#include <reg52.h>
#include"intrins.h"
sbit rs =P2^0; // //數(shù)據(jù)\//指令//選擇
sbit rw =P2^1; // //讀\寫選擇
sbit en =P2^2; // 讀\寫使能
sbit cs1 =P2^4; // 片選1,低有效(前64列)
sbit cs2 =P2^5; // 片選2,低有效(后64列)
void lcdstate()
uchar lcd=0x00; /*設置初值為0,全部為低,方便后面的判忙*/
rs=0; /*根據(jù)時序圖拉低,選擇寫指令*/
rw=1; /*根據(jù)時序圖拉低,選擇寫模式*/
do
en=1; /*使能,使液晶輸出信號,檢查是否忙*/
_nop_();_nop_();_nop_();_nop_();/*延時4US*/
lcd=P0; /*把P0口的狀態(tài)值讀回來給lcd*/
en=0; /*使能端跳變*/;
}while(lcd&0x80); /*結果的高位保留,如果高位DB7為一,則表示忙*/
void delay(uchar ms)
{ uchar i;
uchar j;
for(i=0;i<100;i++)
for(j=0;j<ms;j++);
void write_command(uchar command)
lcdstate();
rs=0; //RS=0;為往MCU進行指令操作
rw=0; //RW=0;為往MCU寫入操作
en=0;
en=1;
P0=command;
en=0;
void write_data(uchar datas)
lcdstate();
rs=1;
rw=0;
en=0;
en=1;
P0=datas;
en=0;
void lcdinit()
delay(100); //
cs1=1;
cs2=1;
delay(100);
lcdstate(); //
write_command(0x3e); //
write_command(0xb8+0); //
write_command(0xc0+0); //
write_command(0x40+0); //
write_command(0x3f);
void clearScreen( )
{ uchar i,j;
lcdstate();
cs1=1;
cs2=1;
write_command(0x3f); //設置顯示開
write_command(0xb8); //Y 設置第0頁;
write_command(0x40); // 設置第0列
for(i=0;i<8;i++)
write_command(0xb8+i);
for(j=0;j<64;j++)
//write_command(0x40+j);
write_data(0x00);
unsigned char code jin[128]=
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xC0,0xF0,0xF8,0x7C,0x3C,0x7C,0xF8,0xE0,0xC0,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x20,0x60,0x70,0x78,0x38,0x3C,0x7E,0x6F,0x67,0x67,0x63,0x61,0xE0,0xE0,0xE0,0xE0,0x61,0x63,0x63,0x67,0x6F,0x7E,0x7E,0x1C,0x3C,0x38,0x78,0x78,0x10,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x18,0xD8,0xD8,0xD8,0x98,0x18,0x18,0xFF,0xFF,0xFF,0xFF,0x18,0x18,0x38,0xF8,0xD8,0xD8,0xD8,0x18,0x18,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x30,0x30,0x30,0x30,0x31,0x37,0x37,0x33,0x32,0x30,0x3F,0x3F,0x3F,0x3F,0x30,0x38,0x3F,0x3F,0x3F,0x33,0x30,0x30,0x30,0x30,0x30,0x00,0x00,0x00};/*"金",0*/
/* (32 X 32 , 黑體, 加粗 )*/
uchar code se[128]=
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xC0,0xF0,0xFC,0xFC,0xF8,0xC8,0xC8,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x10,0x30,0x38,0x3C,0xFE,0xFF,0xFF,0xF7,0x33,0x30,0x30,0x30,0x30,0xF0,0xF0,0xF8,0xFE,0x3F,0x3F,0x33,0x31,0x30,0xF0,0xF0,0xF0,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0x1C,0x1C,0x1C,0x1C,0x1C,0x1F,0x1F,0x1F,0x1F,0x1C,0x1C,0x1C,0x1C,0x1C,0x3F,0x3F,0x3F,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x07,0x1F,0x3F,0x3F,0x38,0x30,0x30,0x30,0x30,0x30,0x30,0x30,0x30,0x30,0x30,0x30,0x30,0x30,0x30,0x30,0x38,0x3E,0x1E,0x0C,0x00,0x00};/*"色",1*/
uchar code tong[128]=
{0x00,0x00,0x00,0x00,0x60,0x60,0x60,0x60,0x60,0x60,0x60,0xE0,0xE0,0x60,0x68,0x7C,0x7C,0x7C,0x60,0x60,0xE0,0xE0,0xE0,0x60,0x60,0x60,0x60,0x60,0x60,0x00,0x00,0x00,
0x00,0x00,0x00,0x04,0x04,0x04,0xE4,0xE4,0xE4,0x64,0x67,0x67,0x67,0x67,0x64,0xE4,0xE4,0xE4,0x64,0x67,0x67,0x67,0x65,0x64,0xE4,0xE4,0xE4,0x04,0x04,0x04,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0x3F,0x3F,0x32,0x32,0x32,0x32,0x32,0x32,0xFF,0xFF,0xFF,0x32,0x32,0x32,0x32,0x32,0x32,0x3F,0x3F,0x3F,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x30,0x30,0x33,0x33,0x33,0x33,0x33,0x33,0x33,0x33,0x33,0x33,0x3F,0x3F,0x3F,0x33,0x33,0x33,0x33,0x33,0x33,0x33,0x33,0x33,0x33,0x30,0x30,0x00,0x00};/*"童",2*/
uchar code nian[128]=
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xE0,0xF8,0xFC,0xFC,0x98,0x88,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x00,0x00,0x00,
0x00,0x00,0x20,0x30,0x78,0x7C,0x3F,0xDF,0xCF,0xC3,0xC1,0xC1,0xC1,0xC1,0xC1,0xC1,0xFF,0xFF,0xFF,0xFF,0xC1,0xC1,0xC1,0xC1,0xC1,0xC1,0xC1,0xC1,0x01,0x00,0x00,0x00,
0x00,0x00,0xC0,0xC0,0xC0,0xC0,0xC0,0xFF,0xFF,0xFF,0xFF,0xC0,0xC0,0xC0,0xC0,0xC0,0xFF,0xFF,0xFF,0xFF,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0x7F,0x7F,0x7F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};/*"年",3*/
void hz_display16(unsigned char pag, unsigned char col, unsigned char code *hzk)
uchar j=0;
uchar i=0;
for(j=0;j<4;j++) //這里寫四頁
write_command(0xb8+pag+j); //page在這里就是從page表示的這頁開始寫起。
write_command(0x40+col); //從列為col表示的列開始
for(i=0;i<32;i++) //這里寫32列
write_data(hzk[32*j+i]); //J為頁,I,為第J行第I個數(shù)
lcdinit();
clearScreen( );
delay(2);
// hz_display16(0,0,xms[]);
cs1=1;
cs2=0;
hz_display16(0,0,jin);
hz_display16(0,32,se);
cs1=0;cs2=1;
hz_display16(0,0,tong);
hz_display16(0,32,nian);
