查看: 14395|回復: 9
不帶字庫的lcd12864顯示程序原理圖及仿真
12864的顯示仿真電路圖
全部資料下載:
12864.rar (49.89 KB, 下載次數: 171)
不帶字庫的12864顯示程序:
  1. #include<reg51.h>
  2. #include<intrins.h>
  4. #define uint unsigned int
  5. //下面是"歡迎訪問伊人憔悴百度空間"點陣數據,一個漢字有32字節數據組成
  6. unsigned char code wu[]= // 梧
  7. {
  8. 0x10,0x10,0xD0,0xFF,0x90,0x10,0x82,0x92,0xF2,0x9E,0x92,0x92,0x92,0xF2,0x82,0x00,
  9. 0x04,0x03,0x00,0xFF,0x00,0x01,0x00,0xFC,0x44,0x44,0x44,0x44,0x44,0xFC,0x00,0x00,
  10. };
  11. unsigned char code zhou[]= //州
  12. {
  13. 0x00,0xE0,0x00,0xFF,0x00,0x20,0xC0,0x00,0xFE,0x00,0x20,0xC0,0x00,0xFF,0x00,0x00,
  14. 0x81,0x40,0x30,0x0F,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00,0xFF,0x00,0x00,
  15. };
  16. unsigned char code xue[]= //學
  17. {
  18. 0x40,0x30,0x11,0x96,0x90,0x90,0x91,0x96,0x90,0x90,0x98,0x14,0x13,0x50,0x30,0x00,
  19. 0x04,0x04,0x04,0x04,0x04,0x44,0x84,0x7E,0x06,0x05,0x04,0x04,0x04,0x04,0x04,0x00,
  20. };
  21. unsigned char code yuan[]=  //院
  22. {
  23. 0x00,0xFE,0x22,0x5A,0x86,0x10,0x0C,0x24,0x24,0x25,0x26,0x24,0x24,0x14,0x0C,0x00,
  24. 0x00,0xFF,0x04,0x08,0x07,0x80,0x41,0x31,0x0F,0x01,0x01,0x3F,0x41,0x41,0x71,0x00,
  25. };
  26. unsigned char code huan[]=  //歡
  27. {
  28. 0x04,0x24,0x44,0x84,0x64,0x9C,0x40,0x30,0x0F,0xC8,0x08,0x08,0x28,0x18,0x00,0x00,
  29. 0x10,0x08,0x06,0x01,0x82,0x4C,0x20,0x18,0x06,0x01,0x06,0x18,0x20,0x40,0x80,0x00,
  30. };
  31. unsigned char code ying[]= //迎
  32. {
  33. 0x40,0x40,0x42,0xCC,0x00,0x00,0xFC,0x04,0x02,0x00,0xFC,0x04,0x04,0xFC,0x00,0x00,
  34. 0x00,0x40,0x20,0x1F,0x20,0x40,0x4F,0x44,0x42,0x40,0x7F,0x42,0x44,0x43,0x40,0x00,
  35. };
  36. unsigned char code nin[]= //您
  37. {
  38. 0x20,0x10,0x08,0xFC,0x23,0x10,0x88,0x67,0x04,0xF4,0x04,0x24,0x54,0x8C,0x00,0x00,
  39. 0x40,0x30,0x00,0x77,0x80,0x81,0x88,0xB2,0x84,0x83,0x80,0xE0,0x00,0x11,0x60,0x00,
  40. };
  41. unsigned char code m[]= //!
  42. {
  43. 0x00,0x00,0x00,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  44. 0x00,0x00,0x00,0x33,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  45. } ;
  46. sbit CS1=P2^0;//片選1,低電平有效,CS1=0開左屏幕,CS1=1關左屏幕
  47. sbit CS2=P2^1;//片選2,低電平有效,CS2=0開右屏幕,CS2=1關右屏幕
  48. sbit RS=P2^2;//數據,指令選擇信號,RS=1為數據操作,RS=0為寫指令或讀狀態(一般為讀忙標志)
  49. sbit RW=P2^3;//讀寫選擇信號,RW=1為讀選通,RW=0為寫選通
  50. sbit EN=P2^4;//讀寫使能信號
  51. void busy()//忙檢測函數
  52. {P0=0X00; //這句不能少
  53. RS=0;
  54. RW=1;
  55. EN=1;
  56. while(P0&0X80);//P0&0X80結果為真則一直執行空操作,也就是說P0&0X80為0則結束循環
  57. EN=0;
  58. }
  59. void wcmd(uchar cmd)
  60. {busy(); //每次寫入指令或數據之前都進行忙檢測
  61. RS=0;
  62. RW=0;
  63. P0=cmd;
  64. EN=1;_nop_();_nop_();//在EN下降沿寫入數據和指令
  65. EN=0;
  66. }
  67. void wdata(uchar dat) //寫命令和寫數據只在RS=0或RS=1上不同,其余都相同
  68. {busy();
  69. RS=1;
  70. RW=0;
  71. P0=dat;
  72. EN=1;_nop_();_nop_();//在EN下降沿寫入數據和指令
  73. EN=0;
  74. }
  75. void set_page(uchar page)//設置頁,12864LCD共有8頁,每頁有8行點陣點。
  76. {page=0xb8|page;  //首頁地址為0XB8
  77. wcmd(page);                  //page取值范圍為0~7,表示第1到8頁
  78. }
  79. void set_line(uchar line)//設置顯示的起始行,共有0--63行,一般從0行開始顯示
  80. {line=0xc0|line;  //起始行地址0XC0
  81. wcmd(line);        //line取值范圍為0~63,表示第1到64行
