查看: 4622|回復(fù): 0
STM8S學(xué)習(xí)之PD口流水燈GPIO庫(kù)函數(shù)熟悉
ID:109770 發(fā)表于 2016-3-20 03:14 | 顯示全部樓層 |閱讀模式
  * @file    Project/main.c
  * @author  MCD Application Team
  * @version V2.1.0
  * @date    18-November-2011
  * @brief   Main program body
  * @attention
  * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
  * <h2><center>&copy; COPYRIGHT 2011 STMicroelectronics</center></h2>
/* Includes ------------------------------------------------------------------*/
#include "stm8s.h"
/* Private defines -----------------------------------------------------------*/
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
#define LED_GPIO_PORT  (GPIOE)
#define LED_GPIO_PINS  (GPIO_PIN_5)
void Delay(uint16_t nCount)
  /* Decrement nCount value */
  while (nCount != 0)
    nCount--;
void main(void)
  /* Initialize I/Os in Output Mode */
  //GPIO_Init(LED_GPIO_PORT, (GPIO_Pin_TypeDef)LED_GPIO_PINS, GPIO_MODE_OUT_PP_LOW_FAST);
  GPIO_Init(GPIOE, GPIO_PIN_5, GPIO_MODE_OUT_PP_HIGH_FAST);
  GPIO_Init(GPIOD, GPIO_PIN_ALL, GPIO_MODE_OUT_OD_LOW_FAST);
  while (1)
    /* Toggles LEDs */
    //GPIO_WriteReverse(LED_GPIO_PORT, (GPIO_Pin_TypeDef)LED_GPIO_PINS);
    //GPIO_WriteReverse(GPIOE, GPIO_PIN_5);
    GPIO_Write(GPIOE, 0x20);
    GPIO_Write(GPIOD, 0xFE);
    Delay(0xFFFF);
    GPIO_Write(GPIOD, 0xFD);
    Delay(0xFFFF);
    GPIO_Write(GPIOD, 0xFB);
    Delay(0xFFFF);
    GPIO_Write(GPIOD, 0xF7);
    Delay(0xFFFF);
    GPIO_Write(GPIOD, 0xEF);
    Delay(0xFFFF);
    GPIO_Write(GPIOD, 0xDF);
    Delay(0xFFFF);
    GPIO_Write(GPIOD, 0xBF);
    Delay(0xFFFF);
    GPIO_Write(GPIOD, 0x7F);
    Delay(0xFFFF);
    GPIO_Write(GPIOE, 0x00);
    Delay(0xFFFF);
    Delay(0xFFFF);
    Delay(0xFFFF);
#ifdef USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *   where the assert_param error has occurred.
  * @param file: pointer to the source file name
  * @param line: assert_param error line source number
  * @retval : None
void assert_failed(u8* file, u32 line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
/******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
