2016-9-9 02:01 上傳
2016-9-9 02:01 上傳
- 簡單菜單程序,八個按鍵.使用AVR單片機.2008/3/24--2008/3/29
- 編譯器為ICCAVR7.14.晶振7.3728M,單片機為ATmega16(用ATmega32在proteus中仿真不成功!)
- #include <iom16v.h>
- #include <macros.h>
- #include <stdio.h>
- #include "menu.h" //所有變量定義以及函數聲明均放在這個頭文件里.
- #include "delay.h"
- #include "lcd_12864.h"
- #include "get_key.h"
- #define blueon PORTB|=(1<<PORTB5)
- #define blueoff PORTB&=~(1<<PORTB5)
- #define greenon PORTB|=(1<<PORTB6)
- #define greenoff PORTB&=~(1<<PORTB6)
- #define redon PORTB|=(1<<PORTB7)
- #define redoff PORTB&=~(1<<PORTB7)
- //SFR初始化.
- void main_init(void)
- DDRA=0xff; //A口設置為輸出.
- PORTA=0x00;
- DDRB=0xff; //B口設置為輸出.
- PORTB=0x00;
- // ASSR&=~(1<<AS2);
- DDRC=0x00; //C口設置為輸入.
- PORTC=0xff; //AVR沒有上拉寄存器,在PORTC中寫1即表示打開上拉了.
- DDRD=0x00; //D口設置為輸入.
- PORTD=0xff; //打開D口上拉.
- void main_menu_initial(void) //LED主菜單初始化.
- main_menu[0].menu_count=3; //有三個菜單項.
- main_menu[0].display=blue;
- main_menu[0].subs=NULL; //點亮蘭燈
- main_menu[0].children_menus=blue_menu;
- main_menu[0].parent_menus=NULL;
- main_menu[1].menu_count=3;
- main_menu[1].display=green; //點亮綠燈
- main_menu[1].subs=NULL;
- main_menu[1].children_menus=green_menu;
- main_menu[1].parent_menus=NULL;
- main_menu[2].menu_count=3;
- main_menu[2].display=red; //點亮紅燈.
- main_menu[2].subs=openred;
- main_menu[2].children_menus=NULL;
- main_menu[2].parent_menus=NULL;
- void blue_menu_initial(void)
- blue_menu[0].menu_count=2;
- blue_menu[0].display=qr; //點亮蘭燈,確認.
- blue_menu[0].subs=openblue;
- blue_menu[0].children_menus=NULL;
- blue_menu[0].parent_menus=main_menu;
- blue_menu[1].menu_count=2;
- blue_menu[1].display=qx; //取消.
- blue_menu[1].subs=closeblue;
- blue_menu[1].children_menus=NULL;
- blue_menu[1].parent_menus=main_menu;
- void green_menu_initial(void)
- green_menu[0].menu_count=2;
- green_menu[0].display=qr; //點亮綠燈---確認.
- green_menu[0].subs=opengreen;
- green_menu[0].children_menus=NULL;
- green_menu[0].parent_menus=main_menu;
- green_menu[1].menu_count=2;
- green_menu[1].display=qx; //----取消.
- green_menu[1].subs=closegreen;
- green_menu[1].children_menus=NULL;
- green_menu[1].parent_menus=main_menu;
- void led_menu_pro(void)
- max_item=menu_led->menu_count;
- switch(keyval)
- case 0: break;
- case 1: //向上鍵.
- if(user_choosen==0)
- user_choosen=max_item;
- refresh=1;
- user_choosen--;
- break;
- case 2: //向下鍵.
- user_choosen++;
- if(user_choosen==max_item)
- user_choosen=0;
- refresh=1;
- break;
- case 3: //確認鍵.
- if(menu_led[user_choosen].subs!=NULL)
- (*menu_led[user_choosen].subs)(); //執行函數.
- if(menu_led[user_choosen].children_menus!=NULL)
- temp_choosen=user_choosen;
- menu_led=menu_led[user_choosen].children_menus;
- user_choosen=0;
- refresh=1;
- break;
- case 4: //返回鍵.
- if(menu_led[user_choosen].parent_menus!=NULL)
- menu_led=menu_led[user_choosen].parent_menus;
- refresh=1;
- break;
- default:
- break;
- if(refresh) //是否需要刷新LCD標志位.
- lcd_clr();
- refresh=0;
- led_menu_show();
- void led_menu_show(void)
- uchar n;
- if (max_item>=3) //菜單項為3則表示為主菜單.
- for(n=0;n<3;n++)
- /*使同一數組元素圖形寬度相同,即取最大的圖形寬度,這里取96,在數組賦值時也要注意*/
- draw_bmp(n*2,20,96,0,menu_led[n].display);
- select_item(user_choosen); //標記出當前菜單項.
- else
- switch(temp_choosen)
- case 0:
- draw_bmp(0,20,96,0,blue);
- break;
- case 1:
- draw_bmp(0,20,96,0,green);
- break;
- case 2:
- draw_bmp(0,20,96,0,red);
- break;
- default:
- break;
- for(n=0;n<max_item;n++)
- draw_bmp((n+1)*2,20,32,0,menu_led[n].display);
- select_item(user_choosen+1);
- void select_item(uchar n)
- draw_bmp(n*2,2,16,0,curflag);
- void openblue(void)
- blueon;
- greenoff;
- redoff;
- void opengreen(void)
- blueoff;
- greenon;
- redoff;
- void openred(void)
- blueoff;
- greenoff;
- redon;
- void closeblue(void)
- blueoff;
- void closegreen(void)
- greenoff;
- 主程序.
- void main(void)
- main_init();
- lcd_init();
- lcd_clr();
- draw_bmp(0,0,128,0,xtcsh); //函數調用形式為頁,列,寬度,數據指針.
- draw_bmp(2,8,72,0,writeby);
- draw_bmp(4,56,32,1,jiangping);
- blueon;
- greenon;
- redon;
- delay_ms(3000); //延時3秒.
- lcd_clr();
- blueoff;
- greenoff;
- redoff;
- main_menu_initial();
- blue_menu_initial();
- green_menu_initial();
- while(1)
- keyval=get_key(); //讀鍵.
- led_menu_pro();
