只需一步,快速開(kāi)始
查看: 2150|回復(fù): 0
單片機(jī)智能小車(chē)源程序
ID:112047 發(fā)表于 2016-4-3 16:17 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
   /*預(yù)處理命令*/
#include<reg52.h>    //包含單片機(jī)寄存器的頭文件
#include<intrins.h> //包含_nop_()函數(shù)定義的頭文件
#define uint  unsigned int
#define delayNOP(); {_nop_();_nop_();_nop_();_nop_();};
sbit IRIN=P3^2;         //紅外接收器數(shù)據(jù)線(xiàn)
sbit LCD_RS = P0^7;
sbit LCD_RW = P0^6;
sbit LCD_EN = P0^5;
uchar begin[]={"My car!"};
uchar cdis1[]={"jiansu!"};
uchar cdis2[]={"qianjin!"};
uchar cdis3[]={"jiasu!"};
uchar cdis4[]={"zuozhuang!"};
uchar cdis5[]={"STOP!"};
uchar cdis6[]={"youzhuan!"};
uchar cdis8[]={"daoche!"};
sbit M1   = P1^0;
sbit M2   = P1^1;
sbit M3   = P1^2;
sbit M4   = P1^3;
sbit EN12 = P1^4;
sbit EN34 = P1^5;
uchar IRCOM[7];
uchar m,n;
uchar t=2;
uchar g;
uchar code digit[]={"0123456789"};
uint v;
uchar count;
bit flag;
void delayxms(uchar t);
void delay(unsigned char x) ;
void delay1(int ms);
void motor();
void lcd_display();
檢查LCD忙狀態(tài)
lcd_busy1時(shí),忙,等待。lcd-busy0時(shí),閑,可寫(xiě)指令與數(shù)據(jù)
bit lcd_busy()
        bit result;
        LCD_RS = 0;
        LCD_RW = 1;
        LCD_EN = 1;
        delayNOP();
        result = (bit)(P0&0x80);
        LCD_EN = 0;
        return(result);
寫(xiě)指令數(shù)據(jù)到LCD
RS=L,RW=L,E=高脈沖,D0-D7=指令碼
void lcd_wcmd(uchar cmd)
   while(lcd_busy());
    LCD_RS = 0;
    LCD_RW = 0;
    LCD_EN = 0;
    _nop_();
    _nop_();
    P2 = cmd;
    delayNOP();
    LCD_EN = 1;
    delayNOP();
    LCD_EN = 0;
寫(xiě)顯示數(shù)據(jù)到LCD
RS=H,RW=LE=高脈沖,D0-D7=數(shù)據(jù)
void lcd_wdat(uchar dat)
   while(lcd_busy());
    LCD_RS = 1;
    LCD_RW = 0;
    LCD_EN = 0;
    P2 = dat;
    delayNOP();
    LCD_EN = 1;
    delayNOP();
    LCD_EN = 0;
LCD初始化設(shè)定
void lcd_init()
    delay1(15);
    lcd_wcmd(0x38);      //16*2顯示,5*7點(diǎn)陣,8位數(shù)據(jù)
    delay1(5);
    lcd_wcmd(0x38);
    delay1(5);
    lcd_wcmd(0x38);
    delay1(5);
    lcd_wcmd(0x0c);      //顯示開(kāi),關(guān)光標(biāo)
    delay1(5);
    lcd_wcmd(0x06);      //移動(dòng)光標(biāo)
    delay1(5);
    lcd_wcmd(0x01);      //清除LCD的顯示內(nèi)容
    delay1(5);
設(shè)定顯示位置
void lcd_pos(uchar pos)
        lcd_wcmd(pos | 0x80);  //數(shù)據(jù)指針=80+地址變量
/*x顯示速度提示符*/
void  display_sym(void)
lcd_pos(0x00);
lcd_wdat('v');
lcd_wdat('=');
/*顯示速度數(shù)值*/
void display_vel(uint x)
uchar i,j,k,l;
i=x/1000;             //取千位
j=(x%1000)/100;         //取百位
k=(x%100)/10;         //取十位
l=x%10;                         //取個(gè)位
lcd_pos(0x02);
lcd_wdat(digit);
lcd_wdat(digit[j]);
lcd_wdat(digit[k]);
lcd_wdat(digit[l]);
/*顯示速度單位*/
void display_unit(void)
lcd_pos(0x06);
lcd_wdat('r');
lcd_wdat('/');
lcd_wdat('m');
lcd_wdat('i');
lcd_wdat('n');
主函數(shù)
        uint a;
        IRIN=1;                    //I/O口初始化
        IE=0x83;                 //允許總中斷中斷,使能 INT0 外部中斷
        TCON=TCON|0x01;               //觸發(fā)方式為脈沖負(fù)邊沿觸發(fā)
        lcd_init();
        TMOD=0x51;
    TH0=(65536-50000)/256;
    TL0=(65536-50000)/256;
    TR0=1;
    count=0;
    display_sym();
    display_vel(0);
    display_unit();
        lcd_pos(0x40);
        g=0;
        while(begin[g]!='\0')
           lcd_wdat(begin[g]);
           g++;
      TR1=1;
      TH1=0;
      TL1=0;
      flag=0;
          display_sym();
          display_unit();
      while(flag==0);
      v=(TH1*256+TL1)*60/20;
      display_vel(v);
          motor();
void IR_IN() interrupt 0 using 0
        unsigned char j,k,N=0;
        unsigned char q=0;
        EX0 = 0;
        delay(15);
        if (IRIN==1)
