查看: 17527|回復: 6
8×8×8光立方程序、原理圖及PCB等制作資料
        這是從一個網友給你的8×8×8光立方程序、原理圖及PCB等制作資料,感覺比較好,特此將該制作資料分享給大家,下載: 8×8×8光立方程序、原理圖及PCB等.rar (3.52 MB, 下載次數: 250)
光立方的效果視頻:
元件名稱
參數規格
數量
AT89S52單片機+管座
DIP40
1
晶振
24MHZ32.678kHZ
1
電解電容
10uF
5
陶瓷電容
22P30P
2
74HC573鎖存器+管座
DIP20
8
ULN2803A+管座
DIP18
1
電阻
220R
70
電阻
10K4.7K
10
排阻
10K
1
滑動變阻器(長方體扁形)
10K
1
白發藍LED
(長腳)3*3mm
600
ISP接口座
10pin
1
USB接口
(母口)
1
單排插
成對的,上下可接
10
按鍵
10
開關
(上下按的dip6
1
PCB 覆銅板
20*25cm
2
固定銅柱(帶螺絲)
4
排線(8P)
10CM
1
導線
5
程序:
  1. #include <REG52.H>
  2. #include <intrins.h>
  4. #define uint unsigned int
  5. uchar display[8][8];
  6. /*A,1,2,3,4,I,心,U*/
  7. uchar code table_cha[8][8]={0x51,0x51,0x51,0x4a,0x4a,0x4a,0x44,0x44,0x18,0x1c,0x18,0x18,0x18,0x18,0x18,0x3c,0x3c,0x66,0x66,0x30,0x18,0xc,0x6,0xf6,0x3c,0x66,0x60,0x38,0x60,0x60,0x66,0x3c,0x30,0x38,0x3c,0x3e,0x36,0x7e,0x30,0x30,0x3c,0x3c,0x18,0x18,0x18,0x18,0x3c,0x3c,0x66,0xff,0xff,0xff,0x7e,0x3c,0x18,0x18,0x66,0x66,0x66,0x66,0x66,0x66,0x7e,0x3c};
  8. /*the "ideasoft"*/
  9. uchar code table_id[40]={0x81,0xff,0x81,0x00,0xff,0x81,0x81,0x7e,0x00,0xff,0x89,0x89,0x00,0xf8,0x27,0x27,0xf8,0x00,0x8f,0x89,0x89,0xf9,0x00,0xff,0x81,0x81,0xff,0x00,0xff,0x09,0x09,0x09,0x01,0x0,0x01,0x01,0xff,0x01,0x01,0x00};
  10. /*railway*/
  11. uchar code dat[128]={0x0,0x20,0x40,0x60,0x80,0xa0,0xc0,0xe0,0xe4,0xe8,0xec,0xf0,0xf4,0xf8,0xfc,0xdc,0xbc,0x9c,0x7c,0x5c,0x3c,0x1c,0x18,0x14,0x10,0xc,0x8,0x4,0x25,0x45,0x65,0x85,0xa5,0xc5,0xc9,0xcd,0xd1,0xd5,0xd9,0xb9,0x99,0x79,0x59,0x39,0x35,0x31,0x2d,0x29,0x4a,0x6a,0x8a,0xaa,0xae,0xb2,0xb6,0x96,0x76,0x56,0x52,0x4e,0x6f,0x8f,0x93,0x73,0x6f,0x8f,0x93,0x73,0x4a,0x6a,0x8a,0xaa,0xae,0xb2,0xb6,0x96,0x76,0x56,0x52,0x4e,0x25,0x45,0x65,0x85,0xa5,0xc5,0xc9,0xcd,0xd1,0xd5,0xd9,0xb9,0x99,0x79,0x59,0x39,0x35,0x31,0x2d,0x29,0x0,0x20,0x40,0x60,0x80,0xa0,0xc0,0xe0,0xe4,0xe8,0xec,0xf0,0xf4,0xf8,0xfc,0xdc,0xbc,0x9c,0x7c,0x5c,0x3c,0x1c,0x18,0x14,0x10,0xc,0x8,0x4};
  12. /*railway 2*/
  13. uchar code dat2[28]={0x0,0x20,0x40,0x60,0x80,0xa0,0xc0,0xe0,0xe4,0xe8,0xec,0xf0,0xf4,0xf8,0xfc,0xdc,0xbc,0x9c,0x7c,0x5c,0x3c,0x1c,0x18,0x14,0x10,0xc,0x8,0x4};
  14. /*railway 3*/
  15. uchar code dat3[24]={0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x16,0x26,0x36,0x46,0x56,0x66,0x65,0x64,0x63,0x62,0x61,0x60,0x50,0x40,0x30,0x20,0x10};
  16. /*3p char*/
  17. uchar code table_3p[3][8]={0xff,0x89,0xf5,0x93,0x93,0xf5,0x89,0xff,0x0e,0x1f,0x3f,0x7e,0x7e,0x3f,0x1f,0x0e,0x18,0x3c,0x7e,0xff,0x18,0x18,0x18,0x18};
  18. //initializtion
  19. //初始化子程序
  20. void sinter()
  21. {
  22.          IE=0x82;
  23.          TCON=0x01;
  24.          TH0=0xf0;
  25.          TL0=0;
  26.          TR0=1;
  27. }
  28. //延時子程序
  29. void delay(uint i)
  30. {
  31.          while (i--){
  32.                  _nop_();
  33.                  }
  34. }
  35. // 計算圈數
  36. uchar abs(uchar a)
  37. {
  38.          uchar b;
  39.          b=a/10;
  40.          a=a-b*10;
  41.          if (a>=5)
  42.          b++;
  43.          return b;
  44. }
  45. /*絕對值*/
  46. uchar abss(char a)
  47. {
  48.          if (a<0)
  49.          a=-a;
  50.          return a;
  51. }
  52. /*比較字符串大小,大的移后邊*/
  53. void max(uchar *a,uchar *b)
  54. {
  55.    uchar t;
  56.    if ((*a)>(*b))
  57.    {
  58.                    t=(*a);
  59.                    (*a)=(*b);
  60.                    (*b)=t;
  61.    }
  62. }
  63. /*計算最大數并返回*/
  64. uchar maxt(uchar a,uchar b,uchar c)
  65. {
  66.          if (a<b)
  67.          a=b;
  68.          if (a<c)
  69.          a=c;
  70.          return a;
  71. }
  72. //清屏子程序
  73. void clear(char le)
  74. {
  75.          uchar i,j;
  76.          for (j=0;j<8;j++)
  77.          {
  78.                    for (i=0;i<8;i++)
  79.                    display[j][i]=le;
  80.          }
  81. }
  82. //點顯示子程序
  83. void point(uchar x,uchar y,uchar z,uchar le)
  84. {
  85.          uchar ch1,ch0;
  86.          ch1=1<<x;
  87.          ch0=~ch1;
  88.          if (le)
  89.          display[z][y]=display[z][y]|ch1;
  90.          else
  91.          display[z][y]=display[z][y]&ch0;
  92. }
  93. void cirp(char cpp,uchar dir,uchar le)
  94. {
  95.          uchar a,b,c,cp;
  96.          if ((cpp<128)&(cpp>=0))
  97.          {
  98.                    if (dir)
  99.                    cp=127-cpp;
  100.                    else
  101.                    cp=cpp;
  102.                    a=(dat[cp]>>5)&0x07;
  103.                    b=(dat[cp]>>2)&0x07;
  104.                    c=dat[cp]&0x03;
  105.                    if (cpp>63)
  106.                    c=7-c;
  107.                    point (a,b,c,le);
  108.          }
  109. }
  110. //線顯示
  111. void line(uchar x1,uchar y1,uchar z1,uchar x2,uchar y2,uchar z2,uchar le)
  112. {
  113.          char t,a,b,c,a1,b1,c1,i;
  114.          a1=x2-x1;
  115.          b1=y2-y1;
  116.          c1=z2-z1;
  117.          t=maxt(abss(a1),abss(b1),abss(c1));
  118.          a=x1*10;
  119.          b=y1*10;
  120.          c=z1*10;
  121.          a1=a1*10/t;
  122.          b1=b1*10/t;
  123.          c1=c1*10/t;
  124.          for (i=0;i<t;i++)
  125.          {
