查看: 2736|回復(fù): 0
stm32 f103 串口中斷通訊程序
ID:134970 發(fā)表于 2016-7-25 17:27 | 只看該作者 回帖獎勵 |倒序?yàn)g覽 |閱讀模式
1、 main.c
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x.h"
#include "stm32f10x_rcc.h"
#include "stm32f10x_gpio.h"
#include "stm32f10x_usart.h"
#include "stm32f10x_exti.h"
#include "system_stm32f10x.h"
#include "misc.h"
/* ÅäÖÃÏμí3ê±Öó 72M */
void SystemInit(void);//SystemInit();
u16 CCR1= 10;
u16 CCR2= 10;
u16 CCR3= 10;
u8 rx_data[20];
u8 rx_num;
u8 rx_status;
* ???:void GPIO_Config(void)
* ??  :??????PWM????I/O
* ??  :main()??
  //′ò¿aGPIOA£¬GPIOBê±Öó
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA , ENABLE);
  RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOB, ENABLE);
        /*GPIOA Configuration: TIM3 channel 1 (GPIOA_Pin_6)and 2(GPIOA_Pin_7) as alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6| GPIO_Pin_7;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;           // ??????
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
        /*GPIOA Configuration: TIM3 channel 3 (GPIOB_Pin_0)and 4(GPIOB_Pin_1) as alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_0 | GPIO_Pin_1 ;
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9 ;  // PB8£P(guān)PB9 = DIêäèë
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;  //ÅäÖÃ3鸡¿Õêäèë
  GPIO_Init(GPIOB, &GPIO_InitStructure);
//Timer3õê¼»ˉ:
* ???:void TIM3_Config(void)
* ??  :??TIM3???PWM?????
*      CH1:?? T=2.5ms(f=1/2.5ms=400Hz)  D=0.6?PWM?(?????,?????)
*      CH2:?? T=2.5ms(f=1/2.5ms=400Hz)  D=0.4?PWM?(?????,?????)
*      ???:??T?TIMxCLK??????TIM_Period?TIM_Prescaler
*          T=(TIM_Period+1)*(TIM_Prescaler+1)/TIMxCLK=2.5ms
*          ?? TIM_Period<65535,?? TIM_Prescaler>1,? TIM_Prescaler=2
*          ?? TIM_Period=59999=0xEA5F
*      ???:??TIM_Period??,???????D,??CCR?TIM_OCPolarity
*          CH1:??D=0.6,????;
*              ??CCR1=(TIM_Period+1)* D=36000;TIM_OCPolarity=TIM_OCPolarity_High
*          CH2:??D=0.4,????;
*              ??CCR1=(TIM_Period+1)* (1-D)=36000;TIM_OCPolarity=TIM_OCPolarity_Low
*      ???:??TIM3?????ARR
*      ???:??TIM3
* ??  :main()??
void TIM3_Config(u16 CCR1,u16 CCR2,u16 CCR3)
    TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
    TIM_OCInitTypeDef  TIM_OCInitStructure;
    /*′ò¿aTIM3ê±Öó 72MHz*/
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
    /* Time base configuration */
    TIM_TimeBaseStructure.TIM_Period =200;
    TIM_TimeBaseStructure.TIM_Prescaler = 2;                                    //?????:???=2,??72/3=24MHz
    TIM_TimeBaseStructure.TIM_ClockDivision = 0;                                //????????:???
    TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;                 //????????
    TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
    TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;          //???PWM??1
        /* PWM1 Mode configuration: Channel1 */
    TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
    TIM_OCInitStructure.TIM_Pulse = CCR1;                                       //?????,???????????,??????
    TIM_OCInitStructure.TIM_OCPolarity =TIM_OCPolarity_High;                    //?????????CCR1?????
    TIM_OC1Init(TIM3, &TIM_OCInitStructure);                                    //????1
    TIM_OC1PreloadConfig(TIM3, TIM_OCPreload_Enable);
         /* PWM1 Mode configuration: Channel2 */
    TIM_OCInitStructure.TIM_Pulse = CCR1;                                       //????2??????,??????????PWM
    TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;                    //?????????CCR2?????