                EX0 =1;
                return;
                   //確認(rèn)IR信號(hào)出現(xiàn)
        while (!IRIN)            //IR變?yōu)楦唠娖,跳過(guò)9ms的前導(dǎo)低電平信號(hào)。
                delay(1);
        for (j=0;j<4;j++)         //收集四組數(shù)據(jù)
                for (k=0;k<8;k++)        //每組數(shù)據(jù)有8
                        while (IRIN)            //IR 變?yōu)榈碗娖,跳過(guò)4.5ms的前導(dǎo)高電平信號(hào)。
                        {delay(1);}
                        while (!IRIN)          //IR 變?yōu)楦唠娖?/font>
                                delay(1);
                        while (IRIN)           //計(jì)算IR高電平時(shí)長(zhǎng)
                                delay(1);
                                N++;
                                if (N>=30)
                                        EX0=1;
                                        return;
                                }                  //0.14ms計(jì)數(shù)過(guò)長(zhǎng)自動(dòng)離開(kāi)。
                        }                        //高電平計(jì)數(shù)完畢
                        IRCOM[j]=IRCOM[j] >> 1;     //數(shù)據(jù)最高位補(bǔ)“0
                        if(N>=8)
                                IRCOM[j] = IRCOM[j] | 0x80;                  //數(shù)據(jù)最高位補(bǔ)“1
                        N=0;
        if(IRCOM[2]!=~IRCOM[3])
                EX0=1;
                return;
        IRCOM[5]=IRCOM[2] & 0x0F;     //取鍵碼的低四位
        IRCOM[6]=IRCOM[2] >> 4;       //右移4次,高四位變?yōu)榈退奈?/font>
        if(IRCOM[5]>9)
                IRCOM[5]=IRCOM[5]+0x37;
        IRCOM[5]=IRCOM[5]+0x30;
        if(IRCOM[6]>9)
                IRCOM[6]=IRCOM[6]+0x37;
        IRCOM[6]=IRCOM[6]+0x30;
        q= (((IRCOM[6]&0x0f)<<4) + (IRCOM[5]&0x0f));
        switch(q)    //判斷按鍵鍵碼值
                case 0x16:m=0;break; //串口發(fā)送0
                case 0x03:m=1;t++;if(t>=5)t=4;break;  //串口發(fā)送01
                case 0x18:m=2;n=2;break;              //串口發(fā)送02
                case 0x55:m=3;t--;if(t<=0)t=0;break;  //串口發(fā)送03
                case 0x08:m=4;n=4;break;              //串口發(fā)送04
                case 0x13:m=5;n=5;break;              //串口發(fā)送05
                case 0x51:m=6;n=6;break;              //串口發(fā)送06
                case 0x42:m=7;break;                  //串口發(fā)送07
                case 0x52:m=8;n=8;break;              //串口發(fā)送08
                case 0x41:m=9;break;                  //串口發(fā)送09
                default :break;
     lcd_display();
         EX0 = 1;
/***************延時(shí)函數(shù)*****************************/
void delay(unsigned char x)    //x*0.14MS
        unsigned char i;
        while(x--)
                for (i = 0; i<13; i++) {}
void lcd_display()
    g=0;
        switch(        m)
          case 1:  lcd_init();
                    lcd_pos(0x40);
                while(cdis1[g]!='\0')        //減速
                                   lcd_wdat(cdis1[g]);
                          g++;
                }break;
        case 2:         lcd_init();
                    lcd_pos(0x40);                             //前進(jìn)
                while(cdis2[g]!='\0')
                                  lcd_wdat(cdis2[g]);
                         g++;
                     }break;
     case 3:   lcd_init();
                    lcd_pos(0x40);                                  //加速
                while(cdis3[g]!='\0')
                                    lcd_wdat(cdis3[g]);
                        g++;
                      }break;
        case 4:           lcd_init();
                    lcd_pos(0x40);                    //左轉(zhuǎn)