  126.                    point(abs(a),abs(b),abs(c),le);
  127.                    a+=a1;
  128.                    b+=b1;
  129.                    c+=c1;
  130.          }
  131.          point(x2,y2,z2,le);
  132. }
  133. //立方顯示
  134. void box(uchar x1,uchar y1,uchar z1,uchar x2,uchar y2,uchar z2,uchar fill,uchar le)
  135. {
  136.          uchar i,j,t=0;
  137.          max(&x1,&x2);
  138.          max(&y1,&y2);
  139.          max(&z1,&z2);
  140.          for (i=x1;i<=x2;i++)
  141.                    t|=1<<i;
  142.          if (!le)
  143.                    t=~t;
  144.          if (fill)
  145.          {
  146.                    if (le)
  147.                    {
  148.                             for (i=z1;i<=z2;i++)
  149.                             {
  150.                                      for (j=y1;j<=y2;j++)
  151.                                                display[j][i]|=t;
  152.                             }
  153.                    }
  154.                    else
  155.                    {
  156.                             for (i=z1;i<=z2;i++)
  157.                             {
  158.                                      for (j=y1;j<=y2;j++)
  159.                                                display[j][i]&=t;
  160.                             }
  161.                    }
  162.          }
  163.          else
  164.          {
  165.                    if (le)
  166.                    {
  167.                             display[y1][z1]|=t;
  168.                             display[y2][z1]|=t;
  169.                             display[y1][z2]|=t;
  170.                             display[y2][z2]|=t;
  171.                    }
  172.                    else
  173.                    {
  174.                            display[y1][z1]&=t;
  175.                             display[y2][z1]&=t;
  176.                             display[y1][z2]&=t;
  177.                             display[y2][z2]&=t;
  178.                    }
  179.                    t=(0x01<<x1)|(0x01<<x2);
  180.                    if (!le)
  181.                             t=~t;
  182.                    if (le)
  183.                    {
  184.                             for (j=z1;j<=z2;j+=(z2-z1))
  185.                             {
  186.                                      for (i=y1;i<=y2;i++)
  187.                                                display[i][j]|=t;
  188.                             }
  189.                             for (j=y1;j<=y2;j+=(y2-y1))
  190.                             {
  191.                                      for (i=z1;i<=z2;i++)
  192.                                                display[j][i]|=t;
  193.                             }
  194.                    }
  195.                    else
  196.                    {
  197.                             for (j=z1;j<=z2;j+=(z2-z1))
  198.                             {
  199.                                      for (i=y1;i<=y2;i++)
  200.                                      {
  201.                                      display[i][j]&=t;
  202.                                      }
  203.                             }
  204.                             for (j=y1;j<=y2;j+=(y2-y1))
  205.                             {
  206.                                      for (i=z1;i<=z2;i++)
  207.                                      {
  208.                                      display[j][i]&=t;
  209.                                      }
  210.                             }
  211.                    }
  212.          }
  213. }
  214. //垂直于xy面的正方行
  215. void box_apeak_xy(uchar x1,uchar y1,uchar z1,uchar x2,uchar y2,uchar z2,uchar fill,uchar le)
  216. {
  217.          uchar i;
  218.          max(&z1,&z2);
  219.          if (fill)
  220.          {
  221.                    for (i=z1;i<=z2;i++)
  222.                    {
  223.                             line (x1,y1,i,x2,y2,i,le);
  224.                    }
  225.          }
  226.          else
  227.          {
  228.                    line (x1,y1,z1,x2,y2,z1,le);
  229.                    line (x1,y1,z2,x2,y2,z2,le);
  230.                    line (x2,y2,z1,x2,y2,z2,le);
  231.                    line (x1,y1,z1,x1,y1,z2,le);
  232.          }
  233. }
  234. //滾動面
  235. void roll_apeak_yz(uchar n,uint speed)
  236. {
  237.          uchar i;
  238.          switch(n)
  239.          {
  240.                    case 1:
  241.                             for (i=0;i<7;i++)
  242.                             {
  243.                                      display[i][7]=0;
  244.                                      display[7][6-i]=255;
  245.                                      delay(speed);
  246.                             };
  247.                             break;
  248.                    case 2:
  249.                             for (i=0;i<7;i++)
  250.                             {
  251.                                      display[7][7-i]=0;
  252.                                      display[6-i][0]=255;
  253.                                      delay(speed);
