返回列表 發(fā)新帖
樓主: 七顆星星
剛剛告知老師不允許用DS18B20數(shù)字傳感器測溫,還有什么嗎?
ID:145062 發(fā)表于 2016-10-29 15:26 | 只看該作者
通過熱敏電阻的阻值變化,通過MCU的ADC獲取熱敏電阻的兩端電壓變化,計算出相應(yīng)的電阻值,根據(jù)組織查邊獲取溫度值,首先熱敏電阻便宜,電阻簡單,查表方便,相應(yīng)的江都不高一般是0.1攝氏度吧!
ID:143848 發(fā)表于 2016-10-29 20:15 | 只看該作者
pingguotu 發(fā)表于 2016-10-29 15:26
通過熱敏電阻的阻值變化,通過MCU的ADC獲取熱敏電阻的兩端電壓變化,計算出相應(yīng)的電阻值,根據(jù)組織查邊獲取 ...
熱敏電阻3950的測溫單片機里程序
code        uint VOL[]和code        uint Temper[]中的數(shù)據(jù)是怎么計算查表得到的。
       result=(uint)((res/2048.0-1.0)*500.0);
                 temp1=abs(result-VOL[0]);
                 for(i=1;i<150;i++)
                         temp2=abs(result-VOL);
                        if(temp1>=temp2)
                                temp1=temp2;
                                flag=i;
   這一段程序是什么意思呢?
               :#include <reg52.h>
#include <intrins.h>
#include <math.h>
typedef unsigned char uchar;
typedef unsigned int  uint;
code        uint VOL[]={                343,        339,        339,        335,        332,        332,        328,        324,        320,        320,
                                                        316,        312,        312,        308,        304,        300,        300,        296,        292,        292,
                                                        289,        285,        285,        281,        277,        273,        273,        269,        265,        265,
                                                        261,        257,        257,        253,        250,        250,        246,        242,        242,        238,
                                                        234,        234,        230,        230,        226,        222,        222,        218,        218,        214,
                                                        210,        210,        207,        207,        203,        199,        199,        195,        195,        191,
                                                        191,        187,        187,        183,        179,        179,        175,        175,        171,        171,
                                                        167,        167,        164,        164,        160,        160,        160,        156,        156,        152,
                                                        152,        148,        148,        144,        144,        140,        140,        140,        136,        136,
                                                        132,        132,        132,        128,        128,        125,        125,        125,        121,        121,
                                                        121,        117,        113,        109,        109,        105,        101,        101,        97,                97,
                                                        93,                89,                89,                85,                85,                82,                82,                78,                78,                74,
                                                        74,                70,                70,                66,                66,                66,                62,                62,                58,                58,
                                                        58,                54,                54,                54,                50,                50,                50,                46,                46,                46,
                                                        42,                42,                42,                42,                39,                39,                39,                39,                35,                35};
code        uint Temper[]={                100,        150,        200,        250,        300,        350,        400,        450,        500,        550,
                                                        600,        650,        700,        750,        800,        850,        900,        950,        1000,        1050,
                                                        1100,        1150,        1200,        1250,        1300,        1350,        1400,        1450,        1500,        1550
                                                        1600,        1650,        1700,        1750,        1800,        1850,        1900,        1950,        2000,        2050,
                                                        2100,        2150,        2200,        2250,        2300,        2350,        2400,        2450,        2500,        2550,
