查看: 2201|回復: 0
MCS-51單片機匯編指令集部分詳解
ID:107189 發表于 2016-3-6 14:26 | 只看該作者 回帖獎勵 |正序瀏覽 |閱讀模式
(1)數據傳送類指令(7種助記符)
MOV(英文為Move):對內部數據寄存器RAM和特殊功能寄存器SFR的數據進行傳送;
MOVC(Move Code)讀取程序存儲器數據表格的數據傳送;
MOVX (Move External RAM) 對外部RAM的數據傳送;
XCH (Exchange) 字節交換;
XCHD (Exchange low-order Digit) 低半字節交換;
PUSH (Push onto Stack) 入棧;
POP  (Pop from Stack) 出棧;
(2)算術運算類指令(8種助記符)
ADD(Addition) 加法;
ADDC(Add with Carry) 帶進位加法;
SUBB(Subtract with Borrow) 帶借位減法;
DA(Decimal Adjust) 十進制調整;
INC(Increment) 加1;
DEC(Decrement) 減1;
MUL(Multiplication、Multiply) 乘法;
DIV(Division、Divide) 除法;
(3)邏輯運算類指令(10種助記符)
ANL(AND Logic) 邏輯與;
ORL(OR Logic) 邏輯或;
XRL(Exclusive-OR Logic) 邏輯異或;
CLR(Clear) 清零;
CPL(Complement) 取反;
RL(Rotate left) 循環左移;
RLC(Rotate Left throught the Carry flag) 帶進位循環左移;
RR(Rotate Right) 循環右移;
RRC (Rotate Right throught the Carry flag) 帶進位循環右移;
SWAP (Swap) 低4位與高4位交換;
(4)控制轉移類指令(17種助記符)
ACALL(Absolute subroutine Call)子程序絕對調用;
LCALL(Long subroutine Call)子程序長調用;
RET(Return from subroutine)子程序返回;
RETI(Return from Interruption)中斷返回;
SJMP(Short Jump)短轉移;
AJMP(Absolute Jump)絕對轉移;
LJMP(Long Jump)長轉移;
CJNE (Compare Jump if Not Equal)比較不相等則轉移;
DJNZ (Decrement Jump if Not Zero)減1后不為0則轉移;
JZ (Jump if Zero)結果為0則轉移;
JNZ (Jump if Not Zero) 結果不為0則轉移;
JC (Jump if the Carry flag is set)有進位則轉移;
JNC (Jump if Not Carry)無進位則轉移;
JB (Jump if the Bit is set)位為1則轉移;
JNB (Jump if the Bit is Not set) 位為0則轉移;
JBC(Jump if the Bit is set and Clear the bit) 位為1則轉移,并清除該位;
NOP (No Operation) 空操作;
(5)位操作指令(1種助記符)
SETB(Set Bit) 位 置1 。
