
{ seconde=0;
minite++;
if( minite==60) //分鐘設(shè)為60進(jìn)制
{ minite=0;
hour++;
if(hour==24) //時(shí)鐘設(shè)為24進(jìn)制
{hour=0; }
/* 顯示子程序*/
void display(void)
if(k1num==0)
snum=30;
fnum=30;
if(k1num==1) //如果k1num=1,分位閃爍
fnum++;
snum=30; // snum=15,每分鐘閃爍2次;snum=30,每分鐘閃爍1次;
if(k1num==2)
snum++;
fnum=30;
if(snum>=30)
P2=0xfe;
P0=dispcode[hour/10]; //顯示小時(shí)的十位
delay(4);
P2=0xfd;
P0=dispcode[hour%10]; //顯示小時(shí)的個(gè)位+秒點(diǎn)閃爍
delay(4);
if(snum==60)
snum=0;
if(seconde%2)
P2=0xfb;
P0=dispcode[10];
delay(4);
else{P2=0xfb;
P0=dispcode[11];
delay(4);}
if(fnum>=30)
P2=0xf7;
P0=dispcode[minite/10]; //顯示分的十位
delay(4);
P2=0xef;
P0=dispcode[minite%10]; //顯示分的個(gè)位
delay(4);
if(fnum==60)
fnum=0;
/* P2=0xdf;
P0=dispcode[10];
delay(4);*/
P2=0xbf;
P0=dispcode[seconde/10]; //顯示秒的十位
delay(4);
P2=0x7f;
P0=dispcode[seconde%10]; //顯示秒的個(gè)位
delay(4);
/*鍵盤掃描子程序*/
void keyscan (void)
if(k1==0) //設(shè)置
delay(30);
if(k1==0)
{ while(!k1);
k1num++;
if(k1num==1) //這句不寫,調(diào)時(shí)間時(shí),秒走時(shí);
{TR0=0; } //這句寫上,調(diào)時(shí)間時(shí),秒停止走時(shí);
if(k1num==3)
seconde=0;
k1num=0;
TR0=1;}
if(k1num==1)
if(k3==0) //按鍵3分的調(diào)整減
delay(30);
if(k3==0)
{ while(!k3);
minite--;
if(minite==-1)
{minite=59;}
if(k2==0) //按鍵2分的調(diào)整加
delay(30);
if(k2==0)
{ while(!k2);
minite++;
if(minite==60)
{minite=0;}
if(k1num==2)
if(k2==0) //按鍵2小時(shí)的調(diào)整加
delay(30);
if(k2==0)
while(!k2);
hour++;
if(hour==24)
{hour=0; }
if(k3==0) //按鍵3小時(shí)的調(diào)整減
delay(30);
if(k3==0)
while(!k3);
hour--;
if(hour==-1)
{hour=23; }
void timer0(void) interrupt 1 //定時(shí)器0方式1,50ms中斷一次
{ //晶振 12MHz
TH0=0x3c;
TL0=0xb0;
mstcnt++;
if(mstcnt==20)
seconde++;
mstcnt=0; //注意點(diǎn)。對(duì)計(jì)數(shù)單元的清零十分的重要,本次調(diào)試中就是
// ss=!ss;
// LED=ss;
} //因?yàn)楹雎粤诉@一點(diǎn),給我造成了很大的被動(dòng)。
/*void timer1(void) interrupt 3 //定時(shí)器0方式1,50ms中斷一次
{ //晶振 12MHz
TH0=0x3c;
TL0=0xb0;
miao_ss++;
if(miao_ss==10)
miao_ss=0;
// P0=dispcode[10];
LED=!LED;
// delay(5);
// P0=dispcode[11];
/*主函數(shù)*/
void main(void)
// P1=0xff; //初始化p1口,全設(shè)為1
TMOD = 0x11; //time0為定時(shí)器,方式1
TH0=0x3c; //預(yù)置計(jì)數(shù)初值
TL0=0xb0;
EA=1;
ET0=1;
ET1=1;
TR1=1;
TR0=1;
while (1)
keyscan( ); //按鍵掃描
display( ); //顯示時(shí)間
} //仿真通過 8位數(shù)碼管顯示88—88—88樣式的時(shí)鐘
評(píng)分
查看全部評(píng)分
