查看: 3569|回復: 0
12864液晶(圖片切換“轉”)程序
ID:137190 發表于 2016-9-4 17:57 | 顯示全部樓層 |閱讀模式
完整資料下載:
12864(圖片切換“轉”).zip (49.62 KB, 下載次數: 26)
51單片機驅動12864液晶實現圖片的切換與轉換程序:
  1. //  11.0592M 的晶振
  2. //  P0  口為數據口
  3. #include<reg52.h>
  4. #include<string.h>
  5. #define uchar unsigned char
  6. #define uint unsigned int
  7. sbit RS=P2^0;//        指令數據選擇。高數據。低指令
  8. sbit RW=P2^1;//        讀寫選擇。高讀。低寫
  9. sbit E=P2^2; //        使能。高有效
  10. sbit PSB=P2^3;//高為并行。低為串行
  11. sbit RST=P2^5;//低電平復位
  12. /*
  13. code uchar table[]="I'm a student!";
  14. code uchar mm[]="I like MCU!";
  15. code uchar nn[]="劉謙";        //一個算兩個字符   */
  16. uchar code bmp0[64][16]={
  17. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xFF,0xFC,0x00},
  18. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x3F,0xFF,0xBC,0x00},
  19. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xFF,0xFC,0x80,0x00},
  20. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0xFF,0xF8,0x00,0x00},
  21. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xF8,0x10,0x00},
  22. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFC,0x10,0x00},
  23. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xFF,0xFF,0xFF,0x5B,0xB0},
  24. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF},
  25. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF},
  26. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF},
  27. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF},
  28. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF},
  29. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF},
  30. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  31. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  32. {0x00,0x00,0x00,0x00,0x18,0x30,0x00,0x00,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  33. {0x00,0x00,0x00,0x00,0x10,0x30,0x00,0x00,0x00,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  34. {0x00,0x00,0x00,0x00,0x30,0x20,0x00,0x00,0x00,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  35. {0x00,0x00,0x00,0x03,0xFC,0xF0,0x00,0x00,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  36. {0x00,0x00,0x00,0x00,0x40,0x20,0x00,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  37. {0x00,0x00,0x00,0x00,0x90,0x27,0xC0,0x00,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  38. {0x00,0x00,0x00,0x01,0x93,0xFC,0x00,0x00,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  39. {0x00,0x00,0x00,0x01,0x10,0x20,0x00,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  40. {0x00,0x00,0x00,0x03,0xFC,0x3C,0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  41. {0x00,0x00,0x00,0x00,0x10,0x06,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  42. {0x00,0x00,0x00,0x00,0x10,0x84,0x00,0x00,0x00,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  43. {0x00,0x00,0x00,0x03,0xFC,0x2C,0x00,0x00,0x00,0x37,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  44. {0x00,0x00,0x00,0x00,0x10,0x38,0x00,0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  45. {0x00,0x00,0x00,0x00,0x10,0x10,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  46. {0x00,0x00,0x00,0x00,0x10,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  47. {0x00,0x00,0x00,0x00,0x10,0x06,0x00,0x00,0x00,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF},
  48. {0x00,0x00,0x00,0x00,0x00,0x02,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  49. {0x00,0x00,0x00,0x00,0x00,0x03,0x00,0x00,0x00,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF},
  50. {0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x00,0x00,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF},
  51. {0x00,0x00,0x00,0x00,0x00,0x01,0x80,0x00,0x00,0x00,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF},
  52. {0x00,0x00,0x00,0x00,0x00,0x01,0x80,0x00,0x00,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF},
  53. {0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x00,0x00,0x00,0x3F,0x0F,0xFF,0xFF,0xFF,0xBF},
  54. {0x00,0x00,0x00,0x00,0x00,0x0F,0xE0,0x00,0x00,0x00,0x7F,0x4F,0xFF,0xFF,0xFF,0xFF},
  55. {0x00,0x00,0x00,0x00,0x00,0x3F,0xF8,0x00,0x00,0x00,0xFF,0x0F,0xFF,0xFF,0xFF,0xFF},
  56. {0x00,0x00,0x00,0x00,0x00,0x3F,0xFC,0x00,0x00,0x00,0x7F,0x0F,0xFF,0xFF,0xFF,0xBF},
  57. {0x00,0x00,0x00,0x00,0x00,0xFF,0xFE,0x00,0x00,0x00,0xFF,0x07,0xFF,0x7F,0xFF,0xFF},
  58. {0x00,0x00,0x00,0x00,0x03,0xFF,0xFE,0x00,0x00,0x00,0x7F,0x01,0xCF,0x7F,0xFF,0xFF},
  59. {0x00,0x00,0x00,0x00,0x01,0xFF,0xFF,0x00,0x00,0x01,0xFF,0x10,0x00,0xFF,0xFF,0xFF},
  60. {0x00,0x00,0x00,0x00,0x00,0x7F,0xFF,0x00,0x00,0x00,0xFF,0x03,0x87,0xFF,0xFF,0xFF},
  61. {0x00,0x00,0x00,0x00,0x00,0x3F,0xFF,0x80,0x00,0x01,0xFF,0x1F,0xC7,0xFF,0xFF,0xFF},
  62. {0x00,0x00,0x00,0x00,0x00,0x3F,0xFF,0x80,0x00,0x03,0xFD,0x1F,0xC7,0xFF,0xFF,0xFF},
  63. {0x00,0x00,0x00,0x00,0x00,0x1F,0xFF,0x80,0x00,0x01,0xFC,0x3F,0xFF,0xFF,0xFF,0xFF},
  64. {0x00,0x00,0x00,0x00,0x00,0x0F,0xFF,0xC0,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  65. {0x00,0x00,0x00,0x00,0x00,0x07,0xFF,0x80,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  66. {0x00,0x00,0x00,0x00,0x00,0x07,0xFF,0xC0,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  67. {0x00,0x00,0x00,0x00,0x00,0x03,0xFF,0x00,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  68. {0x00,0x00,0x00,0x00,0x00,0x01,0x3F,0xC0,0x10,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  69. {0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0xFF,0x02,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  70. {0x00,0x00,0x00,0x00,0x00,0x00,0x47,0xFF,0x00,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  71. {0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0xFF,0xFF,0xDF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  72. {0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  73. {0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  74. {0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  75. {0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  76. {0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  77. {0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  78. {0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  79. {0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xE7,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  80. {0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xEF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  81. };
