查看: 1752|回復: 0
自己做的單片機程序
ID:118121 發表于 2016-5-3 13:02 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
/************漢字點陣*************/
uchar code hanzi[4][32] =
{    //一個漢字分兩行,所以數組二維數為字數的兩倍
{0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0xFF,0xFF,0x01,0x02,0x01,0x84,0x05,0x48,
0x09,0x20,0x11,0x10,0x21,0x08,0x41,0x04,0x01,0x04,0x01,0x02,0x01,0x02,0x00,0x00},/*"長",0*/
{0x08,0x20,0x06,0x20,0x40,0x3E,0x30,0xC0,0x03,0x04,0x20,0x04,0x20,0x04,0x20,0x04,
0x20,0x04,0x3F,0xFC,0x20,0x04,0x20,0x04,0x20,0x04,0x20,0x04,0x00,0x04,0x00,0x00},/*"江",1*/
/*"江",1*/
{0x04,0x01,0x04,0x01,0x04,0x02,0x04,0x04,0x04,0x08,0x04,0x30,0x04,0xC0,0xFF,0x00,
0x04,0xC0,0x04,0x30,0x04,0x08,0x04,0x04,0x04,0x02,0x04,0x01,0x04,0x01,0x00,0x00},/*"大",0*/
{0x02,0x20,0x0C,0x20,0x88,0x20,0x69,0x20,0x09,0x20,0x09,0x22,0x89,0x21,0x69,0x7E,
0x09,0x60,0x09,0xA0,0x19,0x20,0x28,0x20,0xC8,0x20,0x0A,0x20,0x0C,0x20,0x00,0x00},/*"學",1*/
/************位定義**************/
sbit STTP = P2^7;
/************變量聲明***********/
uint n,i,j;   //delay()延時函數計數變量
uint x,y,z;   //out_hanzi()
/************函數聲明***********/
void delay(uint n);   //延時函數
void out_rxd(uchar *d);    //漢字輸出
/************主函數**************/
SCON = 0x00;
  P1 = 0;
  for( x = 0; x < 32; x+=2)
   STTP = 0;
   out_rxd(&hanzi[3][x+1]);
   out_rxd(&hanzi[3][x]);
   out_rxd(&hanzi[2][x+1]);
   out_rxd(&hanzi[2][x]);
   out_rxd(&hanzi[1][x+1]);
   out_rxd(&hanzi[1][x]);
   out_rxd(&hanzi[0][x+1]);
   out_rxd(&hanzi[0][x]);
   STTP = 1;
   P1 = x/2;
/************子函數定義?********/
void delay(uint n)
  for( ; n > 0 ; n--)
   for( j = 0; j < 10; j++)
SBUF = *d;   //啟動串行口傳送
while(TI == 0);   //等待串口傳送結束
TI = 0;    //將串口中斷標志位置0
