查看: 1986|回復: 0
Linux下的openssl安裝
ID:107189 發表于 2016-3-5 18:12 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
我從網上搜索到了一篇安裝openssl的英文文章,地址在 http://www.devside.net/web/server/linux/openssl 我按照上面說的安裝了zlib,openssl。步驟簡介如下(怕以后忘了)
先安裝zlib,見linux下安裝zlib
安裝openssl
Building a Web Server, for Linux
下載地址
  • Package(Linux source) : openssl-0.9.8c.tar.gz
  • 解壓文件
    tar -zxvf openssl-0.9.8c.tar.gz
Our Configuration
  • Install to : 默認安裝路徑 /usr/local/ssl
  • Module type : dynamically and staticly loaded modules, *.so *.a
Build InstructionsConfigure.../openssl-0.9.8c]# ./config --prefix=/usr/local/ --openssldir=/usr/local/openssl -g3 shared zlib-dynamic enable-camellia
  • --prefix=/usr/local/ --openssldir=/usr/local/openssl
    [指定安裝路徑; 默認是'/usr/local/ssl' -- which we will symlink]
  • shared
    [in addition to the usual static libraries, create shared libraries]
  • zlib-dynamic
    [like "zlib", but has OpenSSL load the zlib library dynamically when needed]
  • enable-camellia
    [enables the symmetric cipher 'Camellia' (128-bit, 192-bit, 256-bit key versions), which is now available for royalty-free use]
  • 運行./config --prefix=/usr/local/openssl (更 多選項用./config --help來查看),可用的選項有:no-mdc2、no-cast no-rc2、no-rc5、no-ripemd、 no-rc4 no-des 、no-md2、no-md4、no-idea 、no-aes、no-bf、no-err、no-dsa、no-dh、 no-ec、no-hw、no-asm、no-krb5、no-dso 、no-threads 、no-zlib、-DOPENSSL_NO_HASH_COMP、-DOPENSSL_NO_ERR、-DOPENSSL_NO_HW 、- DOPENSSL_NO_OCSP、-DOPENSSL_NO_SHA256和-DOPENSSL_NO_SHA512等。去掉不必要的內容可以減少生成庫的大小。 若要生成debug版本的庫和可執行程序加-g或者-g3(openssl中有很多宏,需要調試學習最好加上-g3)。
display guess on system made by './config'...
.../openssl-0.9.8c]# ./config -t 正式安裝,Build and Install
  • .../openssl-0.9.8c]# make depend
    [step required since extra cipher was enabled]      (時間很長)
  • .../openssl-0.9.8c]# make                     (時間很長,慢慢等待)
  • .../openssl-0.9.8c]# make test
  • .../openssl-0.9.8c]# make install
*測試是否安裝成功,#openssl version 是否是新安裝的版本
SymlinkForm symlink from '/usr/local/ssl-0.9.8c' to '/usr/local/ssl'
  • ...]# cd /usr/local
  • /usr/local]# ln -s ssl-0.9.8c ssl
Update the Run-time Linkerld.so.cache will need to be updated with the location of the new OpenSSL shared libs: libcrypto.so.0.9.8 and libssl.so.0.9.8
Sometimes it is sufficient to just symlink or copy these two files to /lib, but we recommend you follow these instructions instead.
Edit /etc/ld.so.conf, add to paths...
/usr/local/ssl/lib Update the run-time linker...
...]# ldconfig Update the PATHEdit /root/.bash_profile, add to PATH variable...
/usr/local/ssl/bin Re-login.
[sanity check] OpenSSLVerify that binary 'openssl' is linking against the correct ssl libraries...
...]# ldd /usr/local/openssl/bin/openssl
  • libssl.so.0.9.8 => /usr/local/ssl-0.9.8c/lib/libssl.so.0.9.8 ...
  • libcrypto.so.0.9.8 => /usr/local/ssl-0.9.8c/lib/libcrypto.so.0.9.8 ...
...]# which openssl /usr/local/ssl/bin/openssl...]# openssl version OpenSSL 0.9.8c 05 Sep 2006If another path, or an older version is shown, your system contains a previously installed OpenSSL that is first [relative to the newer openssl] in the path.
Repeate the steps in section 'Update the PATH', except place the specified location at the start of the PATH variable.
Note that the older openssl, on most systems, is located under /usr/bin
The location of 'openssl' can be found with...
...]# which openssl
  • ...]# openssl version
    • should display openssl 0.9.7d 17 mar 2004
    • if an older version is shown, your system contains a previously installed openssl.
      • repeate the steps in update the path, except place the specified location at the start of the path variable.
      • [the older openssl, on most systems, is located under /usr/bin]
      • [the command 'which openssl' should display the path of the openssl that your system is using]
  • /usr/local/ssl/bin]# ./openssl version should display the correct version.
     但是我最后沒有得到想要的結果,系統原來的openssl還是沒能卸載掉,我該怎么做那?我繼續搜索資料,哈,幸運的我找了,在一個國內論壇上是這么說的
      cd /usr/local/ssl/lib
      ln -s libcrypto.so.0.9.7 libcrypto.so.2
      ln -s libssl.so.0.9.7 libssl.so.2
      //最后要刷新系統的動態連接庫配置
      echo /usr/local/ssl/lib >> /etc/ld.so.conf
      ldconfig -v
        這下子我豁然開朗,原來依賴的那2個文件是個軟鏈接啊,我把它修改為我現在真正的openssl庫文件不是就行了嗎?于是一頓忙碌后,我終于執行了 rpm -e -nodeps ,然后重新啟動系統,一路運行下去,全是綠燈。一時間感覺自己好幸福啊