  82. uchar code bmp1[64][16]={
  83. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0x75,0x8C},
  84. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x15,0xFE,0x73,0x82},
  85. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xC9,0x1A},
  86. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x2F,0xFF,0xFE,0x40,0x08},
  87. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0xFF,0xFF,0xD8,0x08},
  88. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xFF,0xFF,0xFF,0x60,0x00},
  89. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0D,0xFF,0xFF,0xFF,0xE0,0x00},
  90. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xFF,0xFF,0xFF,0xF8,0x00},
  91. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0xFF,0xFF,0xFF,0xF8,0x09},
  92. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xFF,0xFF,0xFF,0xFE,0x2B},
  93. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xFF,0xFF,0xFF,0xFE,0x7F},
  94. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  95. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  96. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  97. {0x00,0x00,0x00,0x00,0x0C,0x40,0x00,0x00,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  98. {0x00,0x00,0x00,0x00,0x07,0xC0,0x00,0x00,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  99. {0x00,0x00,0x00,0x00,0x7F,0x00,0x00,0x00,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  100. {0x00,0x00,0x00,0x00,0x61,0x80,0x00,0x00,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  101. {0x00,0x00,0x00,0x06,0x34,0xC0,0x00,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  102. {0x00,0x00,0x00,0x03,0x1C,0x00,0x00,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  103. {0x00,0x00,0x00,0x01,0x3E,0x11,0x80,0x00,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  104. {0x00,0x00,0x00,0x01,0xE2,0x1F,0x00,0x00,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  105. {0x00,0x00,0x00,0x01,0xE1,0x8E,0x00,0x00,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  106. {0x00,0x00,0x00,0x03,0x20,0xFB,0x00,0x00,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  107. {0x00,0x00,0x00,0x0E,0x18,0xF0,0x00,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  108. {0x00,0x00,0x00,0x08,0x0D,0x9C,0x00,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  109. {0x00,0x00,0x00,0x00,0x01,0xE6,0x00,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  110. {0x00,0x00,0x00,0x00,0x00,0x30,0x00,0x00,0x00,0x37,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  111. {0x00,0x00,0x00,0x00,0x17,0xF0,0x00,0x00,0x00,0x0D,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  112. {0x00,0x00,0x00,0x00,0x1F,0x80,0x00,0x00,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  113. {0x00,0x00,0x00,0x00,0x0C,0x80,0x00,0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  114. {0x00,0x00,0x00,0x00,0x0E,0x60,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  115. {0x00,0x00,0x00,0x00,0x00,0x30,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  116. {0x00,0x00,0x00,0x00,0x00,0x18,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  117. {0x00,0x00,0x00,0x00,0x00,0x0C,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  118. {0x00,0x00,0x00,0x00,0x00,0x06,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  119. {0x00,0x00,0x00,0x00,0x00,0x03,0x80,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  120. {0x00,0x00,0x00,0x00,0x01,0xFE,0x00,0x00,0x00,0x00,0xFF,0x9F,0xFF,0xFF,0xFF,0xFF},
  121. {0x00,0x00,0x00,0x00,0x03,0xFF,0xA0,0x00,0x00,0x00,0xFF,0x0F,0xFF,0xFF,0xFF,0xFF},
  122. {0x00,0x00,0x00,0x00,0x07,0xFF,0xD0,0x00,0x00,0x00,0xFF,0xCF,0xFF,0xFF,0xFF,0xFF},
  123. {0x00,0x00,0x00,0x00,0x07,0xFF,0xF0,0x00,0x00,0x00,0xFF,0x4F,0xFF,0xFF,0xFF,0xFF},
  124. {0x00,0x00,0x00,0x00,0x07,0xFF,0xF8,0x00,0x00,0x00,0xFF,0x47,0xFF,0xFF,0xFF,0xFF},
  125. {0x00,0x00,0x00,0x00,0x0F,0xFF,0xF8,0x00,0x00,0x00,0x3F,0x80,0xFF,0xFF,0xFF,0xFF},
  126. {0x00,0x00,0x00,0x00,0x05,0x7F,0xFC,0x00,0x00,0x00,0x3E,0x00,0xFF,0xFF,0xFF,0xFF},
  127. {0x00,0x00,0x00,0x00,0x00,0x7F,0xFC,0x00,0x00,0x00,0x3E,0x87,0x7F,0xFF,0xFF,0xFF},
  128. {0x00,0x00,0x00,0x00,0x04,0x7F,0xFE,0x00,0x00,0x01,0xFE,0x81,0x7F,0xFF,0xFF,0xFF},
  129. {0x00,0x00,0x00,0x00,0x01,0xFF,0xFE,0x00,0x00,0x03,0xFF,0x01,0xFF,0xFF,0xFF,0xFF},
  130. {0x00,0x00,0x00,0x00,0x00,0xDF,0xFF,0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  131. {0x00,0x00,0x00,0x00,0x00,0x17,0xFF,0x00,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  132. {0x00,0x00,0x00,0x00,0x00,0x07,0xFF,0x00,0x00,0x04,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF},
