查看: 3861|回復: 3
超大屏幕16*96點陣顯示程序及原理圖帶proteus仿真
今天給51黑電子論壇的朋友們分享一個16*96點陣組成的超大屏幕的仿真,帶源程序,下面是原理圖:
16*96點陣的單片機源程序:
  1. #include<reg51.h>
  2. typedef  unsigned char uchar;
  3. typedef  unsigned int uint;
  4. sbit E1=P3^4;
  5. sbit ST=P3^5;
  6. sbit SS=P3^6;
  7. unsigned char code mo[6][2][16]=
  8. {{{0x00,0x00,0x01,0x02,0x12,0x13,0x1E,0xF2,0x23,0x24,0x24,0x04,0x07,0x00,0x00,0x00},
  9. {0x00,0x00,0xF8,0x00,0x50,0x50,0xD0,0x78,0xA0,0xA0,0x08,0x04,0xFC,0x00,0x00,0x00}},
  10. {{0x00,0x00,0x00,0x00,0x78,0x54,0x54,0x55,0x95,0x85,0x99,0xE1,0x01,0x00,0x00,0x00},
  11. {0x00,0x00,0x00,0xF0,0xA8,0xA8,0xA8,0x28,0x48,0x48,0x04,0x0E,0xF0,0x00,0x00,0x00}},
  12. {{0x00,0x00,0x0F,0x15,0xF1,0x1F,0x00,0x00,0x09,0x89,0x4A,0x13,0x10,0x10,0x00,0x00},
  13. {0x84,0x88,0xF0,0x40,0x08,0xFC,0x00,0x08,0xF0,0x00,0x00,0xF0,0x08,0x08,0x38,0x00}},
  14. {{0x00,0x04,0x18,0x10,0x11,0x16,0x90,0x50,0x10,0x24,0x22,0x20,0x28,0x10,0x00,0x00},
  15. {0x00,0x04,0x04,0x84,0x04,0x44,0x44,0x78,0x88,0x88,0x88,0x08,0x0C,0x04,0x00,0x00}},
  16. {{0x00,0x00,0x02,0x02,0x02,0x02,0xFF,0x04,0x04,0x04,0x04,0x04,0x00,0x00,0x00,0x00},
  17. {0x00,0x04,0x08,0x10,0x20,0xC0,0x00,0x80,0x40,0x20,0x10,0x08,0x0C,0x04,0x04,0x00}},
  18. {{0x00,0x03,0x0E,0x44,0x24,0x05,0x4A,0x2A,0x0B,0x1A,0xE8,0x08,0x0C,0x08,0x00,0x00},
  19. {0x00,0x20,0x20,0x20,0x20,0x20,0x24,0xC2,0x7C,0x40,0x40,0x40,0x40,0x00,0x00,0x00}}};
  20. void yiwei(int i,int j,int k)
  21. {
  22. SBUF=mo[i][j][k];
  23. while(~TI){};
  24. TI=0;
  25. }
  26. void main() /*主函數*/
  27. {        int i=0,j=0,k=0,n,u;
  28.         SM0=0;
  29.         SM1=0;
  30.         ST=0;
  31.         TI=0;
  32.         yiwei(i,j,k);
  33.         n=0;
  34.         while(1)
  35.                 {for(i=0;i<6;i++)
  36.                  {yiwei(i,0,k);
  37.                  yiwei(i,1,k);
  38.                 }
  39.                 i=0;
  40.                 k++;
  41.                 if(k>15)
  42.                 k=0;
  43.         P2=n;
  44.                 E1=0;
  45.                 ST=1;
  46.                 for(u=0;u<150;u++){}
  47.
  48.                 n++;
  49.                 if(n>15)
  50.                 n=0;
  51.                 E1=1;
  52.                 ST=0;
  53.         }
  54. }
16*96點陣仿真工程文件及所有完整程序等資料下載地址:
http://m.raoushi.com/bbs/dpj-56304-1.html
ID:309376 發表于 2018-6-7 23:54 | 只看該作者
很不錯哦
ID:481880 發表于 2019-5-14 11:14 | 只看該作者
請問,你的字模是咋選的,找半天都沒有呀
ID:639698 發表于 2024-5-1 16:46 | 只看該作者
不錯,挺牛逼