                while(cdis4[g]!='\0')
                               lcd_wdat(cdis4[g]);
                       g++;
                      }break;
        case 5:           lcd_init();
                    lcd_pos(0x40);                          //停車(chē)
                while(cdis5[g]!='\0')
                                    lcd_wdat(cdis5[g]);
                                            g++;
                            }break;
        case 6:           lcd_init();
                    lcd_pos(0x40);                         //右轉(zhuǎn)
                           while(cdis6[g]!='\0')
                                     lcd_wdat(cdis6[g]);
                                            g++;
                                } break;
        case 8:           lcd_init();
                    lcd_pos(0x40);                 //倒車(chē)
                        while(cdis8[g]!='\0')
                                      lcd_wdat(cdis8[g]);
                                            g++;
                                }break;
        default :break;
void motor()
     EN12=1;
         EN34=1;
    switch(        n)
        {   case 2:             //前進(jìn)
                  M1=1;
                                   M2=0;
                              M3=1;
                               M4=0;
                   /* delayxms(5-t);
                              M1=0;
                                M3=0;
                   elayxms(t);           */
                  break;
                 case 4:                              //左轉(zhuǎn)
                     M1=0;
                           M2=0;
                                  M3=1;
                                  M4=0;
                     /*delayxms(5-t);
                      M1=0;
                  M3=0;
                 layxms(t+1);          */
                   break;
                 case 6:                                          //右轉(zhuǎn)
                            M1=1;
                      M2=0;
                              M3=0;
                              M4=0;
                     /*delayxms(5-t);
                         M1=0;
                      M3=0;
                      layxms(t+1);                  */
                 break;
                 case 8:                                //后退
                     M1=0;
                      M2=1;
                      M3=0;
                      M4=1;
                      /*delayxms(5-t);
                      M2=0;
                      M4=0;
                      layxms(t);          */
                   break;
                 case 5:
                      EN12=0;
                       EN34=0;
                   break;
                default :break;
函數(shù)功能:定時(shí)器T0的中斷服務(wù)函數(shù)
void Time0(void ) interrupt 1 using 1 //定時(shí)器T0的中斷編號(hào)為1,使用第1組工作寄存器
    count++;          //T0每中斷1次,count1
         if(count==20)     //若累計(jì)滿(mǎn)20次,即計(jì)滿(mǎn)1秒鐘
       flag=1;        //計(jì)滿(mǎn)1秒鐘標(biāo)志位置1
                 count=0;       //0,重新統(tǒng)計(jì)中斷次數(shù)
    TH0=(65536-46083)/256;   //定時(shí)器T08位重新賦初值
         TL0=(65536-46083)%256;   //定時(shí)器T08位重新賦初值
void delay1(int ms)
        unsigned char y;
        while(ms--)
                for(y = 0; y<250; y++)
                        _nop_();
                        _nop_();
                        _nop_();
                        _nop_();
uint i;
uchar j;
for(j=t;j>0;j--)
    for(i=80;i>0;i--);  //延時(shí)124*8+10=1002us
評(píng)分
參與人數(shù) 1黑幣 +50 收起 理由
查看全部評(píng)分
相關(guān)帖子