  133. {0x00,0x00,0x00,0x00,0x00,0x01,0x7F,0x80,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  134. {0x00,0x00,0x00,0x00,0x00,0x01,0xBF,0x80,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  135. {0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFE,0x00,0x17,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  136. {0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0xFE,0x00,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  137. {0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  138. {0x00,0x00,0x00,0x00,0x00,0x00,0x13,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  139. {0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  140. {0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  141. {0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  142. {0x00,0x00,0x00,0x00,0x00,0x00,0x05,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  143. {0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  144. {0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  145. {0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  146. {0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xEF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  147. };
  148. uchar code bmp2[64][16]={
  149. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xF0,0x00},
  150. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0C,0xFF,0xBF,0x00},
  151. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x7F,0xFC,0x80,0x00},
  152. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0xFF,0xF8,0x00,0x00},
  153. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xFF,0xF8,0x10,0x00},
  154. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xFF,0xFF,0xFC,0x10,0x00},
  155. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xFF,0xFF,0xFF,0x5B,0xB0},
  156. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF},
  157. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF},
  158. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF},
  159. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  160. {0x00,0x00,0x00,0x00,0x10,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  161. {0x00,0x00,0x00,0x00,0x18,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  162. {0x00,0x00,0x00,0x00,0x9C,0x80,0x00,0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  163. {0x00,0x00,0x00,0x00,0x96,0x80,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  164. {0x00,0x00,0x00,0x00,0x91,0x80,0x00,0x00,0x00,0x05,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  165. {0x00,0x00,0x00,0x00,0x91,0xC0,0x00,0x00,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  166. {0x00,0x00,0x00,0x00,0x90,0xA0,0x00,0x00,0x00,0x6F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  167. {0x00,0x00,0x00,0x0F,0xFE,0x80,0x00,0x00,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  168. {0x00,0x00,0x00,0x00,0x90,0x80,0x00,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  169. {0x00,0x00,0x00,0x00,0xA4,0x00,0x00,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  170. {0x00,0x00,0x00,0x00,0x3C,0x80,0x00,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  171. {0x00,0x00,0x00,0x00,0x26,0x80,0x00,0x00,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  172. {0x00,0x00,0x00,0x01,0xA5,0x80,0x00,0x00,0x6F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  173. {0x00,0x00,0x00,0x03,0x24,0xE0,0x00,0x00,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  174. {0x00,0x00,0x00,0x07,0x24,0x80,0x00,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  175. {0x00,0x00,0x00,0x0D,0xE4,0x80,0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  176. {0x00,0x00,0x00,0x00,0x64,0x00,0x00,0x00,0x00,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  177. {0x00,0x00,0x00,0x00,0x24,0x18,0x00,0x00,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  178. {0x00,0x00,0x00,0x00,0x20,0x18,0x00,0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  179. {0x00,0x00,0x00,0x00,0x00,0x0C,0x00,0x00,0x00,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF},
  180. {0x00,0x00,0x00,0x00,0x00,0x06,0x00,0x00,0x00,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF},
  181. {0x00,0x00,0x00,0x00,0x00,0x03,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  182. {0x00,0x00,0x00,0x00,0x00,0x01,0x80,0x00,0x00,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF},
  183. {0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x00,0x00,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF},
  184. {0x00,0x00,0x00,0x00,0x00,0x3F,0xA0,0x00,0x00,0x00,0xFF,0xEF,0xFF,0xFF,0xFF,0xDF},
  185. {0x00,0x00,0x00,0x00,0x00,0xFF,0x90,0x00,0x00,0x00,0xFF,0xEF,0xFF,0xFF,0xFF,0xFF},
  186. {0x00,0x00,0x00,0x00,0x03,0xFF,0xF0,0x00,0x00,0x00,0xFF,0x1F,0xFF,0xFF,0xFF,0xCF},
  187. {0x00,0x00,0x00,0x00,0x07,0xFF,0xF0,0x00,0x00,0x00,0x7F,0x1F,0xFF,0xFF,0xFF,0xFF},
  188. {0x00,0x00,0x00,0x00,0x03,0xFF,0xF8,0x00,0x00,0x00,0xFE,0x0F,0xFF,0xFF,0xFE,0x1F},
  189. {0x00,0x00,0x00,0x00,0x01,0xFF,0xF8,0x00,0x00,0x00,0x7F,0x1F,0xFF,0xFF,0xFE,0x3F},
  190. {0x00,0x00,0x00,0x00,0x01,0xFF,0xFC,0x00,0x00,0x00,0xFF,0x07,0xFF,0xFF,0xFF,0xFF},
  191. {0x00,0x00,0x00,0x00,0x01,0xFF,0xF8,0x00,0x00,0x00,0x3F,0x11,0xFF,0xFF,0xFF,0xFF},
  192. {0x00,0x00,0x00,0x00,0x00,0xFF,0xFC,0x00,0x00,0x00,0x3E,0x00,0xFF,0xFF,0xFF,0xFF},
  193. {0x00,0x00,0x00,0x00,0x00,0x7F,0xFC,0x00,0x00,0x01,0xFF,0x00,0x7F,0xFF,0xFF,0xFF},
  194. {0x00,0x00,0x00,0x00,0x00,0x3F,0xFF,0x00,0x00,0x00,0xFF,0x00,0x7F,0xFF,0xFF,0xFF},
  195. {0x00,0x00,0x00,0x00,0x00,0x1F,0xFF,0x80,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  196. {0x00,0x00,0x00,0x00,0x00,0x0F,0xFF,0xC0,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  197. {0x00,0x00,0x00,0x00,0x00,0x07,0xFF,0xC0,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  198. {0x00,0x00,0x00,0x00,0x00,0x02,0xFF,0xF0,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  199. {0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0xFA,0x00,0x0B,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  200. {0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0xFC,0x48,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE},
