查看: 4309|回復: 0
流水燈顯示學號
ID:125403 發表于 2016-6-6 11:28 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
/**********  hero lee編寫,考試請勿直接移植,否則一切后果自負 **********/
/* 屏蔽的為清翔單片機開發板,若需使用則將沒有屏蔽的注釋,注釋了的打開,*/
/*                學校發的開發板可直接修改學號數組下載                 */
/*    此程序須將開發板上的JOE排針上的跳線帽插左邊兩個即連接VCC與OE     */
#include <reg52.h>
#include <intrins.h>
uchar code display_lxy[20][8]={        //此數組為學號流動顯示數碼管代碼
                                                0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x5b,//       2
                                                0x00,0x00,0x00,0x00,0x00,0x00,0x5b,0x3f,//      20
                                                0x00,0x00,0x00,0x00,0x00,0x5b,0x3f,0x06,//     201
                                                0x00,0x00,0x00,0x00,0x5b,0x3f,0x06,0x4f,//    2013
                                                0x00,0x00,0x00,0x5b,0x3f,0x06,0x4f,0x3f,//   20130
                                                0x00,0x00,0x5b,0x3f,0x06,0x4f,0x3f,0x7d,//  201306
                                                0x00,0x5b,0x3f,0x06,0x4f,0x3f,0x7d,0x3f,// 2013060
                                                0x5b,0x3f,0x06,0x4f,0x3f,0x7d,0x3f,0x3f,//20130600
                                                0x3f,0x06,0x4f,0x3f,0x7d,0x3f,0x3f,0x5b,//01306002
                                                0x06,0x4f,0x3f,0x7d,0x3f,0x3f,0x5b,0x06,//13060021
                                                0x4f,0x3f,0x7d,0x3f,0x3f,0x5b,0x06,0x3f,//30600210
                                                0x3f,0x7d,0x3f,0x3f,0x5b,0x06,0x3f,0x07,//06002107
                                                0x7d,0x3f,0x3f,0x5b,0x06,0x3f,0x07,0x00,//6002107
                                                0x3f,0x3f,0x5b,0x06,0x3f,0x07,0x00,0x00,//002107
                                                0x3f,0x5b,0x06,0x3f,0x07,0x00,0x00,0x00,//02107
                                                0x5b,0x06,0x3f,0x07,0x00,0x00,0x00,0x00,//2107
                                                0x06,0x3f,0x07,0x00,0x00,0x00,0x00,0x00,//107
                                                0x3f,0x07,0x00,0x00,0x00,0x00,0x00,0x00,//07
                                                0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//7
                                                0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//
                                            };        //修改學號對應的數碼管碼
                                         //0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f, 0~9
sbit we=P2^7;
sbit du=P2^6;
uchar ci=0,i,temp;
void init()                                                          //初始化
        TMOD=0x01;
        EA=1;
        ET0=1;
        TH0=(65536-46082)/256;
        TL0=(65536-46082)%256;
        TR0=1;
void delay_ms(uint z)                                  //毫秒級延時
        uint y;
        for(;z>0;z--)
                for(y=115;y>0;y--);
        init();
                for (i=0;i<8;i++)
                        P0=0;
                        du=1;
                        P0=0;
                        du=0;
                        P0=0xff;
                        we=1;
                        P0=_crol_(0xfe,i);
                        we=0;
                        P0=0;
                        du=1;
                        P0=display_lxy[ci][i];     //動態顯示
                        du=0;
                        delay_ms(1);
void print() interrupt 1
        static uchar z=0;
        z++;
        if(z==10)
                z=0;
                if (ci<19)
                        ci++;                                          //次數更新
                        ci=0;
#include <reg52.h>
                                            };        //修改學號對應的數碼管碼
sbit a=P2^2;
sbit b=P2^3;
sbit c=P2^4;                                                //端口定義
uchar ci=0,i,temp;
void init()                                                          //初始化
        TMOD=0x01;
        EA=1;
        ET0=1;
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        TR0=1;
        uint y;
        for(;z>0;z--)
                for(y=125;y>0;y--);
void display()
        P0=0; c=0;b=0;a=0; P0=display_lxy[ci][7]; delay_ms(1);
        P0=0; c=0;b=0;a=1; P0=display_lxy[ci][6]; delay_ms(1);
        P0=0; c=0;b=1;a=0; P0=display_lxy[ci][5]; delay_ms(1);
        P0=0; c=0;b=1;a=1; P0=display_lxy[ci][4]; delay_ms(1);
        P0=0; c=1;b=0;a=0; P0=display_lxy[ci][3]; delay_ms(1);
        P0=0; c=1;b=0;a=1; P0=display_lxy[ci][2]; delay_ms(1);
        P0=0; c=1;b=1;a=0; P0=display_lxy[ci][1]; delay_ms(1);
        P0=0; c=1;b=1;a=1; P0=display_lxy[ci][0]; delay_ms(1);
        init();
                display();
        static uchar z=0;
        z++;
        if(z==10)
                z=0;
                if (ci<19)
                        ci++;                                          //次數更新
                        ci=0;
