查看: 4230|回復(fù): 0
單片機(jī)控制adc0832數(shù)模轉(zhuǎn)換測(cè)電壓,lcd1602顯示
ID:130251 發(fā)表于 2016-7-13 09:07 | 顯示全部樓層 |閱讀模式
#include<reg51.h>
#include <intrins.h>
//#define LCD_DATA  P0;
sbit DI  = P3^4;//¶¨òåADC¸÷¿úêy¾Y
sbit D0   =P3^4;
sbit CLK = P3^5;
sbit CS  = P3^6;
sbit LCD_RS= P1^0;//¶¨òåLCDòy½Å
sbit LCD_RW= P1^1;
sbit LCD_E=  P2^5;
uchar code DIS[]={"voltage:"};//ADC832;
uchar code dsptab[]={'0','1','2','3','4','5','6','7','8','9'};//×Ö·û′úÂë±í;
/*--------------------Ñóê±×ó3ìDò------------------------*/
void delay(uint a)
         uint b;
         for(b=0;b<a;b++);
void delay400ms(void)////400msÑóê±
         uchar a = 5;
         uint b;
         while(a--)
              b=7269;
              while(b--);
     }  /*---------------------------¶á×′ì¬-----------------------*/
                 //¶á×′ì¬×ó3ìDò£»óD·μ»ØÖμ£»·μ»ØÖμààDíÎaCHARDí;
                 //¶á»ØμÄ×′ì¬í¨1yRETURN·μ»Ø;
  uchar read_estate(void)     //¶¨òåóD·μ»ØÖμμÄoˉêy;
                          P0=0Xff;      //°ÑLCD¶Ë¿úè«ÖÃ1·½±ã¶áè¡DÅoÅ;
                           LCD_RS=0;        //RSÖÃ0;
                           LCD_RW=1;        //RWÖÃ1;
                           LCD_E=0;           //E¶ËÖÃ0;
                           delay(10);       //¶ìÑóê±;
                           LCD_E=1;        //E¶ËÖÃ1;òÔËø′æêy¾Y;
                           while(P0&0x80);  //¼ì2aÃ|,Ôòò»Ö±Ñ-»·;
                           return(P0);      //·μ»Ø¶áè¡μÄDÅoÅ;
/*----------------------------D′êy¾Y---------------------------*/
                        //D′êy¾Y×ó3ìDò;ÎT·μ»ØÖμ;êäèë±äá¿I;
                        //IÎaòaD′èëLCDÖDμÄêy¾Y;
                        //êy¾YààDíCHARDí;
                        void write_data(uchar i)    //¶¨òåêäèë±äá¿ÖμI;
                                      read_estate();      //¼ì2aÃ|DÅoÅ;
                                       P0=i;       //°ÑIÖDêy¾YËíμ½LCDêy¾Y¶Ë;
                                      LCD_RS=1;        //RSÖÃ1;
                                      LCD_RW=0;        //RWÖÃ0;
                                      LCD_E=0;        //EÖÃ0;
/*------------------------------D′Ö¸áî--------------------------*/
                        //D′Ö¸áî×ó3ìDò;ÎT·μ»ØÖμ;êäèëὸö±äá¿IoíJ.
                        //IòaD′èëLCDμÄÖ¸áî;JÎaÅD¶Ïòa2»òa¼ì2aÃ|.
                        //èç1ûJÎa0Ôò2»ÅD¶Ï¼ì2aÃ|;
                        //èç1ûJÎa1ÔòÅD¶Ï¼ì2aÃ|;
                            void write_dictate(uchar i,j)   //¶¨òåὸö±äá¿;
                                          if(j)read_estate();         //¸ù¾YDèòa¼ì2aÃ|;
        P0=i;                           //°ÑòaD′èëμÄêy¾YËíμ½LCDêy¾Y¶Ë;
        LCD_RS=0;                       //RSÖÃ0;
        LCD_RW=0;        //RWÖÃ0;
        LCD_E =1;        //E¶ËÖÃ0;
        delay(10);       //Ñóê±;
        LCD_E =0;        //E¶ËÖÃ1;òÔËø′æêy¾Y;
/*------------------------------¶áêy¾Y---------------------*/
                                                        //¶áêy¾Y×ó3ìDò;óD·μ»ØÖμ,·μ»ØÖμààDíÎaCHARDí;
                                                        /*uchar read_data(void)     //¶¨òåóD·μ»ØÖμμÄ×óoˉêy;
                                                              LCD_DATA=0Xff;      //LCDêy¾Y¶Ë¿úÖÃ1;
                    LCD_RS=1;        //RSÖÃ1;
                                                              LCD_RW=1;        //RWÖÃ1;
                                                              LCD_E=0;        //EÖÃ0;
                                                              LCD_E=1;        //EÖÃ1;òÔËø′æêy¾Y;
                                                              return(LCD_DATA);      //·μ»Ø¶áè¡μÄÖμ;
/*----------------------------3õê¼»ˉ-----------------------*/
                                                        //LCD3õê¼»ˉ3ìDò;Ö÷òa×÷óÃ3õê¼»ˉLCD,¶ÔLCD½øDD¸′λòÔ¼°éèÖÃ;