  201. {0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0xFF,0x00,0x17,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  202. {0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0xFF,0xF8,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  203. {0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  204. {0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  205. {0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  206. {0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  207. {0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  208. {0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  209. {0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  210. {0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  211. {0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  212. {0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  213. };
  214. uchar code bmp3[64][16]={
  215. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFC,0x00},
  216. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0xFF,0xFF,0xBF,0x80},
  217. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xFF,0xFF,0xFC,0x80,0x00},
  218. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xFF,0xFF,0xF8,0x00,0x04},
  219. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xFF,0xFF,0xF8,0x10,0x00},
  220. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0xFF,0xFF,0xFC,0x10,0x00},
  221. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0xFF,0xFF,0xFF,0x5B,0xB0},
  222. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  223. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  224. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  225. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  226. {0x00,0x00,0x00,0x00,0x04,0x00,0x00,0x00,0x00,0x05,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  227. {0x00,0x00,0x00,0x00,0x06,0x18,0x00,0x00,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  228. {0x00,0x00,0x00,0x00,0x02,0x30,0x00,0x00,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  229. {0x00,0x00,0x00,0x00,0x03,0x66,0x00,0x00,0x00,0x2F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  230. {0x00,0x00,0x00,0x00,0x01,0xCE,0x00,0x00,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  231. {0x00,0x00,0x00,0x00,0x01,0x9A,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  232. {0x00,0x00,0x00,0x00,0x02,0xD2,0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  233. {0x00,0x00,0x00,0x00,0x02,0x63,0x80,0x00,0x17,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  234. {0x00,0x00,0x00,0x00,0x04,0x53,0x00,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  235. {0x00,0x00,0x00,0x00,0x04,0x86,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  236. {0x00,0x00,0x00,0x3C,0x29,0x86,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  237. {0x00,0x00,0x00,0x18,0xE0,0x1A,0x00,0x80,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  238. {0x00,0x00,0x00,0x09,0xB4,0x02,0x00,0xC0,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  239. {0x00,0x00,0x00,0x0B,0x1C,0x02,0x00,0xC0,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  240. {0x00,0x00,0x00,0x0E,0x38,0x80,0x00,0xC0,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  241. {0x00,0x00,0x00,0x0C,0x68,0x80,0x00,0xC0,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  242. {0x00,0x00,0x00,0x00,0x4D,0x80,0x00,0xC0,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  243. {0x00,0x00,0x00,0x00,0x87,0x00,0x00,0xC0,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  244. {0x00,0x00,0x00,0x00,0x86,0x00,0x01,0xC0,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  245. {0x00,0x00,0x00,0x01,0x07,0x00,0x01,0xC0,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  246. {0x00,0x00,0x00,0x00,0x0D,0x00,0x01,0x40,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  247. {0x00,0x00,0x00,0x00,0x11,0x80,0x01,0xC0,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  248. {0x00,0x00,0x00,0x00,0x00,0x03,0xFF,0xC0,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  249. {0x00,0x00,0x00,0x00,0x00,0x07,0xFF,0xC0,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  250. {0x00,0x00,0x00,0x00,0x00,0x0F,0xFF,0xC0,0x00,0x00,0xFF,0x9F,0xFF,0xFF,0xFF,0xFF},
  251. {0x00,0x00,0x00,0x00,0x00,0x3F,0xFF,0xC0,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  252. {0x00,0x00,0x00,0x00,0x00,0x7F,0xFF,0xC0,0x00,0x01,0xFE,0x3F,0xFF,0xFF,0xFF,0xFF},
  253. {0x00,0x00,0x00,0x00,0x00,0x3F,0xFF,0xC0,0x00,0x01,0xFE,0x1F,0xFF,0xFF,0xFF,0xFF},
  254. {0x00,0x00,0x00,0x00,0x00,0x0F,0xFE,0xC0,0x00,0x01,0xFE,0x1F,0xFF,0xFF,0xFF,0xFF},
  255. {0x00,0x00,0x00,0x00,0x00,0x0F,0xFF,0xC0,0x00,0x01,0xFE,0x1F,0xFF,0xFF,0xFF,0xFF},
  256. {0x00,0x00,0x00,0x00,0x00,0x0F,0xFF,0x80,0x00,0x01,0xFC,0x8F,0xFF,0xFF,0xFF,0xFF},
  257. {0x00,0x00,0x00,0x00,0x00,0x07,0xFF,0x00,0x00,0x00,0xFE,0x0F,0xFF,0xFF,0xFF,0xFF},
  258. {0x00,0x00,0x00,0x00,0x00,0x0F,0xFF,0x00,0x00,0x00,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF},
