廣州 塔diy程序,效果詳見:http://m.raoushi.com/bbs/dpj-48911-1.html
- /****** 名稱:廣州塔 ***************************/
- /****** 編寫:憂傷的季節 ***************************/
- /****** 時間:2014年12月01日 ***************************/
- #include<reg52.h>
- #include<STC12C5A60S2.H>
- #define uchar unsigned char
- #define uint unsigned int
- uchar i,k,a;
- uint cy,cy1,pw;
- uchar code table[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};// 一個燈順時針流水
- uchar code table1[]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};// 一個燈順時針流水
- uchar code table2[]={0x80,0x40,0x20,0x10,0x08,0x04,0x02,0x01};
- uchar code table3[]={0x00,0x80,0xc0,0xe0,0xf0,0xf8,0xfc,0xfe};
- uchar code table4[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
- uchar code table5[]={0x00,0x01,0x03,0x07,0x0f,0x1f,0x3f,0x7f};
- uchar code table6[]={0x7f,0x3f,0x1f,0x0f,0x07,0x03,0x01,0x00};
- uchar code table7[]={0xfe,0xfc,0xf8,0xf0,0xe0,0xc0,0x80,0x00};
- uchar code table8[]={0x55,0xaa};
- uchar code table9[]={0x80,0xc0,0xe0,0xf0,0xf8,0xfc,0xfe,0xff};
- uchar code table10[]={0x01,0x03,0x07,0x0f,0x1f,0x3f,0x7f,0xff};
- void delay1(uint z)
- uint x,y;
- for(x=250;x>0;x--)
- for(y=z;y>0;y--);
- void delay2(uint x)
- uint a,b;
- for(a=x;a>0;a--)
- for(b=5;b>0;b--);
- /******************兩層向上*********************/
- void yiceng()
- for(k=0;k<8;k++){P3=table[k];P2=table[k];delay1(200);}
- /******************兩層向下*********************/
- void yiceng1()
- for(k=0;k<8;k++){P3=table1[k];P2=table1[k];delay1(200);}
- /******************兩條單個順時針滴水*********************/
- void dishushun()
- for(i=0;i<8;i++)
- P1=table4[i];
- P0=table2[i];
- for(k=0;k<8;k++){P2=table1[k];delay1(5);}P2=0xff;
- for(k=0;k<8;k++){P3=table1[k];delay1(5);}P3=0xff;
- /******************兩條單個逆時針滴水*********************/
- void dishuni()
- for(i=0;i<8;i++)
- P1=table2[i];
- P0=table4[i];
- /******************滴水下*********************/
- void liangdix()
- for(i=0;i<8;i++)
- P1=table2[i];
- P0=table4[i];
- for(k=0;k<8;k++){P2=table1[k];delay1(50);}P2=0xff;
- for(k=0;k<8;k++){P3=table1[k];delay1(50);}P3=0xff;
- /******************滴水上*********************/
- void liangdis()
- for(i=0;i<8;i++)
- P1=table4[i];
- P0=table2[i];
- for(k=0;k<8;k++){P2=table[k];delay1(50);}P2=0xff;
- for(k=0;k<8;k++){P3=table[k];delay1(50);}P3=0xff;
- /******************兩層從中間向上下拉伸*********************/
- void sxl()
- P1=0xff;
- P0=0xff;
- for(k=0;k<8;k++){P3=table4[k];P2=table4[k];delay1(200);}
- /******************兩層從頂向下拉伸*********************/
- void sxl1()
- P1=0xff;
- P0=0xff;
- for(k=0;k<8;k++){P3=table6[k];P2=table6[k];delay1(400);}
- void sxls()
- P1=0xff;
- P0=0xff;
- for(k=0;k<8;k++){P3=table6[k];P2=table7[k];delay1(200);}
- /******************單層從底向上旋轉*********************/
- void danxuan()
- { P2=0xff;P3=0xff;
- for(i=0;i<8;i++)
- P1=0x00;P0=0x00;
- P3=table[i];
- for(k=0;k<8;k++){P0=table5[k];delay1(200);}
- for(k=0;k<8;k++){P1=table3[k];delay1(200);}
- }P3=0xff;
- for(i=0;i<8;i++)
- P1=0x00;P0=0x00;
- P2=table[i];
- }P2=0xff;
- /******************單層從頂向上旋轉*********************/
- void danxuand()