    TIM_OC2Init(TIM3, &TIM_OCInitStructure);                                    //????2
    TIM_OC2PreloadConfig(TIM3, TIM_OCPreload_Enable);
                /* PWM1 Mode configuration: Channel3 */
    TIM_OCInitStructure.TIM_Pulse = CCR2;                                       //????2??????,??????????PWM
    TIM_OC3Init(TIM3, &TIM_OCInitStructure);                                    //????2
    TIM_OC3PreloadConfig(TIM3, TIM_OCPreload_Enable);
    /* PWM1 Mode configuration: Channel4 */
    TIM_OCInitStructure.TIM_Pulse = CCR3;                                       //????2??????,??????????PWM
    TIM_OC4Init(TIM3, &TIM_OCInitStructure);                                    //????2
    TIM_OC4PreloadConfig(TIM3, TIM_OCPreload_Enable);
                TIM_ARRPreloadConfig(TIM3, ENABLE);                                         //??TIM3?????ARR
    /* TIM3 enable counter */
    TIM_Cmd(TIM3, ENABLE);                                                      //??TIM3
//Ñóê±oˉêy £¨oáÃ룩
    void delay_ms(u16 time)
     u16 i=0;
     while(time--)
       i=12000;  //????
       while(i--) ;
*????:  UART1Init
void UART1Init(void)
        USART_InitTypeDef USART_InitStructure;
                                //′ò¿aUSART1ê±Öó
                                RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,ENABLE);
                                RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO, ENABLE);
        //GPIO?????????:
         /*--------------4851ü½ÅÅäÖÃ----------*/
         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 ;  // êÕ·¢×a»»¿a1Ø
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //50M????
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //????
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;          //485_TX
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;  //??????
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;           //485_RX
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //????
        //′®¿ú2ÎêyÅäÖÃ:
        USART_InitStructure.USART_BaudRate = 9600;
        USART_InitStructure.USART_WordLength = USART_WordLength_8b;
        USART_InitStructure.USART_StopBits = USART_StopBits_1;
        USART_InitStructure.USART_Parity = USART_Parity_No;
        USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
        USART_InitStructure.USART_Mode = USART_Mode_Tx | USART_Mode_Rx;
        USART_Init(USART1, &USART_InitStructure);
                                USART_ITConfig(USART1,USART_IT_TXE,ENABLE);    //ÔêDí′®¿ú·¢ËíÖD¶Ï
                                USART_ITConfig(USART1,USART_IT_RXNE,ENABLE);  //ÔêDí′®¿ú½óêÕÖD¶Ï
                                USART_ITConfig(USART1,USART_IT_IDLE,ENABLE);  //ÔêDí′®¿ú¿ÕÏDÖD¶Ï£¨ÅD¶ÏêÇ·ñêÕμ½ò»¸öêy¾Y°üμÄê1Äü£©
                                USART_DMACmd(USART1,USART_DMAReq_Rx,ENABLE);        //DMA·½ê½½óêÕ′®¿úêy¾Y
                                USART_Cmd(USART1, ENABLE);
        USART_ClearFlag(USART1, USART_FLAG_TC);    //·¢Ëííê3é±êÖ¾
       // USART_GetITStatus(USART1, USART_FLAG_TC);  /*»ñè¡′®¿ú×′쬱ê־λ*/
/* DMA ÅäÖÃoˉêy */
void DMA_init(void)
   DMA_InitTypeDef    DMA_Initstructure;
   /*??DMA??*/
   RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1,ENABLE);
//   /* Enable the DMA1 Interrupt */
   DMA_Initstructure.DMA_PeripheralBaseAddr =  (u32)(&USART1->DR);;
   DMA_Initstructure.DMA_MemoryBaseAddr     = (u32)rx_data;
   DMA_Initstructure.DMA_DIR = DMA_DIR_PeripheralSRC;
   DMA_Initstructure.DMA_BufferSize = 128;
   DMA_Initstructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
   DMA_Initstructure.DMA_MemoryInc =DMA_MemoryInc_Enable;
   DMA_Initstructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
   DMA_Initstructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
   DMA_Initstructure.DMA_Mode = DMA_Mode_Normal;
   DMA_Initstructure.DMA_Priority = DMA_Priority_High;
   DMA_Initstructure.DMA_M2M = DMA_M2M_Disable;
   DMA_Init(DMA1_Channel5,&DMA_Initstructure);
   //Æô¶ˉDMA
   DMA_Cmd(DMA1_Channel5,ENABLE);
   //??DMA·¢ËíÖD¶Ï
   //DMA_ITConfig(DMA1_Channel4,DMA_IT_TC,ENABLE);
/*  ÖD¶ÏÅäÖÃoˉêy  */
void NVIC_Configuration(void)//???????
