vhdl編的多功能電子秒表,可以記錄幾個(gè)人的時(shí)間,并且可以在跑秒的時(shí)候查看記錄。
- library ieee;
- use ieee.std_logic_1164.all;
- use ieee.std_logic_unsigned.all;
- use ieee.std_logic_arith.all;
- entity clock is
- port( cp:in std_logic;
- minten: out std_logic_vector(3 downto 0);
- min : out std_logic_vector(3 downto 0);
- secten: out std_logic_vector(3 downto 0);
- sec: out std_logic_vector(3 downto 0);
- stop: in std_logic;
- reset: in std_logic;
- lamp: out std_logic;
- lam: out std_logic;
- read: in std_logic);
- end clock;
- architecture a of clock is
- signal mten: integer range 0 to 9;
- signal m: integer range 0 to 9;
- signal sten: integer range 0 to 9;
- signal ss: integer range 0 to 9;
- signal read_signal:integer range 0 to 3;
- signal ta : integer range 0 to 10;
- signal tb : integer range 0 to 10;
- signal tc : integer range 0 to 10;
- signal td : integer range 0 to 10;
- signal xa : integer range 0 to 10;
- signal xb : integer range 0 to 10;
- signal xc : integer range 0 to 10;
- signal xd : integer range 0 to 10;
- signal stop_signal: std_logic;
- begin
- -------------------stop_signal---------------
- process(stop)
- begin
- if stop'event and stop='1' then
- stop_signal<=not stop_signal;
- end if;
- end process;
- ------------------clock goes------------------
- process(cp)
- begin
- if cp'event and cp='1' then
- if reset='0' then
- if stop_signal='1' then
- if ss=9 then
- ss<=0;
- if sten=5 then
- sten<=0;
- if m=9 then
- m<=0;
- if mten=5 then
- mten<=0;
- else mten<=mten+1;
- end if;
- else m<=m+1;
- end if;
- else sten<=sten+1;
- end if;
- else ss<=ss+1;
- end if;
- end if;
- else mten<=0;
- m<=0;
- sten<=0;
- ss<=0;
- end if;
- end if;
- end process;
- ------------------------------read_signal-----------
- process(read)
- begin
- if read'event and read='1' then
- if read_signal=2 then read_signal<=0 ;else read_signal<=read_signal+1 ; end if ;
- end if;
- end process;
- --------------------record--------------
- process(read_signal)
- begin
- case read_signal is
- when 1=> ta<=ss;tb<=sten; tc<=m; td<=mten;lamp<='1';lam<='0';
- when 2=> xa<=ss;xb<=sten; xc<=m; xd<=mten;lam<='1'; lamp<='0';
- when others => lamp<='0' ;lam<='0';
- end case;
- end if;
- end process;
- ------------------------display--------------
- process(cp,read_signal)
- begin
- when 1=>if stop_signal='0' then
- minten<=conv_std_logic_vector(td,4);
- min<=conv_std_logic_vector(tc,4);
- secten<=conv_std_logic_vector(tb,4);
- sec<=conv_std_logic_vector(ta,4);
- end if;
- when 2=>
- if stop_signal='0' then
- minten<=conv_std_logic_vector(xd,4);
- min<=conv_std_logic_vector(xc,4);
- secten<=conv_std_logic_vector(xb,4);
- sec<=conv_std_logic_vector(xa,4);
- end if;
- when others=>
- minten<=conv_std_logic_vector(mten,4);
- min<=conv_std_logic_vector(m,4);
- secten<=conv_std_logic_vector(sten,4);
- sec<=conv_std_logic_vector(ss,4);
- end case;
- end process;
- end a;