- for(i=0;i<8;i++)
- P1=0x00;P0=0x00;
- P2=table1[i];
- }P2=0xff;
- for(i=0;i<8;i++)
- P1=0x00;P0=0x00;
- P3=table1[i];
- }P3=0xff;
- /******************兩層豎立向圓順時針合圍*********************/
- void shw()
- P2=0x00;P3=0x00;
- for(k=0;k<8;k++){P0=table5[k];P1=table3[k];delay1(700);}
- /******************兩層豎立向圓順時針回收*********************/
- void shw1()
- P2=0x00;P3=0x00;
- for(k=0;k<8;k++){P0=table6[k];P1=table7[k];delay1(700);}
- /******************兩層豎立向圓逆時針回收*********************/
- void shw3()
- P2=0x00;P3=0x00;
- for(k=0;k<8;k++){P0=table7[k];P1=table6[k];delay1(700);}
- /******************兩層豎立向圓逆時針合圍*********************/
- void shw2()
- P2=0x00;P3=0x00;
- for(k=0;k<8;k++){P0=table9[k];P1=table10[k];delay1(700);}
- /******************四條單個順時針滴水閃*********************/
- void sidisun()
- for(i=0;i<2;i++)
- P1=table8[i];
- P0=table8[i];
- for(k=0;k<8;k++){P3=table1[k];delay1(50);}P3=0xff;delay1(700);
- void sidisun1()
- for(i=0;i<2;i++)
- P1=table8[i];
- P0=table8[i];
- /******************四條單個順時針滴水轉*********************/
- void sisunz()
- { P2=0x00;
- P3=0x00;
- for(i=0;i<2;i++)
- P1=table8[i];
- P0=table8[i];
- delay1(1000);
- /******************呼吸燈*********************/
- void hxd()
- P0=0xff;P1=0xff;
- for(pw=1;pw<cy1;pw++)
- P2=0x55;P3=0x55;delay2(pw);
- P2=0xff;P3=0xff;delay2(cy1-pw);
- P2=0xaa;P3=0xaa;delay2(pw);
- /******************半層呼吸燈*********************/
- void bhxd()
- P0=0xff;P1=0xff;
- for(pw=1;pw<cy;pw++)
- P2=0x00;P3=0xff;delay2(pw);
- P2=0xff;P3=0x00;delay2(cy-pw);
- /******************四滴下閃*********************/
- void sxs()
- P1=0x55;
- P0=0x55;
- for(k=0;k<8;k++){P2=table1[k];delay1(500);}P2=0xff;
- for(k=0;k<8;k++){P3=table1[k];delay1(500);}P3=0xff;
- /******************四滴上閃*********************/
- void sxss()
- P1=0xaa;
- P0=0xaa;
- for(k=0;k<8;k++){P3=table[k];delay1(500);}P2=0xff;
- for(k=0;k<8;k++){P2=table[k];delay1(500);}P3=0xff;
- void main()
- cy=2000,cy1=1200,pw=1;
- while(1)
- bhxd();//半層呼吸
- for(a=0;a<5;a++){P0=0xff;P1=0xff;yiceng();}//兩層上跳動
- for(a=0;a<5;a++){P0=0xff;P1=0xff;yiceng1();}//兩層下跳動
- for(a=0;a<5;a++){P0=0xff;P1=0xff;yiceng();yiceng1();}//兩層上下跳動
- for(a=0;a<8;a++){dishushun();} //兩條單個順時針滴水
- for(a=0;a<8;a++){dishuni();} //兩條單個逆時針滴水
- for(a=0;a<5;a++){dishushun();dishuni();}//兩條單個順時+逆時針滴水
- for(a=0;a<5;a++){liangdix();}//兩滴掉下
- for(a=0;a<5;a++){liangdis();}//兩滴掉上
- for(a=0;a<5;a++){sxl();}
- for(a=0;a<4;a++){sidisun();}
- for(a=0;a<2;a++){hxd();}//呼吸燈
- for(a=0;a<2;a++){shw();shw2();}//兩層豎立向圓順+逆時針合圍
- for(a=0;a<2;a++){shw1();shw3();}//兩層豎立向圓順+逆時針回收
- for(a=0;a<4;a++){sxl1();}//兩層從頂向下拉伸
- for(a=0;a<5;a++){sxls();}//兩層從中間向上下拉伸
- for(a=0;a<4;a++){sisunz();}
- danxuan();//單層從底向上旋轉
- danxuand();//單層從頂向下旋轉
- for(a=0;a<3;a++){shw();} //兩層豎立向圓順時針合圍
- for(a=0;a<3;a++){shw2();}//兩層豎立向圓逆時針合圍
- for(a=0;a<2;a++){shw1();}//兩層豎立向圓順時針回收
- for(a=0;a<2;a++){shw3();}//兩層豎立向圓逆時針回收
- for(a=0;a<4;a++){sidisun1();}
- sxs();//四滴下閃
- sxss();//四滴上閃
- /********************* the end******************************/
廣州塔程序.rar
2016-8-14 21:07 上傳
下載積分: 黑幣 -5
34.61 KB, 下載次數: 170, 下載積分: 黑幣 -5