  259. {0x00,0x00,0x00,0x00,0x00,0x07,0xFE,0x00,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  260. {0x00,0x00,0x00,0x00,0x00,0x03,0xFE,0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  261. {0x00,0x00,0x00,0x00,0x00,0x00,0xFD,0x00,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  262. {0x00,0x00,0x00,0x00,0x00,0x03,0xFF,0xF0,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  263. {0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xE8,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  264. {0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xD4,0x00,0x0B,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  265. {0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xF9,0x00,0x17,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  266. {0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFE,0x94,0x1B,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  267. {0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xBF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  268. {0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xFF,0xFF,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  269. {0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  270. {0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  271. {0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  272. {0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  273. {0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  274. {0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  275. {0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  276. {0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  277. {0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  278. {0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  279. };
  280. uchar code bmp4[64][16]={
  281. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xFF,0xFF,0xF0,0x00},
  282. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xBC,0x00},
  283. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0xFF,0xFF,0xFC,0x80,0x00},
  284. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x2F,0xFF,0xFF,0xF8,0x00,0x00},
  285. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xFF,0xFF,0xF8,0x10,0x00},
  286. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xFF,0xFF,0xFC,0x10,0x02},
  287. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0x5B,0xB0},
  288. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  289. {0x00,0x00,0x00,0x00,0x04,0x00,0x00,0x00,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  290. {0x00,0x00,0x00,0x00,0x06,0x00,0x00,0x00,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  291. {0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  292. {0x00,0x00,0x00,0x00,0xC2,0x00,0x00,0x00,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  293. {0x00,0x00,0x00,0x04,0x73,0x00,0x00,0x00,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  294. {0x00,0x00,0x00,0x06,0x10,0x00,0x00,0x00,0x00,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  295. {0x00,0x00,0x00,0x03,0x30,0x00,0x00,0x00,0x01,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  296. {0x00,0x00,0x00,0x21,0xE0,0x00,0x00,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  297. {0x00,0x00,0x00,0x13,0x80,0x00,0x00,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  298. {0x00,0x00,0x00,0x0E,0xC0,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  299. {0x00,0x00,0x00,0x1C,0x61,0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  300. {0x00,0x00,0x00,0x76,0x20,0x82,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  301. {0x00,0x00,0x00,0x42,0x00,0x4C,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  302. {0x00,0x00,0x00,0x02,0x06,0x38,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  303. {0x00,0x00,0x00,0x00,0x02,0xF0,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  304. {0x00,0x00,0x00,0x00,0x43,0x18,0x00,0x00,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  305. {0x00,0x00,0x00,0x00,0x35,0xCC,0x00,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  306. {0x00,0x00,0x00,0x00,0x10,0x44,0x00,0x00,0x11,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  307. {0x00,0x00,0x00,0x00,0x18,0x62,0x00,0x00,0x40,0x2F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  308. {0x00,0x00,0x00,0x00,0x7F,0xE0,0x00,0x00,0xC0,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  309. {0x00,0x00,0x00,0x00,0x86,0x30,0x00,0x01,0xC0,0x0B,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  310. {0x00,0x00,0x00,0x00,0x02,0x00,0x00,0x01,0x80,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  311. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  312. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x06,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  313. {0x00,0x00,0x00,0x00,0x00,0x00,0x16,0x1E,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  314. {0x00,0x00,0x00,0x00,0x00,0x00,0xBF,0x9C,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  315. {0x00,0x00,0x00,0x00,0x00,0x01,0xFF,0xF8,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  316. {0x00,0x00,0x00,0x00,0x00,0x0F,0xFF,0xF8,0x00,0x07,0xFC,0xFF,0xFF,0xFF,0xFF,0xFF},
  317. {0x00,0x00,0x00,0x00,0x00,0x1F,0xFF,0xF0,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  318. {0x00,0x00,0x00,0x00,0x00,0x1F,0xFF,0xE0,0x00,0x03,0xE8,0x07,0xFF,0xFF,0xFF,0xFF},
  319. {0x00,0x00,0x00,0x00,0x00,0x0F,0xFF,0xF0,0x00,0x03,0xF8,0x03,0xFF,0xFF,0xFF,0xFF},
  320. {0x00,0x00,0x00,0x00,0x00,0x0F,0xFF,0xF8,0x00,0x07,0xFC,0x03,0xFF,0xFF,0xFF,0xFF},
  321. {0x00,0x00,0x00,0x00,0x00,0x07,0xFF,0xF8,0x00,0x07,0xFC,0x83,0x7F,0xFF,0xFF,0xFF},
  322. {0x00,0x00,0x00,0x00,0x00,0x07,0xFF,0xF8,0x00,0x07,0xF8,0x02,0x7F,0xFF,0xFF,0xFF},
  323. {0x00,0x00,0x00,0x00,0x00,0x03,0xFF,0xF8,0x00,0x02,0xFC,0x03,0x7F,0xFF,0xFF,0xFF},
  324. {0x00,0x00,0x00,0x00,0x00,0x03,0xFF,0xF0,0x00,0x02,0x7D,0x07,0x7F,0xFF,0xFF,0xFF},
  325. {0x00,0x00,0x00,0x00,0x00,0x01,0xFF,0xF0,0x00,0x03,0xFB,0xFF,0x7F,0xFF,0xFF,0xFF},
  326. {0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xF0,0x00,0x03,0x78,0x07,0xFF,0xFF,0xFF,0xFF},