  82. }
  83. void set_column(uchar column)//設置顯示的列
  84. {//column=column&0x3f; //列的最大值為0X3F,即64
  85. column=0x40|column;         //列的首地址為0X40,
  86. wcmd(column);                 //column的取值范圍為0~63,共64列
  87. }
  88. void set_onoff(uchar onoff)//設置顯示開關,onoff取值為0或1
  89. {onoff|=0x3e;//0X3E是關顯示,0X3F是開顯示
  90. wcmd(onoff);//所以若onoff為0,則表示關顯示,onoff為1,則表示開顯示
  91. }
  92. void select_screen(uchar screen)//選屏,screen取值范圍為0,1,2
  93. {switch(screen)
  94. {case 0:CS1=0;CS2=0;break; //全屏
  95. case 1:CS1=0;CS2=1;break;  //左半屏
  96. case 2:CS1=1;CS2=0;break;  //右半屏
  97. default:break;
  98. }
  99. }
  100. void clear_screen(uchar screen)//清屏
  101. {uchar i,j;
  102. select_screen(screen);//先選屏
  103. for(i=0;i<8;i++)//控制頁數0--7,共8頁
  104. {set_page(i);//設置頁
  105. set_column(0); //設置列,每頁都從第1列開始,共64列
  106. for(j=0;j<64;j++)//控制列數0--63,共64列
  107. wdata(0x00);//寫入0,列地址指針會自動加1
  108. }
  109. }
  110. void init()        //LCD初始化
  111. {busy(); //忙檢測
  112. select_screen(0);//選屏,全屏
  113. set_onoff(0);        //關顯示
  114. select_screen(0); //選屏,全屏
  115. set_onoff(1);          //開顯示
  116. select_screen(0); //選屏,全屏
  117. clear_screen(0);  //清屏
  118. set_line(0);          //起始行:0
  119. }
  120. void show(uchar screen,uchar page,uchar column,uchar *p)//顯示一個漢字,一個漢字有32字節數據
  121. {uchar i;        //screen表示選擇屏幕,page表示頁,column表示列,*p表示漢字的數組
  122. select_screen(screen); //選屏
  123. set_page(page);           //設置頁,寫上半頁
  124. set_column(column);//設置列
  125. for(i=0;i<16;i++) //控制16列的數據輸出
  126. wdata(p[i]);   //漢字的上半部分
  127. set_page(page+1); //寫下半頁
  128. set_column(column);        //控制列
  129. for(i=0;i<16;i++) //控制16列的數據輸出
  130. wdata(p[i+16]);         //漢字的下半部分
  131. }
  132. void main()
  133. {init();  //LCD初始化
  134. clear_screen(0); //清屏
  135. set_line(0);   //顯示開始行
  136. //1表示左屏顯示,0表示從0頁開始顯示。因為一頁只有8行點,
  137. //而顯示一個漢字需要16行點(整屏有64行點),所以顯示一個漢字需要2頁
  138. //第0頁顯示"歡"字的上半部分,第1頁顯示"歡"漢字的下半部分
  139. //2*16表示從第32列開始顯示,前面空出0~31列(即2個字的位置)
  140. show(1,2,2*16,wu);//梧
  141. //1表示左屏顯示,0表示從0頁開始顯示
  142. //3*16表示從第48列開始顯示,前面空出0~47列(即3個漢字的位置)
  143. show(1,2,3*16,zhou);//州
  144. //2表示右屏顯示,0表示從0頁開始顯示
  145. //0*16表示從第0列開始顯示(即第一個漢字的位置)
  146. show(2,2,4*16,xue);//學
  147. //1*16表示從第16列開始顯示,前面空出0~15列(即一個漢字的位置)
  148. show(2,2,5*16,yuan);         //院
  149. //左屏開,從第3頁(共8頁)第0列開始顯示,即第3,4頁顯示"伊人憔悴百度空間"幾個字
  150. show(1,4,2*16,huan);         //歡
  151. show(1,4,3*16,ying);         //迎
  152. show(2,4,4*16,nin); //您
  153. show(2,4,5*16,m); //!
  154. while(1);
  155. }
ID:120628 發表于 2016-5-13 22:32 | 只看該作者
什么來的
ID:120620 發表于 2016-5-14 10:27 | 只看該作者
萬年歷
ID:235703 發表于 2017-9-26 11:28 | 只看該作者
厲害!
ID:242198 發表于 2017-10-23 19:56 | 只看該作者
無字庫12864液晶屏漢字取模軟件用哪個呢??
ID:318113 發表于 2018-4-27 23:03 | 只看該作者
怎么實現上下
滾動
ID:328798 發表于 2018-5-13 13:00 | 只看該作者
字庫取模是怎么取的?
ID:341833 發表于 2018-6-2 16:52 | 只看該作者
你的程序寫到開發板上是                      學院梧州
                                                       您!歡迎
ID:341833 發表于 2018-6-2 18:22 | 只看該作者
仿真可以顯示正常的字劇中,到了開發板CS1,CS2用同一個IO口才可以顯示右邊一半
ID:843449 發表于 2020-12-25 18:26 | 只看該作者
取模工具用的哪一個?