  254.                             };
  255.                             break;
  256.                    case 3:
  257.                             for (i=0;i<7;i++)
  258.                             {
  259.                                      display[7-i][0]=0;
  260.                                      display[0][i+1]=255;
  261.                                      delay(speed);
  262.                             };
  263.                             break;
  264.                    case 0:
  265.                             for (i=0;i<7;i++)
  266.                             {
  267.                                      display[0][i]=0;
  268.                                      display[i+1][7]=255;
  269.                                      delay(speed);
  270.                             };
  271.          }
  272. }
  273. void roll_apeak_xy(uchar n,uint speed)
  274. {
  275.          uchar i;
  276.          switch(n)
  277.          {
  278.                    case 1:
  279.                             for (i=0;i<7;i++)
  280.                             {
  281.                                      line(0,i,0,0,i,7,0);
  282.                                      line(i+1,7,0,i+1,7,7,1);
  283.                                      delay(speed);
  284.                             };
  285.                             break;
  286.                    case 2:
  287.                             for (i=0;i<7;i++)
  288.                             {
  289.                                      line(i,7,0,i,7,7,0);
  290.                                      line(7,6-i,0,7,6-i,7,1);
  291.                                      delay(speed);
  292.                             };
  293.                             break;
  294.                    case 3:
  295.                             for (i=0;i<7;i++)
  296.                             {
  297.                                      line(7,7-i,0,7,7-i,7,0);
  298.                                      line(6-i,0,0,6-i,0,7,1);
  299.                                      delay(speed);
  300.                             };
  301.                             break;
  302.                    case 0:
  303.                             for (i=0;i<7;i++)
  304.                             {
  305.                                      line(7-i,0,0,7-i,0,7,0);
  306.                                      line(0,i+1,0,0,i+1,7,1);
  307.                                      delay(speed);
  308.                             };
  309.          }
  310. }
  311. void roll_3_xy(uchar n,uint speed)
  312. {
  313.          uchar i;
  314.          switch(n)
  315.          {
  316.                    case 1:
  317.                             for (i=0;i<8;i++)
  318.                             {
  319.                                      box_apeak_xy (0,i,0,7,7-i,7,1,1);
  320.                                      delay(speed);
  321.                                      if (i<7)
  322.                                      box_apeak_xy (3,3,0,0,i,7,1,0);
  323.                             };
  324.                             break;
  325.                    case 2:
  326.                             for (i=0;i<8;i++)
  327.                             {
  328.                                       box_apeak_xy (7-i,0,0,i,7,7,1,1);
  329.                                      delay(speed);
  330.                                      if (i<7)
  331.                                      box_apeak_xy (3,4,0,i,7,7,1,0);
  332.                             };
  333.                             break;
  334.                    case 3:
  335.                             for (i=0;i<8;i++)
  336.                             {
  337.                                      box_apeak_xy (0,i,0,7,7-i,7,1,1);
  338.                                      delay(speed);
  339.                                      if (i<7)
  340.                                      box_apeak_xy (4,4,0,7,7-i,7,1,0);
  341.                             };
  342.                             break;
  343.                    case 0:
  344.                             for (i=0;i<8;i++)
  345.                             {
  346.                                      box_apeak_xy (7-i,0,0,i,7,7,1,1);
  347.                                      delay(speed);
  348.                                      if (i<7)
  349.                                      box_apeak_xy (4,3,0,7-i,0,7,1,0);
  350.                             };
  351.          }
  352. }
  353. void trans(uchar z,uint speed)
  354. {
  355.          uchar i,j;
  356.          for (j=0;j<8;j++)
  357.          {
  358.                    for (i=0;i<8;i++)
  359.                    {
  360.                             display[z][i]>>=1;
  361.                    }
  362.                    delay(speed);
  363.          }
  364. }
  365. void tranoutchar(uchar c,uint speed)
  366. {
  367.          uchar i,j,k,a,i2=0;
  368.          for (i=0;i<8;i++)
  369.          {
  370.                    if (i<7)
  371.                    box_apeak_xy (i+1,0,0,i+1,7,7,1,1);