  327. {0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xE0,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  328. {0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xF0,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  329. {0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xF0,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  330. {0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0xE0,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  331. {0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0xE0,0x00,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  332. {0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0xE0,0x00,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  333. {0x00,0x00,0x00,0x00,0x00,0x00,0x0B,0xE0,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  334. {0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xFF,0xC7,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  335. {0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xFF,0xFC,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  336. {0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  337. {0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  338. {0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  339. {0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  340. {0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  341. {0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  342. {0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  343. {0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  344. {0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  345. };
  346. uchar code bmp5[64][16]={
  347. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0xFF,0xFF,0xE0,0x00},
  348. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xFF,0xFF,0xFF,0xB8,0x00},
  349. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xFF,0xFF,0xFC,0x80,0x00},
  350. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0xFF,0xFF,0xF8,0x00,0x00},
  351. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x02,0xFF,0xFF,0xFF,0xF8,0x10,0x00},
  352. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFC,0x10,0x00},
  353. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0x5B,0xB4},
  354. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8},
  355. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8},
  356. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8},
  357. {0x00,0x00,0x00,0x03,0x08,0x00,0x00,0x00,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  358. {0x00,0x00,0x00,0x01,0xB8,0x00,0x00,0x00,0x00,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  359. {0x00,0x00,0x00,0x00,0xE0,0x00,0x00,0x00,0x01,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  360. {0x00,0x00,0x00,0x00,0xC3,0x00,0x00,0x00,0x08,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  361. {0x00,0x00,0x00,0x03,0xE2,0x00,0x00,0x00,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  362. {0x00,0x00,0x00,0x02,0x26,0x10,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  363. {0x00,0x00,0x04,0x00,0x3C,0x30,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  364. {0x00,0x00,0x06,0x60,0x38,0x70,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  365. {0x00,0x00,0x02,0xC0,0x6C,0xD0,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  366. {0x00,0x00,0x03,0x80,0xC7,0x90,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  367. {0x00,0x00,0x01,0x84,0x06,0x10,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  368. {0x00,0x00,0x03,0x0C,0x06,0x30,0x00,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  369. {0x00,0x00,0x05,0x78,0xC0,0x20,0x00,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  370. {0x00,0x00,0x0D,0x31,0x80,0x78,0x00,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  371. {0x00,0x00,0x01,0x53,0x00,0xF0,0x00,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  372. {0x00,0x00,0x01,0xDE,0x00,0x00,0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  373. {0x00,0x00,0x01,0x8E,0x00,0x00,0x00,0x18,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  374. {0x00,0x00,0x01,0x1B,0x00,0x00,0x00,0x38,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  375. {0x00,0x00,0x00,0x31,0x80,0x00,0x00,0x70,0x00,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  376. {0x00,0x00,0x00,0x60,0xC0,0x00,0x00,0xE0,0x00,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  377. {0x00,0x00,0x00,0xC0,0x00,0x00,0x01,0xC0,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  378. {0x00,0x00,0x00,0x00,0x00,0x00,0x03,0x80,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  379. {0x00,0x00,0x00,0x00,0x00,0x00,0x07,0x00,0x00,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  380. {0x00,0x00,0x00,0x00,0x00,0x00,0x2E,0x00,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  381. {0x00,0x00,0x00,0x00,0x00,0x03,0xFE,0x80,0x00,0x0F,0xFB,0xFF,0xFF,0xFF,0xFF,0xFF},
  382. {0x00,0x00,0x00,0x00,0x00,0x0F,0xFC,0x00,0x00,0x0F,0xFB,0xFF,0xFF,0xFF,0xFF,0xFF},
  383. {0x00,0x00,0x00,0x00,0x00,0x0F,0xFA,0x00,0x00,0x0F,0xF0,0x1F,0xFF,0xFF,0xFF,0xFF},
  384. {0x00,0x00,0x00,0x00,0x00,0x1F,0xFE,0x00,0x00,0x0F,0xE0,0x0F,0xFF,0xFF,0xFF,0xFF},
  385. {0x00,0x00,0x00,0x00,0x00,0x3F,0xF8,0x00,0x00,0x0F,0xF0,0x0F,0xFF,0xFF,0xFF,0xFF},
  386. {0x00,0x00,0x00,0x00,0x00,0x7F,0xFE,0x00,0x00,0x0F,0xE0,0x0D,0xFF,0xFF,0xFF,0xFF},
  387. {0x00,0x00,0x00,0x00,0x00,0x3F,0xFA,0x00,0x00,0x0F,0xE0,0x0C,0xFF,0xFF,0xFF,0xFF},
  388. {0x00,0x00,0x00,0x00,0x00,0x1F,0xFC,0x00,0x00,0x0F,0xE0,0x0C,0xFF,0xFF,0xFF,0xFF},
  389. {0x00,0x00,0x00,0x00,0x00,0x3F,0xFE,0x00,0x00,0x0D,0xF3,0x0C,0xFF,0xFF,0xFF,0xFF},
  390. {0x00,0x00,0x00,0x00,0x00,0x37,0xFE,0x00,0x00,0x0D,0xFF,0xFC,0xFF,0xFF,0xFF,0xFF},
  391. {0x00,0x00,0x00,0x00,0x00,0x1F,0xFD,0x00,0x00,0x0D,0xE0,0x1F,0xFF,0xFF,0xFF,0xFF},
  392. {0x00,0x00,0x00,0x00,0x00,0x0F,0xFC,0x80,0x00,0x17,0xFF,0x1F,0xFF,0xFF,0xFF,0xFF},
