查看: 3263|回復: 0
912 The computer has been removed , The machine dover has been
ID:104287 發表于 2016-1-29 19:08 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
    開機后出現報警聲并且提示912錯誤,屏幕顯示:“912 The computer has been removed , The machine dover has been --------”,經上網一查,原來是HP臺式機特有的開箱報警,處理方法可以進入BIOS 設置,將Reset case open status 的設置改為Enabled。