  372.                    box_apeak_xy (i2,0,0,i2,7,7,1,0);
  373.                    a=0;
  374.                    i2=i+1;
  375.                    for (j=0;j<=i;j++)
  376.                    {
  377.                             a=a|(1<<j);
  378.                    }
  379.                    for (k=0;k<8;k++)
  380.                    {
  381.                             display[k][3]|=table_cha[c][k]&a;
  382.                             display[k][4]|=table_cha[c][k]&a;
  383.                    }
  384.                    delay(speed);
  385.          }
  386. }
  387. void transss()
  388. {
  389.          uchar i,j;
  390.          for (i=0;i<8;i++)
  391.          {
  392.                    for (j=0;j<8;j++)
  393.                    display[i][j]<<=1;
  394.          }
  395. }
  396. /*動畫程序*/
  397. void flash_1()
  398. {
  399.          uchar i;
  400.          for (i=129;i>0;i--)
  401.          {
  402.                    cirp(i-2,0,1);
  403.                    delay(800);
  404.                    cirp(i-1,0,0);
  405.          }
  406.          delay(800);
  407.          for (i=0;i<136;i++)
  408.          {
  409.                    cirp(i,1,1);
  410.                    delay(800);
  411.                    cirp(i-8,1,0);
  412.          }
  413.          delay(800);
  414.                   for (i=129;i>0;i--)
  415.          {
  416.                    cirp(i-2,0,1);
  417.                    delay(800);
  418.          }
  419.          delay(800);
  420.                    for (i=0;i<128;i++)
  421.          {
  422.                    cirp(i-8,1,0);
  423.                    delay(800);
  424.          }
  425.          delay(6000);
  426. }
  427. void flash_2()
  428. {
  429.          char i;
  430.          for (i=0;i<8;i++)
  431.          {
  432.                    box_apeak_xy(0,i,0,7,i,7,1,1);
  433.                    delay(2000);
  434.                    if (i<7)
  435.                    box_apeak_xy(0,i,0,7,i,7,1,0);
  436.          }
  437.          for (i=7;i>=0;i--)
  438.          {
  439.                    box_apeak_xy(0,i,0,7,i,7,1,1);
  440.                    delay(2000);
  441.                    if (i>0)
  442.                    box_apeak_xy(0,i,0,7,i,7,1,0);
  443.          }
  444.          for (i=0;i<8;i++)
  445.          {
  446.                    box_apeak_xy(0,i,0,7,i,7,1,1);
  447.                    delay(2000);
  448.                    if (i<7)
  449.                    box_apeak_xy(0,i,0,7,i,7,1,0);
  450.          }
  451. }
  452. void flash_3()
  453. {
  454.          char i,j,an[8];
  455.          for (j=7;j<15;j++)
  456.                    an[j-7]=j;
  457.          for (i=0;i<=16;i++)
  458.          {
  459.                    for (j=0;j<8;j++)
  460.                    {
  461.                             if ((an[j]<8)&(an[j]>=0))
  462.                             line(0,an[j],j,7,an[j],j,1);
  463.                    }
  464.                    for (j=0;j<8;j++)
  465.                    {
  466.                             if (((an[j]+1)<8)&(an[j]>=0))
  467.                             line(0,an[j]+1,j,7,an[j]+1,j,0);
  468.                    }
  469.                    for (j=0;j<8;j++)
  470.                    {
  471.                             if (an[j]>0)
  472.                             an[j]--;
  473.                    }
  474.                    delay(1500);
  475.          }
  476.          for (j=0;j<8;j++)
  477.                    an[j]=1-j;
  478.          for (i=0;i<=16;i++)
  479.          {
  480.                    for (j=0;j<8;j++)
  481.                    {
  482.                             if ((an[j]<8)&(an[j]>=0))
  483.                             line(0,an[j],j,7,an[j],j,1);
  484.                    }
  485.                    for (j=0;j<8;j++)
  486.                    {
  487.                             if (((an[j]-1)<7)&(an[j]>0))
  488.                             line(0,an[j]-1,j,7,an[j]-1,j,0);
  489.                    }
  490.                    for (j=0;j<8;j++)
  491.                    {
  492.                             if (an[j]<7)
  493.                             an[j]++;
  494.                    }
  495.                    delay(1500);
  496.          }
  497. }
  498. void flash_4()
  499. {
  500.          uint a=1500;//a=delay
  501.          char i=8,j,an[4];
  502.          //1
  503.          for (j=7;j<11;j++)
  504.                    an[j-7]=j;
  505.          while(i--)
  506.          {
  507.                    for (j=0;j<4;j++)
  508.                    {
  509.                             if (an[j]<8)
  510.                             box_apeak_xy(j,an[j],j,7-j,an[j],7-j,0,1);
  511.                             if (an[j]<7)
  512.                             box_apeak_xy(j,an[j]+1,j,7-j,an[j]+1,7-j,0,0);
  513.                    }
  514.                    for (j=0;j<4;j++)
  515.                    {
  516.                             if (an[j]>3)
  517.                             an[j]--;
  518.                    }
  519.                    delay(a);
  520.          }
  521.          //2
