查看: 6483|回復(fù): 6
求助:PT2259電子音量IC尋不到地址。有玩過(guò)的大神指導(dǎo)下(附程序)
89c52外掛24c02跟一個(gè)PT2259;
程序就發(fā)送一個(gè)地址碼,接收ACK信號(hào),并把接收到的ACK信號(hào)用液晶顯示出來(lái);
發(fā)送 0x50 24c02有應(yīng)答信號(hào);
但我按PT2259資料寫的四個(gè)地址:0x88;0x89;0x8D;0x8C  都測(cè)試一邊都沒有收到應(yīng)答信號(hào)!
這是什么回事啊?是不是24C02跟PT2259的尋址方式不同?
程序:
LCD1206.C
#include <reg52.h>
#define LCD1602_DB  P0
sbit LCD1602_RS = P1^2;
sbit LCD1602_RW = P1^1;
sbit LCD1602_E  = P1^0;
/* 等待液晶準(zhǔn)備好 */
void LcdWaitReady()
    unsigned char sta;
    LCD1602_DB = 0xFF;
    LCD1602_RS = 0;
    LCD1602_RW = 1;
    do {
        LCD1602_E = 1;
        sta = LCD1602_DB; //讀取狀態(tài)字
        LCD1602_E = 0;
    } while (sta & 0x80); //bit7等于1表示液晶正忙,重復(fù)檢測(cè)直到其等于0為止
/* 向LCD1602液晶寫入一字節(jié)命令,cmd-待寫入命令值 */
void LcdWriteCmd(unsigned char cmd)
    LcdWaitReady();
    LCD1602_RS = 0;
    LCD1602_RW = 0;
    LCD1602_DB = cmd;
    LCD1602_E  = 1;
    LCD1602_E  = 0;
/* 向LCD1602液晶寫入一字節(jié)數(shù)據(jù),dat-待寫入數(shù)據(jù)值 */
void LcdWriteDat(unsigned char dat)
    LcdWaitReady();
    LCD1602_RS = 1;
    LCD1602_RW = 0;
    LCD1602_DB = dat;
    LCD1602_E  = 1;
    LCD1602_E  = 0;
/* 設(shè)置顯示RAM起始地址,亦即光標(biāo)位置,(x,y)-對(duì)應(yīng)屏幕上的字符坐標(biāo) */
void LcdSetCursor(unsigned char x, unsigned char y)
    unsigned char addr;
    if (y == 0)  //由輸入的屏幕坐標(biāo)計(jì)算顯示RAM的地址
        addr = 0x00 + x;  //第一行字符地址從0x00起始
        addr = 0x40 + x;  //第二行字符地址從0x40起始
    LcdWriteCmd(addr | 0x80);  //設(shè)置RAM地址
/* 在液晶上顯示字符串,(x,y)-對(duì)應(yīng)屏幕上的起始坐標(biāo),str-字符串指針 */
void LcdShowStr(unsigned char x, unsigned char y, unsigned char *str)
    LcdSetCursor(x, y);   //設(shè)置起始地址
    while (*str != '\0')  //連續(xù)寫入字符串?dāng)?shù)據(jù),直到檢測(cè)到結(jié)束符
        LcdWriteDat(*str++);
/* 初始化1602液晶 */
void InitLcd1602()
    LcdWriteCmd(0x38);  //16*2顯示,5*7點(diǎn)陣,8位數(shù)據(jù)接口
    LcdWriteCmd(0x0C);  //顯示器開,光標(biāo)關(guān)閉
    LcdWriteCmd(0x06);  //文字不動(dòng),地址自動(dòng)+1
    LcdWriteCmd(0x01);  //清屏
main.c
#include <reg52.h>
#include <intrins.h>
#define I2CDelay()  {_nop_();_nop_();_nop_();_nop_();}
sbit I2C_SCL = P3^6;
sbit I2C_SDA = P3^7;
extern void InitLcd1602();
extern void LcdShowStr(unsigned char x, unsigned char y, unsigned char *str);
bit I2CAddresing(unsigned char addr);
        bit ack = 0;
        unsigned char str[10];
    InitLcd1602();   //初始化液晶
        ack = I2CAddresing(0x88);
        str[0] = '5';
        str[1] = '0';
        str[2] = ':';
        str[3] = (unsigned char)ack + '0';
        str[4] = '\0';
        LcdShowStr(0, 0, str);
        ack = I2CAddresing(0x89);
        str[0] = '6';
        str[1] = '2';
        str[2] = ':';
        str[4] = '\0';
        LcdShowStr(8, 0, str);
    while (1);
void I2CStart()
        I2C_SDA = 1;
        I2C_SCL = 1;
        I2CDelay();
        I2C_SDA = 0;
        I2CDelay();
        I2C_SCL = 0;
void I2CStop()
        I2C_SCL = 0;
        I2C_SDA = 0;
        I2CDelay();
        I2C_SCL = 1;
        I2CDelay();
        I2C_SDA = 1;
        I2CDelay();
bit I2CWrite(unsigned char dat)
        bit ack = 0;
        unsigned char mask;
        for(mask=0x80; mask!=0; mask>>=1)
                if((mask&dat) == 0)
                        I2C_SDA = 0;
                        I2C_SDA = 1;
                I2CDelay();
                I2C_SCL = 1;
                I2CDelay();
                I2C_SCL = 0;
        I2C_SDA = 1;
        I2CDelay();
        I2C_SCL = 1;
        ack = I2C_SDA;
        I2CDelay();
        I2C_SCL = 0;
        return ack;
        bit ack = 0;
        I2CStart();
        ack = I2CWrite(addr << 1);
        I2CStop();
        return ack;
來(lái)自 6#
ID:74784 發(fā)表于 2016-12-19 16:27 | 只看該作者
建議樓主用pga2311吧
ID:129964 發(fā)表于 2016-7-18 23:51 | 只看該作者
快來(lái)人救命啊!!!
ID:129964 發(fā)表于 2016-7-19 08:02 | 只看該作者
PT2257跟PT2259是不是不同的兩種東西啊?
那個(gè)更好?我看很多人都是在用2257的。
ID:134182 發(fā)表于 2016-7-19 08:57 | 只看該作者
不懂,但頂一個(gè),樓主加油
ID:129964 發(fā)表于 2016-7-19 16:10 | 只看該作者
huayangshiboqi 發(fā)表于 2016-7-19 08:57
不懂,但頂一個(gè),樓主加油
嗯嗯 謝謝哈~
ID:211349 發(fā)表于 2017-11-24 21:38 | 只看該作者
樓主解決了嗎?畢業(yè)設(shè)計(jì)得用這個(gè)芯片,想?yún)⒖家幌?/td>