                                void initialization(void)    //¶¨òåoˉêy;
        delay(50);       //Ñóê±5MS;
        write_dictate(0x38,0);    //D′Ö¸áî38H;2»¼ì2aÃ|;
        delay(50);
        write_dictate(0x38,1);    //ÏÔê¾Ä£ê½éèÖÃ;¼ì2aÃ|;
        write_dictate(0x08,1);    //1رÕÏÔê¾;¼ì2aÃ|;
        write_dictate(0x01,1);    //ÏÔê¾ÇåÆá;¼ì2aÃ|;
        write_dictate(0x06,1);    //ÏÔê¾1a±êòƶˉéèÖÃ;¼ì2aÃ|;
        write_dictate(0x0C,1);    //ÏÔ꾿a1ؼ°1a±êéèÖÃ;¼ì2aÃ|;
/*---------------------------ÔúÖ¸¶¨Î»ÖÃÏÔê¾ò»¸ö×Ö·û----------------------*/
        void displayonechar(uchar x, y,ddata)
        y &= 0x01;
        x &= 0x0f;           //ÏTÖÆX2»Äü′óóú15,Y2»Äü′óóú1
        if (y) x+= 0x40;     //μ±òaÏÔê¾μú¶tDDê±μØÖ·Âë+0x40;
        x+= 0x80;            //Ëã3öÖ¸áîÂë
        write_dictate(x,0);  //Õaàï2»¼ì2aÃ|DÅoÅ,·¢ËíμØÖ·Âë
        write_data(ddata);
/*-------------------------ÔúÖ¸¶¨Î»ÖÃÏÔê¾ò»′®×Ö·û--------------*/
        void displaylistchar(uchar x,y,uchar code *ddata)
        uchar a=0;
        y&=0x01;
                             x&=0xf;
                             while(ddata[a]>0x20)
        if(x<=0xff)
        displayonechar(x, y,ddata[a]);
        a++;
        x++;
/*-------------------------------¶áADC0832μÄêy¾Y----------------------------*/
          unsigned char readadc(void)
        unsigned char dat,i;
        CLK=0;         //D¾Æ¬¸′λ
        CS=1;
        _nop_();
        CS=0;
        _nop_();
        DI=1;         //Æô¶ˉλ
        CLK=1;
        _nop_();
        CLK=0;
        DI=1;         //ÅäÖÃλ1
        CLK=1;
        _nop_();
        CLK=0;
        DI=0;         //ÅäÖÃλ2
        CLK=1;
        _nop_();
        CLK=0;         //¿ÕÏDλ
        _nop_();
        CLK=1;
        DI=1;
                                                for(i=0;i<=8;i++){  //¶á3ö8×Ö½úêy¾Y
                                                            dat=dat<<1;
                                                            _nop_();
                                                             CLK=1;//ÕaàïòaÏè1oó0...èç1ûÏè0oó1Ôòêä3ö½á1û′íÎó...
                                                if(DI){
                 dat|=0x01;
        _nop_();
                  CLK=0;
                        CS=1;//1رÕD¾Æ¬
                  return(dat);//·μ»Øêy¾Y
                                        {  uint dat;
                                                delay400ms();//Ñóê±400MS
                                                initialization();//LCD¸′λ;
                                                displaylistchar(0,0,DIS);//ÏÔê¾ADC832 2aêÔ;
                                                displayonechar(0,1,'O'); //ÔúLCDêÇÏÔê¾OUT:_.___V
                                                displayonechar(1,1,'U');
                                                displayonechar(2,1,'T');
                                                displayonechar(3,1,':');
                                                displayonechar(5,1,'.');
                                                displayonechar(8,1,'V');
                                                while(1)//ÎTÏTÑ-»·...ò»Ö±¶á3öμçÑ1ÖμÏÔê¾ÔúLCDéÏ;
                                { displayonechar(13,1,dsptab[readadc()/100]);
                                        displayonechar(14,1,dsptab[(readadc()%100)/10]);
                                        displayonechar(15,1,dsptab[readadc()%10]);//ÔúLCD×îóò±ßÏÔê¾255ÖDμÄÄ3ò»¸öêy¾Y;
                                        dat=readadc()/0.542;//0.542êÇ2553yòÔ»ù×¼μçÑ1ò2¾íêÇADC0832μÄVCC...μÿ′3öà′...Õa¸öÖμ¿éÄüÿ¸öèË2»í¬.
                                        displayonechar(4,1,dsptab[dat/100]);//ÏÂÃæèyDDÏÔê¾μçÑ1...
                                        displayonechar(6,1,dsptab[(dat%100)/10]);
                                        displayonechar(7,1,dsptab[dat%10]);
相關(guān)帖子