  522.          i=3;
  523.          for (j=0;j<4;j++)
  524.          an[j]=5-j;
  525.          while(i--)
  526.          {
  527.                    for (j=1;j<4;j++)
  528.                    {
  529.                             if (an[j]<4)
  530.                             box_apeak_xy(j,an[j],j,7-j,an[j],7-j,0,1);
  531.                             if (an[j]<3)
  532.                             box_apeak_xy(j,an[j]+1,j,7-j,an[j]+1,7-j,0,0);
  533.                    }
  534.                    for (j=0;j<4;j++)
  535.                    {
  536.                             if (an[j]>0)
  537.                             an[j]--;
  538.                    }
  539.                    delay(a);
  540.          }
  541.          //3
  542.          i=3;
  543.          for (j=1;j<4;j++)
  544.          an[j]=4-j;
  545.          while(i--)
  546.          {
  547.                    for (j=1;j<4;j++)
  548.                    {
  549.                             if (an[j]>=0)
  550.                             box_apeak_xy(j,an[j],j,7-j,an[j],7-j,0,1);
  551.                             if (an[j]>0)
  552.                             box_apeak_xy(j,an[j]-1,j,7-j,an[j]-1,7-j,0,0);
  553.                    }
  554.                    for (j=1;j<4;j++)
  555.                    {
  556.                             if (an[j]<3)
  557.                             an[j]++;
  558.                    }
  559.                    delay(a);
  560.          }
  561.          //4
  562.          i=3;
  563.          for (j=0;j<4;j++)
  564.          an[j]=j+1;
  565.          while(i--)
  566.          {
  567.                    for (j=1;j<4;j++)
  568.                    {
  569.                             if (an[j]>3)
  570.                             box_apeak_xy(j,an[j],j,7-j,an[j],7-j,0,1);
  571.                             if (an[j]>3)
  572.                             box_apeak_xy(j,an[j]-1,j,7-j,an[j]-1,7-j,0,0);
  573.                    }
  574.                    for (j=0;j<4;j++)
  575.                             an[j]++;
  576.                    delay(a);
  577.          }
  578.          //5
  579.          i=3;
  580.          for (j=3;j<6;j++)
  581.                    an[j-2]=j;
  582.          while(i--)
  583.          {
  584.                    for (j=1;j<4;j++)
  585.                    {
  586.                             box_apeak_xy(j,an[j],j,7-j,an[j],7-j,0,1);
  587.                             box_apeak_xy(j,an[j]+1,j,7-j,an[j]+1,7-j,0,0);
  588.                    }
  589.                    for (j=0;j<4;j++)
  590.                    {
  591.                             if (an[j]>3)
  592.                             an[j]--;
  593.                    }
  594.                    delay(a);
  595.          }
  596.          //6
  597.          i=3;
  598.          for (j=0;j<4;j++)
  599.          an[j]=5-j;
  600.          while(i--)
  601.          {
  602.                    for (j=1;j<4;j++)
  603.                    {
  604.                             if (an[j]<4)
  605.                             box_apeak_xy(j,an[j],j,7-j,an[j],7-j,0,1);
  606.                             if (an[j]<3)
  607.                             box_apeak_xy(j,an[j]+1,j,7-j,an[j]+1,7-j,0,0);
  608.                    }
  609.                    for (j=0;j<4;j++)
  610.                    {
  611.                             if (an[j]>0)
  612.                             an[j]--;
  613.                    }
  614.                    delay(a);
  615.          }
  616.          //7
  617.          i=3;
  618.          for (j=0;j<4;j++)
  619.          an[j]=3-j;
  620.          an[0]=2;
  621.          while(i--)
  622.          {
  623.                    for (j=0;j<3;j++)
  624.                    {
  625.                             if (an[j]>=0)
  626.                                      box_apeak_xy(j,an[j],j,7-j,an[j],7-j,0,1);
  627.                             if (an[j]>=0)
  628.                                      box_apeak_xy(j,an[j]+1,j,7-j,an[j]+1,7-j,0,0);
  629.                    }
  630.                    for (j=0;j<4;j++)
  631.                    {
  632.                             if (j<5-i)
  633.                             an[j]--;
  634.                    }
  635.                    delay(a);
  636.          }
  637.          //8
  638.          i=10;
  639.          for (j=0;j<4;j++)
  640.                    an[j]=j-2;
  641.          while(i--)
  642.          {
  643.                    for (j=0;j<4;j++)
  644.                    {
  645.                             if (an[j]>=0)
  646.                             box_apeak_xy(j,an[j],j,7-j,an[j],7-j,0,1);
  647.                             if (an[j]>=0)
  648.                             box_apeak_xy(j,an[j]-1,j,7-j,an[j]-1,7-j,0,0);
  649.                    }
  650.                    for (j=0;j<4;j++)
  651.                    {
  652.                             if (an[j]<7)
  653.                             an[j]++;
  654.                    }
  655.                    delay(a);
  656.          }
  657. }
  658. void flash_5()
