查看: 3059|回復: 1
舵機的控制程序 51單片機寫的
ID:118923 發(fā)表于 2016-5-6 19:23 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
//請根據自己馬達的控制 來改變程序
#include<reg52.h>
#include<math.h>
#include<intrins.h>
uchar Buffer =0;      //從串口接收的數據
uint URTAReceivedCount=0,n=1;
uchar data Tempdatatable[5],CommandDatatable[5];//數據包
uchar serVal[2];
//uint pwm[]={1120,1190,1382,1382,1382,1382,1382,1382}; //初始90度,(實際是1382.4,取整得1382)
//uchar pwm_flag=0;
uint code ms0_5Con=461; //0.5ms計數 (實際是460.8,取整得461)
uint code ms2_5Con=2304; //2.5ms計數
bit key_stime_ok;
void Delay_1ms(uint i)//1ms延時
uchar x,j;
for(j=0;j
for(x=0;x<=148;x++);
void Send_Data(uchar type,uchar cmd,uchar dat)
   uchar data Buffer[5];//構建數據包
   uchar *p;
   uint Send_Count=0;
   p = Buffer;
   Buffer[0]=0XFF;
   Buffer[1]=type;
   Buffer[2]=cmd;
   Buffer[3]=dat;
   Buffer[4]=0XFF;
      if(*p==0XFF)
         Send_Count++;  //0XFF標志統(tǒng)計位
      SBUF = *p;  //發(fā)送
      while(!TI)  //如果發(fā)送完畢,硬件會置位TI,等待發(fā)送完畢
             _nop_();
      p++;
      TI = 0;
      if(Send_Count == 2)  //當統(tǒng)計到兩次出現0XFF,則認為一個數據包發(fā)送完畢,跳出循環(huán)
         TI = 0;
         break;
void Com_Int(void) interrupt 4
uchar temp;
ES=0; //關串口中斷
RI=0; //軟件清除接收中斷
temp=SBUF;
  if(temp==0XFF && URTAReceivedCount<3)
       Tempdatatable[0]==0XFF;  //包頭
       URTAReceivedCount++;
       Tempdatatable[n]=temp;
       n++;
       if(URTAReceivedCount==0&&n==2)
       n=1;
  if(URTAReceivedCount==2)//包尾
       Tempdatatable[0]=0XFF;
       Tempdatatable[4]=0XFF;
       n=1;
       URTAReceivedCount=0;  //組包完畢
       temp=" ";
      // Send_Data(Tempdatatable[1],Tempdatatable[2],Tempdatatable[3]);  //發(fā)送組成的數據包回去
  CommandDatatable[0]=Tempdatatable[0];
  CommandDatatable[1]=Tempdatatable[1];
  CommandDatatable[2]=Tempdatatable[2];
  CommandDatatable[3]=Tempdatatable[3];
  CommandDatatable[4]=Tempdatatable[4];
  ES=1;//開串口中斷
void Com_Init(void)
     TMOD = 0x21;
     PCON = 0x00;
     SCON = 0x50;
     TH1 = 0xFd;    //設置波特率 9600
     TL1 = 0xFd;
     TR1 = 1;  //啟動定時器1
     ES = 1;  //開串口中斷
     EA = 1;  //開總中斷
     IT0=0;
     EX0=1;
    Delay_1ms(200);
    Com_Init();//串口初始化
    Timer0Init();//舵機PWM中斷初始化
   if(CommandDatatable[0]==0XFF && CommandDatatable[4]==0XFF)
           switch (CommandDatatable[1])      //根據鍵值不同,執(zhí)行不同的內容
              case 0X00:  //類型位0X00,表明是控制數據包,進入控制數據case
                  switch(CommandDatatable[2])  //根據數據位的值來進行選擇執(zhí)行不同的動作
                             case 0X00:Moto_Stop();break;
                             case 0X01:Moto_Forward();break;
                             case 0X02:Moto_Backward();break;
                             case 0X03:Moto_TurnLeft();break;
                             case 0X04:Moto_TurnRight();break;
                             case 0X05:Moto_ForLeft();break;
                             case 0X06:Moto_ForRight();break;
                             case 0X07:Moto_BackLeft();break;
                             case 0X08:Moto_BackRight();break;
                             default :  break;
                         break;
                         default :  break;
ID:241541 發(fā)表于 2020-4-20 12:12 | 只看該作者
挺好,借鑒了
