#include <reg51.h>
#include <intrins.h>
#define LCD_data P0 //數(shù)據(jù)口
sbit LCD_EN = P3^4; //液晶使能控制
sbit LCD_RS = P3^5; //寄存器選擇輸入
sbit LCD_RW = P3^6; //液晶讀/寫控制
sbit LCD_PSB = P3^7; //串/并方式控制
sbit wela = P2^6;
sbit dula = P2^7;
sbit s5 = P3^3;
sbit s4 = P3^2;
sbit s3 = P3^1;
sbit s2 = P3^0;
sbit a4 = P2^5;
sbit a3 = P2^4;
sbit a2 = P2^2;
sbit a1 = P2^0;
sbit HX711_DOUT=P1^6;
sbit HX711_SCK=P1^7;
uchar code dis1[] = {"簡易電子稱 "};
uchar code dis2[] = {"重量:"};
uchar code dis3[] = {"單價(jià):"};
uchar code dis4[] = {"總價(jià):"};
uchar code dis5[] = {"克"};
uchar code dis6[] = {"元"};
uchar code dis7[] = {"累計(jì)金額: "};
float q; //重量
float w=1.00000; //單價(jià)
float pi=0;
float mmm=0;
unsigned long HX711_Buffer=0;
uint a,s,d,f,g,je=0,o=0,kk=0,qp=0,pq=0;
#define delayNOP(); {_nop_();_nop_();_nop_();_nop_();};
void delay1(uint xms) //延時(shí)函數(shù)
uint i,j;
for(i=xms;i>0;i--)
for(j=110;j>0;j--);
void Delay__hx711_us(void)
_nop_();
_nop_();
unsigned long HX711_Read(void) //增益128
unsigned long count;
unsigned char i;
HX711_DOUT=1;
Delay__hx711_us();
HX711_SCK=0;
count=0;
while(HX711_DOUT);
for(i=0;i<24;i++)
HX711_SCK=1;
count=count<<1;
HX711_SCK=0;
if(HX711_DOUT)
count++;
HX711_SCK=1;
count=count^0x800000;//第25個(gè)脈沖下降沿來時(shí),轉(zhuǎn)換數(shù)據(jù)
Delay__hx711_us();
HX711_SCK=0;
return(count);
void Get_Weight()
HX711_Buffer = HX711_Read();
HX711_Buffer = HX711_Buffer/100;
q= HX711_Buffer;
//獲取實(shí)物的AD采樣數(shù)值。
q= ((double)q/7.6/*+0.05*/); //計(jì)算實(shí)物的實(shí)際重量
//因?yàn)椴煌膫鞲衅魈匦郧不一樣,因此,每一個(gè)傳感器需要矯正這里的4.30這個(gè)除數(shù)。
//當(dāng)發(fā)現(xiàn)測試出來的重量偏大時(shí),增加該數(shù)值。
//如果測試出來的重量偏小時(shí),減小改數(shù)值。
//該數(shù)值一般在4.0-5.0之間。因傳感器不同而定。
//+0.05是為了四舍五入百分位
void delay(int ms) //延時(shí)
while(ms--)
uchar i;
for(i=0;i<250;i++)
_nop_();
_nop_();
_nop_();
_nop_();
bit lcd_busy()
bit result;
LCD_RS = 0;
LCD_RW = 1;
LCD_EN = 1;
delayNOP();
result = (bit)(P0&0x80);
LCD_EN = 0;
return(result);
void lcd_wcmd(uchar cmd) //寫指令
while(lcd_busy());
LCD_RS = 0;
LCD_RW = 0;
LCD_EN = 0;
_nop_();
_nop_();
P0 = cmd;
delayNOP();
LCD_EN = 1;
delayNOP();
LCD_EN = 0;
void lcd_wdat(uchar dat) //寫數(shù)據(jù)
while(lcd_busy());
LCD_RS = 1;
LCD_RW = 0;
LCD_EN = 0;
P0 = dat;
delayNOP();
LCD_EN = 1;
delayNOP();
LCD_EN = 0;
void lcd_pos(uchar X,uchar Y) //設(shè)置顯示位置
uchar pos;
if (X==0)
{X=0x80;}
else if (X==1)
{X=0x90;}
else if (X==2)
{X=0x88;}
else if (X==3)
{X=0x98;}
pos = X+Y ;
lcd_wcmd(pos); //顯示地址
void lcd_init() //12864初始化
LCD_PSB = 1; //并口方式
lcd_wcmd(0x34); //擴(kuò)充指令操作
delay(5);
lcd_wcmd(0x30); //基本指令操作
delay(5);
lcd_wcmd(0x0C); //顯示開,關(guān)光標(biāo)
delay(5);
lcd_wcmd(0x01); //清除LCD的顯示內(nèi)容
delay(5);
void xianshi1() //顯示主屏幕(漢字)