  659. {
  660.       uchar i,j,k,z;
  661.       roll_apeak_yz(1,1000);
  662.       roll_apeak_yz(2,1000);
  663.       roll_apeak_yz(3,1000);
  664.       roll_apeak_yz(0,1000);
  665.       roll_apeak_yz(1,1000);
  666.       roll_apeak_yz(2,1000);
  667.       roll_apeak_yz(3,1000);
  668.       for (i=0;i<3;i++)
  669.                {
  670.                          for (j=0;j<8;j++)
  671.                          {
  672.                                   for (k=0;k<8;k++)
  673.                                   {
  674.                                            if ((table_3p[i][j]>>k)&1)
  675.                                            {
  676.                                                      for (z=1;z<8;z++)
  677.                                                               {
  678.        point (j,7-k,z,1);
  679.        if (z-1)
  680.        point (j,7-k,z-1,0);
  681.        delay(500);
  682.                                                               }
  683.                                            }
  684.                                   }
  685.                          }
  686.                          trans(7,1500);
  687.                }
  688. }
  689. void flash_6()
  690. {
  691.       uchar i;
  692.       uint a=3000;
  693.       roll_apeak_yz(0,1000);
  694.       roll_apeak_yz(1,1000);
  695.       roll_apeak_yz(2,1000);
  696.       roll_apeak_yz(3,1000);
  697.       roll_apeak_yz(0,1000);
  698.       roll_apeak_yz(1,1000);
  699.       roll_apeak_yz(2,1000);
  700.       roll_apeak_yz(3,1000);
  701.       roll_apeak_yz(0,1000);
  702.       roll_apeak_yz(1,1000);
  703.       roll_apeak_yz(2,1000);
  704.       roll_apeak_xy(0,1000);
  705.       roll_apeak_xy(1,1000);
  706.       roll_apeak_xy(2,1000);
  707.       roll_apeak_xy(3,1000);
  708.       roll_apeak_xy(0,1000);
  709.       roll_apeak_xy(1,1000);
  710.       roll_apeak_xy(2,1000);
  711.       roll_apeak_xy(3,1000);
  712.       for (i=0;i<8;i++)
  713.       {
  714.                box_apeak_xy (0,i,0,7-i,i,7,1,1);
  715.                delay(a);
  716.       }
  717.       delay(3000);
  718.       roll_3_xy(0,a);
  719.       delay(3000);
  720.       roll_3_xy(1,a);
  721.       delay(3000);
  722.       roll_3_xy(2,a);
  723.       delay(3000);
  724.       roll_3_xy(3,a);
  725.       delay(3000);
  726.       roll_3_xy(0,a);
  727.       delay(3000);
  728.       roll_3_xy(1,a);
  729.       delay(3000);
  730.       roll_3_xy(2,a);
  731.       delay(3000);
  732.       roll_3_xy(3,a);
  733.       for (i=7;i>0;i--)
  734.       {
  735.                box_apeak_xy(i,0,0,i,7,7,1,0);
  736.                delay(a);
  737.       }
  738. }
  739. void flash_7()
  740. {
  741.       uchar i;
  742.       for (i=5;i<8;i++)
  743.       {
  744.                tranoutchar(i,1000);
  745.                delay(6000);
  746.                delay(6000);
  747.       }
  748. }
  749. void flash_8()
  750. {
  751.       char i;
  752.       uchar j,an[8],x,y,t,x1,y1;
  753.       for (i=0;i<8;i++)
  754.       {
  755.                box_apeak_xy (i,0,0,i,7,7,1,1);
  756.                if (i)
  757.                box_apeak_xy (i-1,0,0,i-1,7,7,1,0);
  758.                delay(1000);
  759.       }
  760.       roll_apeak_xy(3,1000);
  761.       roll_apeak_xy(0,1000);
  762.       roll_apeak_xy(1,1000);
  763.       for (i=0;i<7;i++)
  764.       {
  765.                line(6-i,6-i,0,6-i,6-i,7,1);
  766.                line(i,7,0,i,7,7,0);
  767.                delay(1000);
  768.       }
  769.       for (i=0;i<8;i++)
  770.                an[i]=14;
  771.       for (i=0;i<85;i++)
  772.       {
  773.                clear(0);
  774.                for (j=0;j<8;j++)
  775.                {
  776.                          t=an[j]%28;
  777.                          x=dat2[t]>>5;
  778.                          y=(dat2[t]>>2)&0x07;
  779.                          t=(an[j]-14)%28;
  780.                          x1=dat2[t]>>5;
  781.                          y1=(dat2[t]>>2)&0x07;
  782.                          line(x,y,j,x1,y1,j,1);
  783.                }
  784.                for (j=0;j<8;j++)
  785.                {
  786.                if ((i>j)&(j>i-71))
  787.                an[j]++;
  788.                }
  789.                delay(500);
  790.       }
  791.       for (i=0;i<85;i++)
  792.       {
  793.                clear(0);
  794.                for (j=0;j<8;j++)
  795.                {
  796.                          t=an[j]%28;
  797.                          x=dat2[t]>>5;
  798.                          y=(dat2[t]>>2)&0x07;
  799.                          t=(an[j]-14)%28;
  800.                          x1=dat2[t]>>5;
  801.                          y1=(dat2[t]>>2)&0x07;
  802.                          line(x,y,j,x1,y1,j,1);
  803.                }
  804.                for (j=0;j<8;j++)
  805.                {
  806.                if ((i>j)&(j>i-71))
  807.                an[j]--;
  808.                }
  809.                delay(500);
  810.       }
  811.       for (i=0;i<29;i++)