  393. {0x00,0x00,0x00,0x00,0x00,0x07,0xFF,0x80,0x00,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  394. {0x00,0x00,0x00,0x00,0x00,0x03,0xFF,0xC0,0x00,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  395. {0x00,0x00,0x00,0x00,0x00,0x03,0xFF,0x90,0x00,0x21,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  396. {0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xE0,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  397. {0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xE4,0x00,0x2F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  398. {0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0xD4,0x90,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  399. {0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0xDF,0x05,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  400. {0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0xFF,0xC1,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  401. {0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xFF,0xFC,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  402. {0x00,0x00,0x00,0x00,0x00,0x00,0x0B,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  403. {0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  404. {0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  405. {0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xFB,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  406. {0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xFB,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  407. {0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xFB,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  408. {0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xFB,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  409. {0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xF9,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  410. {0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  411. };
  412. uchar code bmp6[64][16]={
  413. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xBF,0xFF,0xF8,0x00,0x00},
  414. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xFF,0xFF,0xF8,0x60,0x00},
  415. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x4F,0xFF,0xFF,0xFC,0x80,0x00},
  416. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xFF,0xFF,0xF0,0x00,0x00},
  417. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xF8,0x10,0x00},
  418. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFC,0x10,0x00},
  419. {0x00,0x00,0x00,0x00,0x08,0x00,0x00,0x00,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0x5B,0xB0},
  420. {0x00,0x00,0x00,0x00,0x0C,0x00,0x00,0x00,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xE8},
  421. {0x00,0x00,0x00,0x00,0x04,0x00,0x00,0x00,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC},
  422. {0x00,0x00,0x00,0x00,0x04,0x60,0x00,0x00,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8},
  423. {0x00,0x00,0x00,0x00,0x07,0xC0,0x00,0x00,0x00,0x27,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0},
  424. {0x00,0x00,0x00,0x20,0x06,0x00,0x00,0x00,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  425. {0x00,0x00,0x00,0x20,0x1C,0x1C,0x00,0x00,0x02,0x5F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  426. {0x00,0x00,0x00,0x31,0x16,0x70,0x00,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  427. {0x00,0x00,0x00,0x13,0x07,0x80,0x00,0x00,0x7B,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  428. {0x00,0x00,0x00,0x1E,0x03,0x06,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  429. {0x00,0x00,0x00,0x18,0x0E,0x1E,0x00,0x0B,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  430. {0x00,0x00,0x00,0x70,0x1A,0x36,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  431. {0x00,0x00,0x00,0xD4,0x53,0x64,0x00,0x0B,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC},
  432. {0x00,0x00,0x00,0x14,0xC1,0xCC,0x00,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8},
  433. {0x00,0x00,0x00,0x17,0x81,0x88,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8},
  434. {0x00,0x00,0x00,0x36,0x00,0x08,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC},
  435. {0x00,0x00,0x00,0x2F,0x08,0x18,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC},
  436. {0x00,0x00,0x00,0x39,0xF0,0x50,0x00,0x00,0x17,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE},
  437. {0x00,0x00,0x00,0x00,0xC0,0xF9,0x00,0x00,0x09,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC},
  438. {0x00,0x00,0x00,0x03,0xC0,0x3D,0x80,0x00,0x02,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE},
  439. {0x00,0x00,0x00,0x0E,0x60,0x01,0x80,0x00,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE},
  440. {0x00,0x00,0x00,0x18,0x20,0x01,0x80,0x00,0x00,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC},
  441. {0x00,0x00,0x00,0x10,0x30,0x00,0x80,0x00,0x00,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  442. {0x00,0x00,0x00,0x00,0x10,0x00,0xC0,0x00,0x00,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  443. {0x00,0x00,0x00,0x00,0x00,0x01,0xC0,0x00,0x00,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  444. {0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x00,0x00,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  445. {0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x00,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  446. {0x00,0x00,0x00,0x00,0x00,0x00,0x60,0x00,0x00,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  447. {0x00,0x00,0x00,0x00,0x00,0x3C,0x60,0x00,0x00,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  448. {0x00,0x00,0x00,0x00,0x00,0xFF,0xE0,0x00,0x00,0x1F,0xC7,0xFF,0xFF,0xFF,0xFF,0xFF},
  449. {0x00,0x00,0x00,0x00,0x03,0xFF,0xF0,0x00,0x00,0x1F,0xC1,0xFF,0xFF,0xFF,0xFF,0xFE},
  450. {0x00,0x00,0x00,0x00,0x05,0xFF,0xF8,0x00,0x00,0x1F,0x80,0x7F,0xFF,0xFF,0xFF,0xFE},
  451. {0x00,0x00,0x00,0x00,0x07,0xFF,0xFC,0x00,0x00,0x1F,0xC4,0x3F,0xFF,0xFF,0xFF,0xFE},