  NVIC_InitTypeDef NVIC_InitStructure;
   #ifdef VECT_TAB_RAM
  /*??????????0x20000000?*/
  NVIC_SetVectorTable(NVIC_VectTab_RAM,0x00);
#else
  /*????????????0x80000000?*/
  NVIC_SetVectorTable(NVIC_VectTab_FLASH,0x00);
#endif
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
  NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;    //ÖD¶ÏÕ¼Ïèμè¼¶
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;    //ÖD¶ÏÏìó|óÅÏè¼¶
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
        //DMAÖD¶ÏéèÖÃ
    NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel5_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 3;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2;
* ???:main
int main(void)
                SystemInit();
    GPIO_Config();
          //TIM3_Config(CCR1,CCR2,CCR3);
                UART1Init();
                NVIC_Configuration();
                DMA_init();
    while (1)
     delay_ms(3000);
                        CCR1= CCR1*2;
                        CCR2= CCR1*2.5;
                        CCR3= CCR1*3;
                        if (CCR1>=200 ) CCR1= CCR1-200;
                        if (CCR2>=200 ) CCR2= CCR2-200;
                        if (CCR3>=200 ) CCR3= CCR1-200;
                        //TIM3_Config(CCR1,CCR2,60000);
                        if(GPIO_ReadInputDataBit(GPIOB, GPIO_Pin_8))  //¼ì2aPB¿úμÄμú8¸ö1ü½ÅμÄμçÆ½
                                TIM3_Config(CCR1,CCR2,200);   //Õy3£êä3ö
                                TIM3_Config(0,0,0);  //êä3ö0
#ifdef  USE_FULL_ASSERT
void assert_failed(uint8_t* file, uint32_t line)
  while (1)
#endif
2、中斷程序
void UartASendStr (u8 *pucStr, u8 ulNum)
u8 i;
for(i = 0;i<ulNum;i++)
while(USART_GetFlagStatus(USART1,USART_FLAG_TC)==RESET);
    USART_SendData(USART1,*pucStr++);
// ′®¿úÖD¶Ïoˉêy
void USART1_IRQHandler(void)
        extern u8 rx_data[20];
        extern u8 rx_num;
        extern u8 rx_status;
        u8 RX_dat;
        u16 clear=0;
        u8 data[5];
data[0]=0x55;
data[1]=0xAA;
data[2]=0x36;
data[3]=0xFF;
data[4]=0xEF;
  if(USART_GetITStatus(USART1,USART_IT_RXNE)==SET)//êÕμ½1¸ö×Ö½ú
    //RX_dat=USART_ReceiveData(USART1);
                //USART_ClearFlag(USART1,USART_IT_RXNE);
    rx_data[rx_num++]=USART_ReceiveData(USART1);
                if (rx_num>5)
                        rx_num=0; //êy×éÖ¸Õë»Øμ½¿aí·
                        rx_status=1;  //êÕμ½ò»Ö¡êy¾Y
                        GPIO_SetBits(GPIOA,GPIO_Pin_8);  //ÔêDí′®¿ú·¢Ëí
                        delay_ms(10);
     //        UartASendStr(data,5);
                //        while(USART_GetFlagStatus(USART1,USART_FLAG_TXE) == RESET){} //???????????
                        delay_ms(20);
                        GPIO_ResetBits(GPIOA,GPIO_Pin_8);  //ÔêDí′®¿ú½óêÕ
         if (USART_GetITStatus(USART1,USART_IT_IDLE)==SET)//êÕμ½1Ö¡êy¾Y
                clear= USART1->SR;
                clear= USART1->DR; //Çå3yIDLE ±êÖ¾
                         DMA_Cmd(DMA1_Channel5,DISABLE);    //??DMA
       rx_num = 128 -  DMA_GetCurrDataCounter(DMA1_Channel5);      //??????????
       rx_data[rx_num] = '\0';
       DMA1_Channel5->CNDTR=128;       //??????????
       DMA_Cmd(DMA1_Channel5,ENABLE);  //??DMA
    delay_ms(1);
   // USART_SendData(USART1,RX_dat);
    delay_ms(2);
