這可是我自己寫的CAN總線的程序呀,里面有模擬各傳感器的功能,比如汽車儀表,溫度還有油門等,血汗來的
2016-4-12 03:03 上傳
; LINS08AW60 v.1.0
; filelist.txt
; Copyright (C) 2005 Freescale Semiconductor, Inc.
; All Rights Reserved
; LINS08AW60 file list
.\filelist.txt ; List of LIN S08 files
.\readme.txt ; Readme
.\license.txt ; License statement
.\inc:
.\inc\l_api.h ; User's main header (for LIN API)
.\inc\lintmr.h ; Timer routines header file
.\inc\linstd.h ; Define LIN driver data types
.\inc\linsci.h ; SCI routines header file
.\inc\linprot.h ; LIN Protocol header file.
.\inc\linmsgid.h ; User's Message configuration (for Freescale API)
.\inc\linmsg.h ; Message processing subsystem header file
.\inc\lininit.h ; LIN Driver initialization header file
.\inc\linerr.h ; LIN Error management header file
.\inc\lindef.h ; LIN Driver data types and definitions
.\inc\lindbg.h ; Debug routines header file
.\inc\lincfg.h ; User's Driver configuration (for Freescale API)
.\inc\linbase.h ; Includes all needed files for developers
.\inc\linapi.h ; User's main header (for Freescale API)
.\man: ;
.\man\lin.pdf ; User manual
.\S08:
.\S08\vector.c ; Interrupt vectors (for Freescale API)
.\S08\regs.h ; Register definition file
.\sample: ; Sample application
.\sample\inc\master.h ; Header file for master
.\sample\inc\master_option.h ; Header file for preprocessor definitions
.\sample\inc\slave.h ; Header file for slave
.\sample\inc\slave_option.h ; Header file for preprocessor definitions
.\sample\src\master.c ; Source code of sample master
.\sample\src\slave.c ; Source code of sample slave
.\sample\LIN config\master.cfg ; Driver configuration file
.\sample\LIN config\master.id ; Message configuration file
.\sample\LIN config\slave.cfg ; Driver configuration file
.\sample\LIN config\slave.id ; Message configuration file
.\sample\prm\S08AW60.prm ; Parameter file for the sample project
.\sample\sample.mcp ; Sample project file
.\sample\BDM_P&E_Multilink_CyclonePro.ini ; MW Debugger initialisation file
.\sample\C_Layout.hwl ; MW Debugger layout file
.\src:
.\src\l_cfg.c ; LIN S08 configuration source (for LIN API)
.\src\lintmr.c ; LIN Timeout management module
.\src\linsci.c ; SCI management module
.\src\linprot.c ; LIN Protocol module. Master and Slave State Machines
.\src\linmsgid.c ; Message configuration source (for Freescale API)
.\src\linmsg.c ; Message processing subsystem
.\src\lininit.c ; LIN Driver initialization
.\src\linerr.c ; LIN Error management module
.\src\lincfg.c ; LIN S08 configuration source (for Freescale API)
.\src\linapi.c ; Some API realization
CAN2.rar
2016-4-12 03:03 上傳
下載積分: 黑幣 -5
449.41 KB, 下載次數(shù): 17, 下載積分: 黑幣 -5