uchar i;
lcd_pos(0,1);
for(i=0;i<12;i++)
lcd_wdat(dis1[i]);
lcd_pos(1,0);
for(i=0;i<5;i++)
lcd_wdat(dis2[i]);
lcd_pos(1,7);
for(i=0;i<2;i++)
lcd_wdat(dis5[i]);
lcd_pos(2,0);
for(i=0;i<5;i++)
lcd_wdat(dis3[i]);
lcd_pos(2,7);
for(i=0;i<2;i++)
lcd_wdat(dis6[i]);
lcd_pos(3,0);
for(i=0;i<5;i++)
lcd_wdat(dis4[i]);
lcd_pos(3,7);
for(i=0;i<2;i++)
lcd_wdat(dis6[i]);
void xianshi2(uchar pos,uchar z,uchar x,uchar c,uchar v) //顯示
lcd_pos(pos,3);
if(z!=0)
lcd_wdat(0x30+z);
lcd_wdat(0x30+x);
if(x!=0)
lcd_wdat(0x30+x);
lcd_wdat(0x30+c);
lcd_wdat('.');
lcd_wdat(0x30+v);
void chuli(float q)
uint k,l;
q=q+0.005;
l=(uint)q;
q=q*10;
k=(uint)q;
a=l/100;
s=l%100/10;
d=l%10;
f=k%10;
void ping1() //主屏1 (全部)
float e,t;
uint r;
if(o==0) pi=0;
q=q-pi;
if(q<0) q=0;
q=q*25;
chuli(q);
xianshi2(1,a,s,d,f);
if(a1==0)
{delay1(5);while(a1==0);w=w+1,chuli(w);xianshi2(2,a,s,d,f);}
if(a2==0)
{delay1(5);while(a2==0);w=w+0.1;chuli(w);xianshi2(2,a,s,d,f);}
if(a3==0)
{delay1(5);while(a3==0);w=w-0.1;chuli(w);xianshi2(2,a,s,d,f);}
if(a4==0)
{delay1(5);while(a4==0);w=w-1;chuli(w);xianshi2(2,a,s,d,f);}
chuli(w);
{ //顯示總價(jià)
lcd_pos(3,3);
e=q*w;
r=(int)(e/1000);
t=e-r*1000;
a=r/10;
s=r%10;
if(e>=10000)
lcd_wdat(0x30+a);
lcd_wdat(0x30+s);
if(e>=1000)
lcd_wdat(0x30+s);
chuli(t);
if(a!=0||r!=0)
lcd_wdat(0x30+a);
if(e>10)
lcd_wdat(0x30+s);
lcd_wdat(0x30+d);
lcd_wdat('.');
lcd_wdat(0x30+f);
if(s2==0) //記錄總價(jià)并累加
delay1(5);
while(s2==0);
mmm=mmm+e ;
kk++;
if(s4==0) //清楚累加數(shù)據(jù)
delay1(5);
while(s4==0);
mmm=0;
kk=0;
lcd_pos(0,7);
lcd_wdat(0x30+kk);
void ping2() //屏2(累計(jì)金額)
uchar i,r;
float t;
lcd_pos(0,1);
for(i=0;i<12;i++)
lcd_wdat(dis1[i]);
lcd_pos(1,0);
for(i=0;i<12;i++)
lcd_wdat(dis7[i]);
lcd_pos(3,7);
for(i=0;i<2;i++)
lcd_wdat(dis6[i]);
r=(int)(mmm/1000);
t=mmm-r*1000;
a=r/10;
s=r%10;
lcd_pos(2,3);
if(a!=0)
lcd_wdat(0x30+a);
lcd_wdat(0x30+s);
if(s!=0)
lcd_wdat(0x30+s);
chuli(t);
if(a!=0||r!=0)
lcd_wdat(0x30+a);
lcd_wdat(0x30+s);
lcd_wdat(0x30+d);
lcd_wdat('.');
lcd_wdat(0x30+f);
lcd_wdat(0x30+g);
lcd_pos(0,7); //顯示累計(jì)次數(shù)
lcd_wdat(0x30+kk);
void qingping()
if(qp==0)
if(q>10) qp++;
if(qp==1)
if(q<10) qp++;
if(qp==2)
delay(5);
qp++;
if(qp==3) qp=0;
void ss3()
uint qqq;
if(s3==0) //顯示累加或關(guān)閉累加
delay1(5);
while(s3==0);
qqq=1;
delay(5);
while(qqq)
ping2();
if(s3==0)
delay1(5);
while(s3==0);
qqq=0;
lcd_wcmd(0x01);
delay(5);
void ss5()
if(s5==0) //去皮
delay1(5);
while(s5==0);
o++;
if(o==2) o=0;
lcd_wcmd(0x01);//清除LCD的顯示內(nèi)容
delay(5);
if(o==1) pi=q;
main()
delay(10); //延時(shí)
wela=0;
dula=0;
lcd_init(); //初始化LCD
xianshi1();
Get_Weight(); //稱重
ss5(); //去皮
ping1();
qingping();
ss3(); //累計(jì)
評(píng)分
查看全部評(píng)分
