查看: 2366|回復: 1
單片機時鐘程序
ID:139175 發表于 2016-9-12 13:20 | 只看該作者 回帖獎勵 |正序瀏覽 |閱讀模式
#include  <AT89X52.H> unsigned char dispbitcnt;  //數碼管位碼掃描變量
unsigned char second;   //秒變量
unsigned char  minite;   //分變量
unsigned char  hour;    //時變量
unsigned char  tcnt;    //秒信號產生變量
unsigned char mstcnt;   //掃描時間變量 const unsigned char dispcode[10]={0xc0,0xf9,0xa4,0xb0,0x99,<br>             0x92,0x82,0xf8,0x80,0x90};
            //0123456789段碼
const unsigned char dispbitcode[6]={0xfe,0xfd,0xfb,0xf7,<br>            0xef,0xdf};
          //123456位碼
unsigned char dispbuf[6]={0,0,0,0,0,0};
          //緩沖數組
//**************TMR0中斷數碼管掃描程序*********************
void Timer0() interrupt 1
{        P2=dispcode[dispbuf[dispbitcnt]];//段碼
   P1=dispbitcode[dispbitcnt];//位碼
  dispbitcnt++;
  if(dispbitcnt==6)
   {dispbitcnt=0;<br>   }
  tcnt++;      //中斷產生秒信號
  if(tcnt==244)
   {tcnt=0;<br>    second++;<br>    if(second==60)<br>      {second=0;<br>       minite++;<br>       if(minite==60)<br>        {minite=0;<br>         hour++;<br>         if(hour==24)<br>          {hour=0;<br>          }
     dispbuf[4]=second%10;    //得秒鐘的低位,送緩沖數組
     dispbuf[5]=second/10;     //得秒鐘的高位,送緩沖數組
     dispbuf[2]=minite%10;     //得分鐘的低位,送緩沖數組
     dispbuf[3]=minite/10;     //得分鐘的高位,送緩沖數組
     dispbuf[0]=hour%10;     //得時鐘的低位,送緩沖數組
     dispbuf[1]=hour/10;      //得時鐘的高位,送緩沖數組
TMOD=0x01;
TL0=0x10;
TH0=0xf0;  }
///****************1ms延時程序******************
void delay_1ms(unsigned char i)
unsigned char j;
for(i=0;i<144;i++)
for(j=0;j<144;j++);
} ///****************按鍵檢測*********************
void key_scan(void)
  if(P3_0==0)
   delay_1ms(20);
   if(P3_0==0)
    {second++;<br>     if(second==60)<br>       {second=0;<br>       }
    while(P3_0==0);
   if(P3_1==0)
    delay_1ms(20);
    if(P3_1==0)
      minite++;
      if(minite==60)
        {minite=0;<br>        }
     while(P3_1==0);
   if(P3_2==0)
    delay_1ms(20);
    if(P3_2==0)
      hour++;
      if(hour==24)
        hour=0;
     dispbuf[0]=hour%10;
     dispbuf[1]=hour/10;
     while(P3_2==0);
      //*************主程序********************
void main(void)
TMOD=0x01;TL0=0x10;
TH0=0xf0;
dispbitcnt=0;P1=0x00;      //開段碼
P2=0x00;      //開位碼
delay_1ms(200);    //延時
P2=0xff;      //關位碼EA=1;
ET0=1;
TR0=1;
key_scan();
ID:462433 發表于 2019-1-11 22:58 | 只看該作者
P3 是干嘛用的
