查看: 3559|回復: 0
求助!藍牙測試不成功
ID:118184 發(fā)表于 2016-5-20 09:16 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
程序如下
  Receives Test Events from your phone.
  After it gets a test message the led 13 will blink
  for one second.
#include <MeetAndroid.h>
MeetAndroid meetAndroid;
int onboardLed = 13;
int x;
void setup()
  // use the baud rate your bluetooth module is configured to
  // not all baud rates are working well, i.e. ATMEGA168 works best with 57600
  Serial.begin(57600);
  // register callback functions, which will be called when an associated event occurs.
  // - the first parameter is the name of your function (see below)
  // - match the second parameter ('A', 'B', 'a', etc...) with the flag on your Android application
  meetAndroid.registerFunction(testEvent, 'A');
  pinMode(onboardLed, OUTPUT);
  digitalWrite(onboardLed, HIGH);
void loop()
  while(Serial.available())
  x=Serial.read();
  Serial.println(x);
  meetAndroid.receive(); // you need to keep this in your loop() to receive events
* This method is called constantly.
* note: flag is in this case 'A' and numOfValues is 0 (since test event doesn't send any data)
void testEvent(byte flag, byte numOfValues)
  flushLed(300);
  flushLed(300);
void flushLed(int time)
  digitalWrite(onboardLed, LOW);
  delay(time);
  delay(time);
無論輸入什么參數(shù),結果都是0或者224,這是什么情況???
手機上使用的是Amarino2.0界面如下