  812.       {
  813.                clear(0);
  814.                t=an[0]%28;
  815.                x=dat2[t]>>5;
  816.                y=(dat2[t]>>2)&0x07;
  817.                t=(an[0]-14)%28;
  818.                x1=dat2[t]>>5;
  819.                y1=(dat2[t]>>2)&0x07;
  820.                box_apeak_xy(x,y,0,x1,y1,7,0,1);
  821.                box_apeak_xy(x,y,1,x1,y1,6,0,1);
  822.                an[0]++;
  823.                delay(500);
  824.       }
  825.       for (i=0;i<16;i++)
  826.       {
  827.                clear(0);
  828.                t=an[0]%28;
  829.                x=dat2[t]>>5;
  830.                y=(dat2[t]>>2)&0x07;
  831.                t=(an[0]-14)%28;
  832.                x1=dat2[t]>>5;
  833.                y1=(dat2[t]>>2)&0x07;
  834.                box_apeak_xy(x,y,0,x1,y1,7,1,1);
  835.                an[0]--;
  836.                delay(500);
  837.       }
  838.       for (i=0;i<8;i++)
  839.       {
  840.                line(i,i,0,0,0,i,0);
  841.                delay(500);
  842.       }
  843.       for (i=1;i<7;i++)
  844.       {
  845.                line(i,i,7,7,7,i,0);
  846.                delay(500);
  847.       }
  848.       for (i=1;i<8;i++)
  849.       {
  850.                clear(0);
  851.                box(7,7,7,7-i,7-i,7-i,0,1);
  852.                delay(1000);
  853.       }
  854.       for (i=1;i<7;i++)
  855.       {
  856.                clear(0);
  857.                box(0,0,0,7-i,7-i,7-i,0,1);
  858.                delay(1000);
  859.       }
  860.       for (i=1;i<8;i++)
  861.       {
  862.                clear(0);
  863.                box(0,0,0,i,i,i,0,1);
  864.                delay(1000);
  865.       }
  866.       for (i=1;i<7;i++)
  867.       {
  868.                clear(0);
  869.                box(7,0,0,i,7-i,7-i,0,1);
  870.                delay(1000);
  871.       }
  872.       for (i=1;i<8;i++)
  873.       {
  874.                box(7,0,0,7-i,i,i,1,1);
  875.                delay(1000);
  876.       }
  877.       for (i=1;i<7;i++)
  878.       {
  879.                clear(0);
  880.                box(0,7,7,7-i,i,i,1,1);
  881.                delay(1000);
  882.       }
  883. }
  884. void flash_9()
  885. {
  886.       uchar i,j,an[4],x,y,t;
  887.       for (i=1;i<7;i++)
  888.       {
  889.
  890.                clear(0);
  891.                box(0,6,6,1,7,7,1,1);
  892.                box(i,6,6-i,i+1,7,7-i,1,1);
  893.                box(i,6,6,i+1,7,7,1,1);
  894.                box(0,6,6-i,1,7,7-i,1,1);
  895.                box(0,6-i,6,1,7-i,7,1,1);
  896.                box(i,6-i,6-i,i+1,7-i,7-i,1,1);
  897.                box(i,6-i,6,i+1,7-i,7,1,1);
  898.                box(0,6-i,6-i,1,7-i,7-i,1,1);
  899.                delay(3000);
  900.       }
  901.       for (i=0;i<4;i++)
  902.       {
  903.                an[i]=6*i;
  904.       }
  905.       for (i=0;i<35;i++)
  906.       {
  907.                clear(0);
  908.                for(j=0;j<4;j++)
  909.                {
  910.                          t=an[j]%24;
  911.                          x=dat3[t]>>4;
  912.                          y=dat3[t]&0x0f;
  913.                          box(x,y,0,x+1,y+1,1,1,1);
  914.                          box(x,y,6,x+1,y+1,7,1,1);
  915.                }
  916.                for (j=0;j<4;j++)
  917.                an[j]++;
  918.                delay(1000);
  919.       }
  920.       for (i=0;i<35;i++)
  921.       {
  922.                clear(0);
  923.                for(j=0;j<4;j++)
  924.                {
  925.                          t=an[j]%24;
  926.                          x=dat3[t]>>4;
  927.                          y=dat3[t]&0x0f;
  928.                          box(x,y,0,x+1,y+1,1,1,1);
  929.                          box(x,y,6,x+1,y+1,7,1,1);
  930.                }
  931.                for (j=0;j<4;j++)
  932.                an[j]--;
  933.                delay(1000);
  934.       }
  935.       for (i=0;i<35;i++)
  936.       {
  937.                clear(0);
  938.                for(j=0;j<4;j++)
  939.                {
  940.                          t=an[j]%24;
  941.                          x=dat3[t]>>4;
  942.                          y=dat3[t]&0x0f;
  943.                          box(x,0,y,x+1,1,y+1,1,1);
  944.                          box(x,6,y,x+1,7,y+1,1,1);
  945.                }
  946.                for (j=0;j<4;j++)
  947.                an[j]++;
  948.                delay(1000);
  949.       }
  950.       for (i=0;i<36;i++)
  951.       {
  952.                clear(0);
  953.                for(j=0;j<4;j++)
  954.                {
  955.                          t=an[j]%24;
  956.                          x=dat3[t]>>4;
  957.                          y=dat3[t]&0x0f;
  958.                          box(x,0,y,x+1,1,y+1,1,1);
  959.                          box(x,6,y,x+1,7,y+1,1,1);
  960.                }
  961.                for (j=0;j<4;j++)
  962.                an[j]--;
  963.                delay(1000);
  964.       }
  965.       for (i=6;i>0;i--)
  966.       {
  967.
