帶溫度報警功能
- /*#include<reg52.h>
- #include<intrins.h>
- #define uint unsigned int
- #define uchar unsigned char
- sbit DQ=P3^7; //連接DS18B20
- sbit rs=P2^7; //??1602 RS?
- sbit rw= P2^6; //??1602 ?R/W?,???????
- sbit en=P2^5; //??1602 E?
- /*****************Happy Everyday!**************/
- //DS18B20????,?????1602????!???!
- //DS18B20????,LCD1602??
- #include<reg52.h>
- uchar table[]={" temp:"};
- uchar table1[]={"warntemp: "};
- /********IO????**********/
- sbit rs=P0^7;
- sbit rw=P0^6;
- sbit en=P0^5;
- sbit dq=P3^7;
- sbit beep=P3^6;
- sbit led1=P1^0;
- sbit key1=P3^5;
- sbit key2=P3^4;
- sbit key3=P3^3;
- sbit key4=P3^2;
- uchar num;
- uint tempwarn,d=0,h=0;
- uint warntem=31;
- void delay(uint n) //????
- while(n>0)n--;
- void write_com(uchar com) //???????
- rs=0; //?0????
- en=0; //?????????
- P2=com; //?com??,????????P2?
- delay(100); //??,???????????
- en=1; //????,0?1??????????????????
- delay(100);
- en=0; //??????
- void write_data(uchar date) //???????
- rs=1; //?1??????
- en=0;
- P2=date; //?date??,???????P2?
- delay(100);
- en=1;
- delay(100);
- en=0;
- void init() //???????
- en=0;
- write_com(0x38); //??16X2??,5X7??,8????
- write_com(0x0c); //?????,?????
- write_com(0x06); //???????????1
- write_com(0x01); //???0,?????0
- void Writebyte(uchar dat)//DS18B20??????????
- uchar j;
- for(j=0;j<8;j++)
- dq=0;
- dq=dat&0x01;
- delay(5);
- dq=1;
- dat>>=1;
- uchar Readbyte(void)//DS18B20?????????
- uchar i,dat=0;
- for(i=0;i<8;i++)
- dq=0;
- dat>>=1;
- dq=1;
- if(dq==1)
- dat|=0x80;
- delay(4);
- return dat;
- void initds18b20(void)//?????????
- uchar x=0;
- dq=1;
- delay(8);
- dq=0;
- delay(80);
- dq=1;
- delay(14);
- x=dq;
- delay(20);
- void Readtemp(void)//?????
- initds18b20();
- Writebyte(0xcc);
- Writebyte(0x44);
- initds18b20();
- Writebyte(0xcc);
- Writebyte(0xbe);
- d=Readbyte(); //??????8?????
- h=Readbyte(); //??????8?????
- convert() //????????,???????????????
- uint temp,tmp;
- float tt,yy;
- tmp=d; //?8????tmp
- temp=h; //?8????temp
- temp<<=8; //?8???8?
- temp|=d; //??8?????????temp
- if((h&0x80)!=0) //?8?h&10000000???0,??0??????
- table[7]='-'; //?-????????8???,??-???8?,1602???16???
- temp=temp-1;
- temp=~temp;
- else
- table[7]='+';
- temp>>=4;
- table[8]=(temp/100)+'0'; //???9??????????,??120??1
- table[9]=(temp/10)%10+'0'; //???10??????????,??120??2
- table[10]=(temp%10)+'0'; //???9??????????,??120??0
- tmp=tmp&0x0f; //??????????
- tt=tmp*0.0625; //????????
- table[11]='.'; //?????
- table[12]=((uchar)(tt*10))%10+'0';//??????????
- table[13]='.';
- table[14]='C';
- tempwarn=temp;
- warntem>>=4;
- table1[8]=(warntem/100)+'0'; //???9??????????,??120??1
- table1[9]=(warntem/10)%10+'0'; //???10??????????,??120??2
- table1[10]=(warntem%10)+'0'; //???9??????????,??120??0
- warntem=warntem&0x0f; //??????????
- yy=warntem*0.0625; //????????
- table1[11]='.'; //?????
- table1[12]=((uchar)(tt*10))%10+'0';//??????????
- table1[13]='.';
- table1[14]='C';
- return tempwarn;//?????
- void warn(uint tempwarn)//??????
- if(tempwarn<=warntem) //?????????,??????20????????????
- beep=0;
- delay(5000);//??????????
- beep=0;
- delay(50000); //???????????
- led1=1;
- else if(tempwarn>warntem)//??????25???????
- beep=~beep;
- led1=0;
- //delay(300);
- //beep=1;
- //delay(300));
- void main()
- rw=0; //rw???0,?????????,?????????????,??!!!
- init(); //???????
- if(key1==0)
- delay(5); //消抖動
- if(key1==0) //確認按鍵被按下
- while(!key1);//松手檢測
- warntem+=1;
- if(key2==0)
- delay(5); //消抖動
- if(key2==0) //確認按鍵被按下
- while(!key2);//松手檢測
- warntem-=1;
- //write_com(0x80+0x40); //0x80+0x40????????????
- //for(num=0;num<15;num++) //num<16,16????16?
- // write_data(table1[num]);//?????????,?????????,??????dengtianming
- while(1) //???,?????????
- Readtemp();
- convert();
- warn(tempwarn);
- write_com(0x80); //??????????
- for(num=0;num<15;num++)//??16???,?????????????16,????????????????????
- write_data(table[num]);//?????????
- write_com(0x80+0x40); //0x80+0x40????????????
- for(num=0;num<15;num++) //num<16,16????16?
- write_data(table1[num]);//?????????,?????????,??????dengtianming
- //table1[11]=warntem/10;
- //table1[12]=warntem%10;
- // table1[13]='.';
- //table1[14]='C';
18B20程序.rar
2016-4-13 22:50 上傳
下載積分: 黑幣 -5
32.3 KB, 下載次數: 25, 下載積分: 黑幣 -5
