我所見過的矩陣鍵盤一般有兩種識別方法:掃描法和線反轉法。以4X4矩陣鍵盤為例,掃描法是依次將每一行置為0,然后讀取列的狀態,這樣就可以通過四次掃描將整個矩陣鍵盤的按鍵狀況辨別出來,這個方法所需的代碼量比較長;而線反轉法則顯得比較簡潔,它通過先將4行全部置0(0xf0),然后讀列的狀態,接著,將列全部置0(0x0f),讀行的狀態,通過(行|列)就能確定整個行列的狀態了。掃描法比線反轉法占用更多的程序儲存空間(ProgramSpace),但占用的更少的數據儲存空間(Data Space)。
程序如下
掃描法:
#include<reg52.h>
uchar num,c;
uchar codeSSEG[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
void delay1ms(uint z)
uint x;
uchar y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void keyscan()
uchar temp;
P2=0xfe;
temp=P2&0xf0;
if(temp!=0xf0)
delay1ms(10);
temp=P2&0xf0;
if(temp!=0xf0)
temp=P2;
switch(temp)
case0xee:num=0;break;
case0xde:num=1;break;
case0xbe:num=2;break;
case0x7e:num=3;break;
while(temp!=0xf0)//松手檢測
temp=P2;
temp=temp&0xf0;
P2=0xfd;
temp=P2&0xf0;
if(temp!=0xf0)
delay1ms(10);
temp=P2&0xf0;
if(temp!=0xf0)
temp=P2;
switch(temp)
case0xed:num=4;break;
case0xdd:num=5;break;
case0xbd:num=6;break;
case0x7d:num=7;break;
while(temp!=0xf0)
temp=P2;
temp=temp&0xf0;
P2=0xfb;
temp=P2&0xf0;
if(temp!=0xf0)
delay1ms(10);
temp=P2&0xf0;
if(temp!=0xf0)
temp=P2;
switch(temp)
case0xeb:num=8;break;
case0xdb:num=9;break;
case0xbb:num=10;break;
case0x7b:num=11;break;
while(temp!=0xf0)
temp=P2;
temp=temp&0xf0;
P2=0xf7;
temp=P2&0xf0;
if(temp!=0xf0)
delay1ms(10);
temp=P2&0xf0;
if(temp!=0xf0)
temp=P2;
switch(temp)
case0xe7:num=12;break;
case0xd7:num=13;break;
case0xb7:num=14;break;
case0x77:num=15;break;
while(temp!=0xf0)
temp=P2;
temp=temp&0xf0;
num=0xff;
keyscan();
P1=~SSEG[num];
線反轉法:
#include<reg52.h>
uchar num;
uint x;
uchar y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void keyscan()
uchar temp,z;
P2=0xf0;
if(P2!=0xf0)
delay1ms(10);
if(P2!=0xf0)
temp=P2;
P2=0x0f;
z=temp|P2;
temp=P2&0x0f;
while(temp!=0x0f)//松手檢測
temp=P2&0x0f;
switch(z)
case0xee: num =0; break;
case 0xde: num =1; break;
case 0xbe: num =2; break;
case 0x7e: num =3; break;
case 0xed: num =4; break;
case 0xdd: num =5; break;
case 0xbd: num =6; break;
case 0x7d: num =7; break;
case 0xeb: num =8; break;
case 0xdb: num =9;break;
case 0xbb: num =10;break;
case 0x7b: num =11;break;
case 0xe7: num =12;break;
case 0xd7: num =13;break;
case 0xb7: num =14;break;
case 0x77: num =15;break;
num=0xff;
P2=0xff;
keyscan();
P1=~SSEG[num];