  968.                clear(0);
  969.                box(0,6,6,1,7,7,1,1);
  970.                box(i,6,6-i,i+1,7,7-i,1,1);
  971.                box(i,6,6,i+1,7,7,1,1);
  972.                box(0,6,6-i,1,7,7-i,1,1);
  973.                box(0,6-i,6,1,7-i,7,1,1);
  974.                box(i,6-i,6-i,i+1,7-i,7-i,1,1);
  975.                box(i,6-i,6,i+1,7-i,7,1,1);
  976.                box(0,6-i,6-i,1,7-i,7-i,1,1);
  977.                delay(3000);
  978.       }
  979. }
  980. void flash_10()
  981. {
  982.       uchar i,j,t,x,y;
  983.       uchar code daa[13]={0,1,2,0x23,5,6,7,6,5,0x23,2,1,0};
  984.       for (j=0;j<5;j++)
  985.       {
  986.                for (i=0;i<13;i++)
  987.                {
  988.                          if (daa[i]>>4)
  989.                          {
  990.                                   t=daa[i]&0x0f;
  991.                                   line (0,0,t+1,0,7,t+1,1);
  992.                          }
  993.                          else
  994.                                   t=daa[i];
  995.                          line (0,0,t,0,7,t,1);
  996.                          transss();
  997.                          delay(1000);
  998.                }
  999.       }
  1000.       for (j=1;j<8;j++)
  1001.       {
  1002.                if (j>3)
  1003.                          t=4;
  1004.                else
  1005.                          t=j;
  1006.                for (i=0;i<24;i+=j)
  1007.                {
  1008.                          x=dat3[i]>>4;
  1009.                          y=dat3[i]&0x0f;
  1010.                          box_apeak_xy(0,x,y,0,x+1,y+1,1,1);
  1011.                          transss();
  1012.                          delay(1000);
  1013.                }
  1014.       }
  1015.       for (j=1;j<8;j++)
  1016.       {
  1017.                if (j>3)
  1018.                          t=4;
  1019.                else
  1020.                          t=j;
  1021.                for (i=0;i<24;i+=j)
  1022.                {
  1023.                          x=dat3[i]>>4;
  1024.                          y=dat3[i]&0x0f;
  1025.                          point (0,x,y,1);
  1026.                          transss();
  1027.                          delay(1000);
  1028.                }
  1029.       }
  1030. }
  1031. void main()
  1032. {
  1033.
  1034.          sinter();
  1035.                  while(1){
  1036.
  1037.
  1038.       clear(0);
  1039.       flash_1();
  1040.       flash_2();
  1041.       flash_3();
  1042.       flash_4();
  1043.       flash_5();
  1044.       flash_6();
  1045.       flash_7();
  1046.       flash_8();
  1047.       flash_9();
  1048.       clear (0);
  1049.       flash_10();
  1050.
  1051.          }
  1052. }
  1053. //P0;   //573 in
  1054. //P1;  //uln2803
  1055. //P2;  //573 LE
  1056. void print() interrupt 1//顯示中斷,不斷刷新數組中的數據
  1057. {
  1058.          uchar i;
  1059.          static uchar layer=0;
  1060.          P1=0;
  1061.          for (i=0;i<8;i++)
  1062.          {
  1063.                    P2=1<<i;
  1064.                    delay(3);
  1065.                    P0=display[layer][i];
  1066.                    delay(3);
  1067.          }
  1068.          P1=1<<layer;
  1069.          if (layer<7)
  1070.                    layer++;
  1071.          else
  1072.                    layer=0;
  1073.          TH0=0xf0;
  1074.          TL0=0;
  1075. }
收藏收藏5 分享淘帖 頂 踩
ID:175687 發表于 2017-4-10 14:53 | 只看該作者
請問程序中flash函數的功能是什么?主程序一開始就執行flash,但是flash函數并沒有向P0、P1、P2發送控制命令?
ID:236177 發表于 2017-9-27 21:33 | 只看該作者
那位朋友給我發個原理圖(protuse),光看程序有些難懂。
ID:187096 發表于 2018-2-3 15:15 | 只看該作者
謝謝分享
ID:202184 發表于 2018-2-6 21:12 | 只看該作者
厲害,請教一下你電腦上那個軟件是什么?
ID:328609 發表于 2018-5-27 00:28 | 只看該作者
好的,這程序適合我用
ID:163002 發表于 2020-3-21 19:38 | 只看該作者
這個可以顯示溫度嗎
