查看: 3155|回復: 1
分享lcd12864例程
ID:120821 發表于 2016-5-14 20:50 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
一些關于lcd12684的例程文件
  1. #include<reg52.h>
  2. #include<intrins.h>
  4. #define uint unsigned int
  5. sbit en=P3^4;
  6. sbit rs=P3^5;
  7. sbit rw=P3^6;
  8. sbit lcd_psb=P3^1;
  9. sbit wela=P2^6;
  10. sbit dula=P2^7;
  11. uchar code dis1[]={"清翔電子"};
  12. uchar code dis2[]={"QX-X3 開發板"};
  13. uchar code dis3[]={"祝大家生活愉快!"};
  14. uchar code dis4[]={"TEST!12864"};
  15. void delaynop()
  16. {
  17.         _nop_();
  18.         _nop_();
  19.         _nop_();
  20.         _nop_();
  21. }
  22. bit lcd_status()
  23. {
  24.         bit status;
  25.         rs=0;
  26.         rw=1;
  27.         _nop_();
  28.         _nop_();
  29.         en=1;
  30.         status=P0&0x80;
  31.         delaynop();
  32.         delaynop();
  33.         en=0;
  34.         return status;
  35. }
  36. void lcd_wcmd(uchar cmd)
  37. {
  38.         while(lcd_status());
  39.         rs=0;
  40.         rw=0;
  41.         _nop_();
  42.         _nop_();
  43.         en=1;
  44.         P0=cmd;
  45.         delaynop();
  46.         delaynop();
  47.         en=0;
  48. }
  49. void lcd_wdat(uchar dat)
  50. {
  51.         while(lcd_status());
  52.         rs=1;
  53.         rw=0;
  54.         _nop_();
  55.         _nop_();
  56.         en=1;
  57.         P0=dat;
  58.         delaynop();
  59.         delaynop();
  60.         en=0;
  61. }
  62. void lcd_pos(uchar x,y)
  63. {
  64.         uchar pos;
  65.         switch(x)
  66.         {
  67.                 case 0: x=0x80; break;
  68.                 case 1: x=0x90; break;
  69.                 case 2: x=0x88; break;
  70.                 case 3: x=0x98; break;
  71.         }
  72.         pos=x+y;
  73.         lcd_wcmd(pos);
  74. }
  75. void lcd_init()
  76. {
  77.         lcd_psb=1;
  78.         lcd_wcmd(0x30);
  79.         delaynop();
  80.         lcd_wcmd(0x0c);
  81.         delaynop();
  82.         lcd_wcmd(0x01);
  83.         delaynop();
  84. }
  85. void main()
  86. {
  87.         uchar i;
  88.         lcd_init();
  89.         lcd_pos(0,0);
  90.         i=0;
  91.         while(dis1[i]!='\0')
  92.         {
  93.                 lcd_wdat(dis1[i]);
  94.                 i++;
  95.         }
  96.         lcd_wcmd(0x34);
  97.         lcd_wcmd(0x04);
  98.         lcd_wcmd(0x30);
  99.         lcd_pos(1,0);
  100.         i=0;
  101.         while(dis2[i]!='\0')
  102.         {
  103.                 lcd_wdat(dis2[i]);
  104.                 i++;
  105.         }
  106.         lcd_pos(2,0);
  107.         i=0;
  108.         while(dis3[i]!='\0')
  109.         {
  110.                 lcd_wdat(dis3[i]);
  111.                 i++;
  112.         }
  113.         lcd_pos(3,0);
  114.         i=0;
  115.         while(dis4[i]!='\0')
  116.         {
  117.                 lcd_wdat(dis4[i]);
  118.                 i++;
  119.         }
  120.         P0=0xff;
  121.         dula=0;
  122.         wela=0;
  123.         while(1);
  124. }
例程.zip
12.76 KB, 下載次數: 26, 下載積分: 黑幣 -5
一些關于lcd12684的例程
收藏收藏1 分享淘帖 頂1 踩
ID:223702 發表于 2017-8-1 01:44 | 只看該作者
多謝分享 ,樓主好人
