查看: 2660|回復: 2
51單片機—直流電機速度控制
ID:109480 發表于 2016-3-18 11:45 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
#include "lcd1602.h"
sfr T2MOD = 0x0c9;
sbit Q0 = P2^4;
sbit Q1 = P2^5;
sbit Q2 = P2^6;
sbit Q3 = P2^7;
sbit GORB        = P1^6; //»»Ïà
sbit PWM = P1^7;
sbit UP        = P1^0;
sbit DOWM        = P1^1;
sbit ADDSPEED = P1^2;
sbit SUBSPEED        = P1^3;
uint tuint = 65535;
uint tpwm = 1;        //pwmÖüÆúÎa10000us tpwm±ä῱íê¾pwm¸ßμçÆ½ê±¼ä£¬ò2Ïàμ±óúÕ¼¿Õ±è (·ÂÕæê±£¬ÆμÂê¸ßê±£¬μç»ú·′ó|Ây¡£ÔúêμÎïéÏòa¼ó′óÆμÂê)
uchar t1_flag = 0;
uint pulse = 0;
uint t0_flag = 0;
uchar t2_flag = 0;
bit t2_over = 0;
bit Just_Get = 1;
#define         ZZ                 { Q0 = 0;Q1 = 0;Q2 = 1;Q3 = 1;}        //Õy×a
#define         FZ                 { Q0 = 1;Q1 = 1;Q2 = 0;Q3 = 0;}        //·′×a
#define         STOP        { Q0 = 1;Q1 = 0;Q2 = 1;Q3 = 0;}        //í£Ö1
//½ûÖ13öÏÖ Q0 = 0;Q1 = 1;Q2 = 0;Q3 = 1; 2»è»»áéÕμômos1ü
//************************ PID *************************************
float now = 0,bef = 0,bbef = 0;         //±¾′Î2éÑùÖ죬éÏ′Î2éÑùÖ죬éÏéÏ′Î2éÑùÖμ
float err_now,err_bef,err_bbef;                //μ±Ç°Æ«2éÏ′ÎÆ«2éÏéÏ′ÎÆ«2î
float error_add = 0;                                //ËùóDÆ«2îÖ®oí
float set = 25;                                                //é趨Öμ
float kp = 25;
float ki = 25;
float kd = 0;
void delayms(uint ms)//Ñóê±£¿¸ö ms
    uchar a,b,c;
        while(ms--)
          for(c=1;c>0;c--)
        for(b=142;b>0;b--)
            for(a=2;a>0;a--);
void timer_init()
        EA = 1;
        ET0 = 1;
        ET1 = 1;
        ET2 = 1;
        TMOD = 0x15; //¶¨ê±Æ÷0 ¼ÆêyÄ£ê½ ¶¨ê±Æ÷1Ä£ê½1
        T2MOD = 0x01;
        TH0 = TL0 = 255;
        TH2 = 0x3C;
        TL2 = 0xB0;                //50MS
void timer1() interrupt 3
        if(t1_flag == 0)
                t1_flag = 1;
                PWM = 1;
                TH1 = (tuint - tpwm + 1)/256;
                TL1 = (tuint - tpwm + 1)%256;
                t1_flag = 0;
                PWM = 0;
                TH1 = (tuint - 10000 + tpwm + 1)/256;
                TL1 = (tuint - 10000 + tpwm + 1)%256;
void timer0() interrupt 1
        TH0 = TL0 = 255;
        t0_flag++;
void timer2() interrupt 5
        TF2 = 0;
        TH2 = 0x3C;
        TL2 = 0xB0;                //50MS
        t2_flag++;
        if(t2_flag == 2)
                TR0 = 0;
                TR2 = 0;
                t2_flag = 0;
                t2_over = 1;        //±íê¾100msê±¼äμ½
void GetPulse()
        t0_flag = 0;
        t2_flag = 0;
        TH0 = TL0 = 255;
        TH2 = 0x3C;
        TL2 = 0xB0;                //50MS
        TR0 = 1;
        TR2 = 1;
int PID()        //Ôöá¿ê½PID
        int change;
        err_now = set - now;
        err_bef = set - bef;
        err_bbef = set - bbef;
        change = kp*(err_now - err_bef) + ki*err_now + kd*(err_now - 2*err_bef + err_bbef);
        if(set >= now)
                if(set - now > 1)
                        change = 0.2*kp*(err_now - err_bef) + 0.5*ki*err_now + kd*(err_now - 2*err_bef + err_bbef);
        else if(now > set)
                if(now - set > 1)
        //change = (kp + ki + kd)*(set - now) + (-kp - 2*kd)*(set - bef) + kd*(set - bbef);
        //change = kp*(set - now) + ki*(set - bef) + kd*(set - bbef);
        if(change > 0)
                printchar(1,10,'+');
                printuint(1,11,4,change);
        else if(change < 0)
                printchar(1,10,'-');
                printuint(1,11,4,-change);
        else if(change == 0)
                printchar(1,10,' ');
                printword(1,11," 0  ");
        return(change);
int PID2()                //λÖÃê½PID
        int num = 0;
        static num_bef = 0;
        error_add = error_add + err_now;  //Îó2îàÛ¼ó¡£ò»μ©Îó2îÎa0Ôòerror_addμÄÖμ2»±ä£¬PIDêä3öÖμ2»±ä
        num = kp*err_now + ki*error_add + kd*(err_now - err_bef);
        if(set - now >= 0)
                if(set - now > 1)
                        num = 0.1*kp*err_now + ki*error_add + kd*(err_now - err_bef);
                if(now - set > 1)
        if(num > num_bef)
                printuint(1,11,4,num - num_bef);
        else if(num < num_bef)
                printuint(1,11,4,num_bef - num);
                printuint(1,11,4,0);
        num_bef = num;
        return((uint)num);
        lcd_init();
        timer_init();
        TH1 = TL1 = 255;
        printword(0,0,"P:");                //±èàyÏμêy
        printword(0,5,"S:");                //é趨Öμ
        printword(1,0,"TPWM:");                //μ±Ç°Õ¼¿Õ±è
        printword(0,10,"PS:");                //μ±Ç°μç»ú·′à¡μÄÿÃëÂö3åêy
                if(GORB == 1)
                {        ZZ;                }
                {        FZ;                }
                if(ADDSPEED == 0)
                        set++;
                if(SUBSPEED == 0)
                        set--;
                if(Just_Get == 1)
                        Just_Get = 0;
                        GetPulse();
                else if(t2_over == 1)
                        t2_over = 0;
                        Just_Get = 1;
                        pulse = t0_flag;
                        bbef = bef;
                        bef = now;
                        now = t0_flag;
                        if(set != 0)
                                TR1 = 1;
                                TR1 = 0;
                                PWM = 0;
                //        tpwm = tpwm + PID();                //Ôöá¿ê½PID
                        tpwm = PID2();                                //λÖÃê½PID
                if(UP == 0)
                        kp = kp + 1;
                if(DOWM == 0)
                        kp = kp - 1;
                printuint(0,2,3,kp);
                printuint(0,7,3,set);
                printuint(1,5,4,tpwm);
                printuint(0,13,5,pulse);
參與人數 1黑幣 +60 收起 理由
admin + 60 共享資料的黑幣獎勵!
ID:1 發表于 2016-3-18 13:17 | 只看該作者
lcd1602.h 這個頭文件能分享一下嗎?
ID:448352 發表于 2018-12-17 20:48 | 只看該作者
有圖片嗎
