查看: 6629|回復: 3
單片機電子時鐘-用液晶屏顯示--基于Proteus和keil模擬
ID:102858 發表于 2016-1-12 08:57 | 顯示全部樓層 |閱讀模式
Proteus電路圖:
元器件:
Atmel 89c51
                                        LM032L液晶屏
                                        Button
仿真文件.rar (46.4 KB, 下載次數: 29)
C程序代碼:
/*電子時鐘 1062液晶來顯示*/
#include<reg52.h>
sbit LCD_EN=P3^4;
sbit LCD_RS=P3^5;
sbit s1=P3^0;
sbit s2=P3^1;
sbit s3=P3^2;
sbit rd=P3^7;
uchar count,s1num;
char miao,shi,fen;
uchar code table[]=" 2010-06-25 FIR";
uchar code table1[]="    20:25:00";
void delay(uint z)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
void write_com(uchar com)
        LCD_RS=0;
        P1=com;
        delay(5);
        LCD_EN=1;
        delay(5);
        LCD_EN=0;
void write_data(uchar date)
        LCD_RS=1;
        P1=date;
        delay(5);
        LCD_EN=1;
        delay(5);
        LCD_EN=0;
void init()
        uchar num;
        LCD_EN=0;
        write_com(0x38);
        write_com(0x0f);
        write_com(0x06);
        write_com(0x01);
        write_com(0x80);
        for(num=0;num<15;num++)
   write_data(table[num]);
   delay(5);
write_com(0x80+0x40);
for(num=0;num<12;num++)
   write_data(table1[num]);
   delay(5);
TMOD=0x01;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
EA=1;
ET0=1;
TR0=1;
void write_sfm(uchar add,uchar date)
uchar shi,ge;
shi=date/10;
ge=date%10;
write_com(0x80+0x40+add);
write_data(0x30+shi);
write_data(0x30+ge);
void keyscan()
rd=0;
if(s1==0)
  delay(5);
  if(s1==0)
  { s1num++;
   while(!s1);
   if(s1num==1)
    TR0=0;
    write_com(0x80+0x40+10);
    write_com(0x0f);
   if(s1num==2)
    write_com(0x80+0x40+7);
   if(s1num==3)
    write_com(0x80+0x40+4);
   if(s1num==4)
    s1num=0;
    write_com(0x0c);
    TR0=1;
  if(s1num!=0)
   if(s2==0)
    delay(5);
    if(s2==0)
     while(!s2);
     if(s1num==1)
      miao++;
      if(miao==60)
       miao=0;
      write_sfm(10,miao);
     if(s1num==2)
      fen++;
      if(fen==60)
       fen=0;
      write_sfm(7,fen);
     if(s1num==3)
      shi++;
      if(shi==24)
       shi=0;
      write_sfm(4,shi);
   if(s3==0)
    delay(5);
    if(s3==0)
     while(!s3);
     if(s1num==1)
      miao--;
      if(miao==-1)
       miao=59;
      write_sfm(10,miao);
     if(s1num==2)
      fen--;
      if(fen==-1)
       fen=59;
      write_sfm(7,fen);
     if(s1num==3)
      shi--;
      if(shi==-1)
       shi=23;
      write_sfm(4,shi);
init();
  keyscan();
void timer0() interrupt 1
count++;
if(count==18)
   count=0;
   miao++;
   if(miao==60)
    miao=0;
    fen++;
    if(fen==60)
     fen=0;
     shi++;
     if(shi==24)
      shi=0;
     write_sfm(4,shi);
    write_sfm(7,fen);
   write_sfm(10,miao);
單片機電子時鐘--用液晶屏顯示--基于protues和keil模擬.doc
46.5 KB, 下載次數: 21, 下載積分: 黑幣 -5
ID:99525 發表于 2016-1-12 12:58 | 顯示全部樓層
一個注釋都沒有,一個月后全忘光
ID:1 發表于 2016-1-12 14:28 來自觸屏版 | 顯示全部樓層
樓主你好電腦頭好像沒有上傳成功嗎?
ID:200804 發表于 2017-5-18 21:03 | 顯示全部樓層
很好 學習了