                                                        2600,        2650,        2700,        2750,        2800,        2850,        2900,        2950,        3000,        3050,
                                                        3100,        3150,        3200,        3250,        3300,        3350,        3400,        3450,        3500,        3550,
                                                        3600,        3650,        3700,        3750,        3800,        3850,        3900,        3950,        4000,        4050,
                                                        4100,        4150,        4200,        4250,        4300,        4350,        4400,        4450,        4500,        4550,
                                                        4600,        4650,        4700,        4750,        4800,        4850,        4900,        4950,        5000,        5050,
                                                        5100,        5200,        5300,        5400,        5500,        5600,        5700,        5800,        5900,        6000,
                                                        6100,        6200,        6300,        6400,        6500,        6600,        6700,        6800,        6900,        7000,
                                                        7100,        7200,        7300,        7400,        7500,        7600,        7700,        7800,        7900,        8000,
                                                        8100,        8200,        8300,        8400,        8500,        8600,        8700,        8800,        8900,        9000,
                                                        9100,        9200,        9300,        9400,        9500,        9600,        9700,        9800,        9900,        10000};
sbit STS=P1^0;
sbit CE = P1^1;
sbit CS=P1^2;
sbit A0=P1^3;
sbit RC=P1^4;
sbit RS=P1^5 ;
sbit RW=P1^6 ;
sbit EN=P1^7 ;
void delay_ms(uint z)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
uint AD1674_Read(void)
        uint temp;
        uchar temp1,temp2;
        CS=1;        //片選信號
        CE=0;        //初始化,關(guān)閉數(shù)據(jù)采集
        CS=0;
        A0=0;
        RC=0;
        CE=1;//CE=1,CS=0,RC=0,A0=0啟動12位溫度轉(zhuǎn)換
        _nop_();
        while(STS==1);         //等待數(shù)據(jù)采集結(jié)束
        CE=0;         //芯片使能關(guān)閉
        RC=1;
        A0=0;
        CE=1;//CE=1,CS=0,RC=1,12/8=1,A0=0 允許高八位數(shù)據(jù)并行輸出
        _nop_();
        temp1=P0; //讀取轉(zhuǎn)換結(jié)果的高八位
        RC=1;
        A0=1;
        CE=1;//CE=1,CS=0,RC=1,12/8=0,A0=1 允許低四位數(shù)據(jù) 并行輸出
        _nop_();
        temp2=P0;         //讀取轉(zhuǎn)換結(jié)果的第四位
        temp=((temp1<<4)|(temp2&0X0F));          //高位和低位合成實際溫度,temp2為PO口的高四位
        return (temp);           //還回轉(zhuǎn)換結(jié)果,右移四位是因為temp2為P0口的高四位
/*** 寫數(shù)據(jù)***/
void w_dat(unsigned char dat)
        RS = 1;
        //EN = 0;
        P2 = dat;
        delay_ms(5);
        RW = 0;
        EN = 1;
        EN = 0;
/*** 寫命令***/
void w_cmd(unsigned char cmd)
        RS = 0;
//        EN = 0;
        P2 = cmd;
        delay_ms(5);
        RW = 0;
        EN = 1;
        EN = 0;
/*** 發(fā)送字符串到LCD***/
void w_string(unsigned char addr_start, unsigned char *p)
        unsigned char *pp;
        pp = p;
        w_cmd(addr_start);
        while (*pp != '\0')
                w_dat(*pp++);
/*** 初始化1602****/
void Init_LCD1602(void)
        EN = 0;
        w_cmd(0x38);  // 16*2顯示,5*7點陣,8位數(shù)據(jù)接口
        w_cmd(0x0C);  // 顯示器開、光標開、光標允許閃爍
        w_cmd(0x06);  // 文字不動,光標自動右移
        w_cmd(0x01);  // 清屏
void process(uint date,uchar add)
        uchar A[7];
        A[0]=date/1000%10+'0';
        A[1]=date/100%10+'0';
        A[2]='.';
        A[3]=date/10%10+'0';
        A[4]=date%10+'0';
        A[5]='C';
        w_string(add,A);
        uchar i,flag=0;
        uint result,temp1,temp2;
        float        res;
        Init_LCD1602();
        w_string(0x80,"Temper:");
        while (1)
                 res=(float)(AD1674_Read());
                 for(i=1;i<150;i++)
                        if(temp1>=temp2)
                                temp1=temp2;
                                flag=i;
                 process(Temper[flag],0x80+7);
ID:140371 發(fā)表于 2016-10-30 16:11 | 只看該作者
這個電路不妨用麵包板,試做看看(或是用仿真軟體模擬看看)...例如測試範圍從  0到 100度  輸出Vo從0到4.92 這個電路就可以用
ID:164989 發(fā)表于 2017-5-28 16:48 | 只看該作者
pt100接一個tl431恒流源再接2個運放加調(diào)零出來就是電壓的變化再接個tl1543AD轉(zhuǎn)換接到單片機里計算電阻值在計算溫度temp_r=((float)temp)*5000/(1024*20)+100;  //計算電阻值。[img]C:\Users\asus\Desktop\E13DA9FA454BBB6930F3639E5E9D33EE.pngC:\Users\asus\Desktop\4700A418B4F82E4F6F6DE1ED1AB49134.png[/img]