  452. {0x00,0x00,0x00,0x00,0x0D,0xFF,0xFC,0x00,0x00,0x3F,0x80,0x1F,0xFF,0xFF,0xFF,0xFE},
  453. {0x00,0x00,0x00,0x00,0x03,0xFF,0xF8,0x00,0x00,0x3F,0x80,0xFF,0xFF,0xFF,0xFF,0xFC},
  454. {0x00,0x00,0x00,0x00,0x01,0xFF,0xFC,0x00,0x00,0x47,0xC3,0xBF,0xFF,0xFF,0xFF,0xFE},
  455. {0x00,0x00,0x00,0x00,0x00,0xBF,0xFC,0x00,0x00,0x47,0xCF,0xFF,0xFF,0xFF,0xFF,0xFC},
  456. {0x00,0x00,0x00,0x00,0x00,0xFF,0xF8,0x00,0x00,0x6F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC},
  457. {0x00,0x00,0x00,0x00,0x00,0x7F,0xF0,0x00,0x00,0x7F,0xBF,0xFF,0xFF,0xFF,0xFF,0xFC},
  458. {0x00,0x00,0x00,0x00,0x00,0x7F,0xE0,0x00,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8},
  459. {0x00,0x00,0x00,0x00,0x00,0x1F,0xFC,0x00,0x00,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8},
  460. {0x00,0x00,0x00,0x00,0x00,0x0F,0xFE,0x00,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8},
  461. {0x00,0x00,0x00,0x00,0x00,0x07,0xFC,0x40,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0},
  462. {0x00,0x00,0x00,0x00,0x00,0x01,0xFF,0x80,0x00,0xBF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0},
  463. {0x00,0x00,0x00,0x00,0x00,0x03,0xFF,0x80,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0},
  464. {0x00,0x00,0x00,0x00,0x00,0x01,0xFF,0x84,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC},
  465. {0x00,0x00,0x00,0x00,0x00,0x00,0xDF,0x9C,0x05,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC},
  466. {0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xFF,0xC7,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC},
  467. {0x00,0x00,0x00,0x00,0x00,0x00,0x17,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF4},
  468. {0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0},
  469. {0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0},
  470. {0x00,0x00,0x00,0x00,0x00,0x00,0x05,0xEF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8},
  471. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8},
  472. {0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8},
  473. {0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC},
  474. {0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE},
  475. {0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  476. {0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFD},
  477. };
  478. void delay(uint z)
  479. {
  480.         uint x,y;
  481.         for(x=100;x>0;x--)
  482.                 for(y=z;y>0;y--);
  483. }
  484. uchar read();
  485. void write(bit,uchar);
  486. void initpicture();
  487. void initword();
  488. void distab(uchar *add);
  489. void dispic( uchar *add);
  490. void main()
  491. {
  492. while(1)
  493. {        initpicture();
  494.         dispic(&bmp0[0][0]);
  495.         delay(200);
  496.         dispic(&bmp1[0][0]);
  497.         delay(200);
  498.         dispic(&bmp2[0][0]);
  499.         delay(200);
  500.         dispic(&bmp3[0][0]);
  501.         delay(200);
  502.         dispic(&bmp4[0][0]);
  503.         delay(200);
  504.         dispic(&bmp5[0][0]);
  505.         delay(200);
  506.         dispic(&bmp6[0][0]);
  507.         delay(200);
  508. }
  509.
  510. }
  511. void initpicture()         //顯示圖片的初始化
  512. {
  513.         delay(60);        //開機延時40ms
  514.         RST=0;
  515.         RST=1;
  516.         PSB=1;           //并口
  517.         RW=0;
  518.         RS=0;
  519.         E=0;
  520. //初始化液晶
  521.         write(0,0x36);         //功能設定          8位數據,擴充指令集動作(0x36),繪圖開
  522.         delay(1);
  523.         write(0,0x36);
  524.         delay(1);
  525.         write(0,0x3e);         //顯示狀態          整體顯示開,游標開,游標位置反白關(后三位高開,低關)
  526.         delay(1);
  527.         write(0,0x01);         //清除顯示
  528.         delay(10);
  529. }
  530. void initword()                //顯示文字的初始化
  531. {
  532.         delay(60);        //開機延時40ms
  533.         RST=0;
  534.         RST=1;
  535.         PSB=1;           //并口
  536.         RW=0;
  537.         RS=0;
  538.         E=0;
  539.                  //初始化液晶
  540.         write(0,0x30);         //功能設定          8位數據,基本指令操作(0x30)
  541.         delay(1);
  542.         write(0,0x30);
  543.         delay(1);
  544.         write(0,0x0c);         //顯示狀態          整體顯示開,游標開,游標位置反白關(后三位高開,低關)
  545.         delay(1);
  546.         write(0,0x01);         //清除顯示
  547.         delay(10);
  548.         write(0,0x06);        //點設定     光標右移,整體顯示移動
  549. }
  550. void distab(uchar *add)         //文字顯示函數  (一維數組)
  551. {
  552.         uchar m,i;
  553.         m=strlen(add);
  554.         for(i=0;i<m;i++)
  555.         {
  556.                 write(1,add[i]);
  557.         }
  558. }
  559. void dispic(uchar *add)         //圖片顯示函數         (二維數組)
  560. {
  561.         uchar i,j;
  562.         for(i=0;i<32;i++)
  563.         {
  564.                 write(0,0x80+i);write(0,0x80);
  565.                 for(j=0;j<16;j++)
  566.                 {
  567.                         write(1,*add++);
  568.                 }
  569.         }
  570.         for(i=0;i<32;i++)
  571.         {
  572.                 write(0,0x80+i);write(0,0x88);
  573.                 for(j=0;j<16;j++)
  574.                 {
  575.                         write(1,*add++);
  576.                 }
  577.         }
  578. }
  579. void write(bit m,uchar a)
  580. {
  581.          RS=m;
  582.          RW=0;
  583.               P0=a;
  584.          E=1;
  585.          ;
  586.          E=0;
  587.          while(read()&0x80);
  588. }
  589. uchar read()
  590. {
  591.         uchar aa;
  592.         RS=0;
  593.         RW=1;
  594.         E=1;
  595.         aa=P0;
  596.         E=0;
  597.         return aa;
  598. }
  599.
